Author Topic: A/C ?  (Read 850 times)
Offline cb650
A/C ?
« on: May 09, 2012, 08:48:00 AM »
Can a horizontal window unit be installed vertically?   I would say no but hope I'm wrong.
Offline mono
  • Definitely no
Re: A/C ?
« Reply #1 on: May 09, 2012, 08:52:47 AM »
sorry, but that's a big "no".
the coolant coils in an AC unit need to be kept upright, even when being stored (not in use).
Offline BeSeeingYou
Re: A/C ?
« Reply #2 on: May 09, 2012, 08:54:41 AM »
Another concern would be the moisture condensation.  It drips out the bottom on a specific path.  Turn it on it's side and where will it go.  Dripping all through the unit?
Offline cb650
Re: A/C ?
« Reply #3 on: May 09, 2012, 10:54:31 AM »
yea i figured I couldnt but had to ask the "experts" and confirm.    ;D
Thanks guys
« Last Edit: May 10, 2012, 01:29:04 AM by cb650 »
Offline demon78
  • After work to the "Wets"
Re: A/C ?
« Reply #4 on: May 09, 2012, 01:41:54 PM »
No chance if you turn Compressor on it's side the oil will run out of the compressor and it'll seize also compressor is spring mounted internally and sideways could cause compressor to ground out, other thing you risk oil hydraulic lock which is why if you transport a fridge on it's side or back you should wait 24 hours with it upright so iol cand drain back to compressor. (Sorry 2 wordy, just don't).
Bill the demon.
Offline faux fiddy
  • bike in a box
Re: A/C ?
« Reply #5 on: May 09, 2012, 02:28:08 PM »
If it is a matter of the unit not fitting in the window, a friend of mine has solved that problem with a short piece of insulated ductwork.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline mono
  • Definitely no
Re: A/C ?
« Reply #6 on: May 10, 2012, 05:18:33 AM »
i had the same dilemma at an old apartment about 6 years ago - it had old vertical crank windows, and no way to put in a horizontal unit, so i had to bite the bullet on the vertical unit which cost $450 as compared to the $200 horizontal unit.    >:(
Offline cb650
Re: A/C ?
« Reply #7 on: May 10, 2012, 06:28:17 AM »
That is my problem.  When I had a normal job at nite I could open it up and get cool air in here.  Working nites and with the stupid FN dogs now behind me I cant.  Guess I'll have to get a proper A/C.  I hate ac dont really need it here.
Offline fmctm1sw
Re: A/C ?
« Reply #8 on: May 10, 2012, 07:05:49 AM »
Make you one of those "swamp coolers."
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline cb650
Re: A/C ?
« Reply #9 on: May 10, 2012, 07:25:57 AM »
But I dont live in a swamp. ;D
Re: A/C ?
« Reply #10 on: May 10, 2012, 08:48:56 AM »
He's mean. He doesn't like those yap yap Chi-who-a-who-a perros.
Offline tomkimberly
Re: A/C ?
« Reply #11 on: May 11, 2012, 01:15:33 AM »
It's not that hard to rough-in an openng for a A/C unit, I've even removed the window (save the pieces for future re-use) and mounted in the opening. It's not like you're going to want to open that window again.
Tom
