Author Topic: timing chain removal???  (Read 1629 times)
Offline neckyzips
« on: May 09, 2005, 05:40:20 PM »
hey,
how do i get the timing chain apart or off, there doesnt seem to be a master link... and the slots are two small in the top gear to slid the cam into enough to remove the cam... a little frustrated after 3 hrs of looking marking and fiddling????? also if anyone has the correct settings for a cb500 that would be awsome!
thanks joe
Offline neckyzips
Re: timing chain removal???
« Reply #1 on: May 09, 2005, 09:14:12 PM »
ok, never mind the how to, but the corect positining would be very helpfull, since the paint i used to mark the gear cam and chain, has now dissapeared.... oh well.
thanks joe
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: May 09, 2005, 09:43:37 PM »
Go here and download your Service Manual.  It outlines how to position the cam in relation to TDC when you're doing the top-end.  The position of the chain of course doesn't matter (so long as it's on the sprocket!).
http://www.sohc4.us/forums/index.php?topic=973.0
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
