Author Topic: My 2nd CB650 project... This one with a build thread.  (Read 15836 times)
Offline onepieceatatime
« on: May 10, 2012, 02:40:07 PM »
I got another project to work on. It will probably be a slow moving project, but i will post updates as they happen. I have almost finished my 1980 CB650C, so now on to a 1980 CB650 I plan to try to do a build thread on this one, since I did most of the other one before I found this forum, and didn't take any pictures while working on it. I already have a spare engine, and a 1980 CB650 as a parts bike that I picked up for $50 and in about a week I will have 1981 CB650 parts bike that I got for $30.
Here are the photos of what I am starting with.
Plus it came with all of these parts. If the engine on the new parts bike is any good, I'll probably keep the CV carbs to go with it, otherwise they will be added to a pile of parts that I am going to list on e-bay at some point.
This headlight will be going on the bike, with a H4 halogen conversion kit like the custom got.
2 spare wiring harnesses
Harley exhaust  ???
The ram needs replaced on this, but it was thrown in with the parts too.
Oh, and the tires are new.
The spare speedometer drive is slightly different than stock, it uses a clip to hold the cable on, not a screw.
Also the spare fuse holder is slightly different, the choke cable mount hole is open on the side instead of the top.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Re: My 2nd CB650 project... This one with a build thread.
« Reply #1 on: May 10, 2012, 02:45:13 PM »
I forgot to take a picture of the seat... It has been recovered, but is in very good condition.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #2 on: May 17, 2012, 06:14:36 PM »
When I pull off the rusted out right side exhaust, and replace it with a used one off my parts bike, do the copper washers have to be replaced as well, or are they re-useable?
Thanks
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: May 17, 2012, 06:36:59 PM »
nice finds, cheap bike! to start with is always nice.
you could probably reuse them if they're still in good shape but they are pretty cheap on feebay, so i would just replace them.
CB550 K0
« Reply #4 on: May 17, 2012, 08:08:20 PM »
Ok, thanks.
I figured they should be replaced, but I was not sure. I have not had the engine or exhaust off my first project bike, but other than that I pretty much rebuilt it from the ground up. I figured on maybe next winter pulling the engine from that one, sandblasting and re-painting the frame.
I don't think I am going to go that far on this one. Probably just put it back together with the correct parts and use it that way.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #5 on: May 18, 2012, 10:00:53 AM »
Way cool to see another 650 project going. I have a 1980 CB650C and a 1980 CB650 as well. It seems they're mostly the same, but there are enough differences to cause a headache if you're not paying attention.
BTW, just where in the world do you snap up 2 parts bikes for $80?!
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
« Reply #6 on: May 18, 2012, 06:39:20 PM »
The $50 one was on ebay last summer in Pottstown, PA. The $30 one was on ebay in Leesburg, VA this month. I drove to get the first one, about 2 hours each way. I had a co-worker who lives near Leesburg pick up the other one. He is dropping it off at work for me on Monday.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #7 on: May 18, 2012, 06:44:39 PM »
I have noticed several small differences between the 2 models. Most apparent is the wheels, exhaust, and logos, but the forks are about 2 inches longer on the custom, black plastic chainguard and headlight bucket on the standard, chrome on the custom and the master brake cylinder is slightly different also. I put a standard model headlight bucket on the custom (not a big fan of chrome), but have an original if I decide to go back to it.
« Last Edit: May 18, 2012, 06:46:39 PM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #8 on: May 20, 2012, 09:17:53 AM »
So I got a chance to do some work on it today.
First I pulled the front wheel off because the it had the wrong rotor and the caliper wouldn't fit.
Then off with that headlight.
At this point, I am thinking "Look at this mess, no wonder the PO included 2 wiring harnesses in the parts box".
And there went the "Waterproofing" for the wires, revealing  :o
and once all that extra stuff was gone,
http://i.imgur.com/ptJci.jpg
He didn't hack up the original harness after all. :D
And what CB650 is complete with out its 30A wire?
The forks came off due to extreme amounts of oil getting past the seals.
And the clutch lever has a severe bend. I don't think I would be able to use it.
But I have one from the first parts bike
I figure I am going to have to rebuild the master brake cylinder, so lets take it apart.
I think I'll rebuild the one off the parts bike instead of the one with the screw broken off.
« Last Edit: May 21, 2012, 05:06:43 AM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #9 on: May 21, 2012, 05:53:51 AM »
I picked up my parts bike today. Once taken apart, it fit nicely into my Ford Escort.  8)
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline goldarrow
« Reply #10 on: May 21, 2012, 12:27:02 PM »
i wish things are as easy as just "pick up the parts bike" here in SoCal area
if you're ever taking apart your 650 sohc/4 engine, i might be interested in a few parts, tach drive with cable, tach gauge, and camshaft.   my 550 camshaft is pitted :(
CB550 K0
« Reply #11 on: May 21, 2012, 12:40:02 PM »
The parts bike did not have a Tach on it. I do however have a spare cam and tach drive gear that I have been thinking about putting up for sale.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline JimJamerino
  • Yay! I'm a
« Reply #12 on: May 21, 2012, 02:14:03 PM »
I have a hard enough time not buying every bike I want just trolling Craigslist, so it's probably a good thing that I don't lurk ebay.  I think my wife would shoot me if I put another non-running motorcycle in the garage.  If it were running, that would be a different story... but good luck picking up a runner/rider for $30!
~ Jim
Offline goldarrow
« Reply #13 on: May 21, 2012, 02:14:51 PM »
Once you decide, add me to top of your list?
CB550 K0
« Reply #14 on: May 21, 2012, 02:18:02 PM »
If I do, you have first choice.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #15 on: May 21, 2012, 02:48:01 PM »
A bit of clarification...
I have a 1980 CB650C I bought years ago for $400, then bought an untitled parts bike last year for $50. The engine was blown on that parts bike. I then got a good spare engine. Now this project is another $400 bike (1980 CB650). Then I bought a $30 non-runnning untitled parts bike (it is an '81). The engine turns over, the tank is solid but full of rust and has a couple of dents. The forks look very good, but are soft. The carb rack has been picked apart, but I have a carb rack that will fit it. I think this could be a good spare engine too. I also have a big pile of spare parts from other sources.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #16 on: May 21, 2012, 08:04:31 PM »
I compared the rotor I pulled off the front wheel with the one on the parts bike I got today. They are the same size, so I guess the wheel that was on the bike with the new tire was off a 1981 cb650. The forks off the parts bike are in very good condition compared to the 2 sets of 1980 cb650 forks I have. I think I am going to use them on the bike instead of the 1980 version. I compared part numbers and they both take the same caliper. I will have to swap back to the larger rotor. I will probably rebuild these forks too, even though they do not appear to be leaking. The dust seals are even in good condition, soft and not cracked like the ones on the 4 sets of 1980 forks I have.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline goldarrow
« Reply #17 on: May 22, 2012, 08:28:39 PM »
i wouldn't worry about those tires and wheels yet.  i would focus on fire, fuel, and air and other major components to get the bike running first.  i'm sure you already know  ;)
CB550 K0
« Reply #18 on: May 22, 2012, 09:00:53 PM »
First, I think I need to worry about a battery.   ;D Once I have that, then the fuel, fire, air. Since I have the wheels rotors, etc already, that is what I was working with (one of the reasons I took on another CB650 project). When it comes to spending money though, the getting it running will be the priority.
I had the other one running 2 years ago, but then the choke cable connection to the carbs broke and the battery failed. I replaced that junk piece of plastic, and put the carbs back on it, but have not gotten a battery for it yet. Besides that, it needs the tank to be sealed, which I will be doing next week. Then I should have a runner and can take all the time playing with this one that I want.
Before I hook the tank and battery to that one, I may try to fire this one up though, just to see if it will run. Carbs have been cleaned (by PO) but I do not think a bench sync was done.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline goldarrow
« Reply #19 on: May 22, 2012, 09:14:29 PM »
[/quote]
[/quote]
there are several ways to clean out the tank.  if money is the issue, you could try the cheap and effective way Electrolysis.  Or expensive way, the high way, using Evaporust which seems to work well.
CB550 K0
« Reply #20 on: July 19, 2012, 07:41:57 PM »
I got a chance to do a little work on the bike today. I rebuilt the master brake cylinder, put in tapered steering stem bearings, and started to rebuild the forks. The forks are all cleaned up, and the new oil seals are in, but I am still waiting on the oil seal retaining rings, and dust seals. Once I get those, I will re-fill the forks, and re-assemble the front end. I bought all of the correct headlight parts that were missing, and the bike will look correct when I get it back together. I also bought an '81 CB650 headlight so I can have H4 bulbs instead of sealed beam. I have sealed the tanks for both bikes with Caswell's epoxy sealer, but spilled some lacquer thinner on the rattle can black paint job that was on this project. Needless to say it looks terrible, so it will be sandblasted and repainted.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #21 on: September 03, 2012, 09:59:23 AM »
I finished the fork rebuild. Re-assembled the front end and put in a 1981 H4 headlight. I also lubed the cables.
I think I also figured out why the PO couldn't get it to run...
The spark plug boots were all loose on the wires. I bumped one and it fell right off, so I checked the rest of them.
Still to do on this bike:
new brake line
clean carbs
finish sandblasting and paint tank
check/adjust chain
check rear brake shoes
check/ adjust cam chain
check/adjust valves
put in battery and check out electronics
title transfer/ insurance/ registration
I got these off of craigslist, they came from a 1981 CB650. I am going to paint them black, but I have not decided which bike to put them on yet.
« Last Edit: September 03, 2012, 10:02:32 AM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline goldarrow
« Reply #22 on: September 04, 2012, 10:45:14 AM »
That actually happened to me also with my cm400 months ago.  Spark plugs were loose, and also didnt realized that i was really low on fuel.
Simple little thing makes a big difference.
CB550 K0
« Reply #23 on: September 07, 2012, 05:18:39 AM »
Got started on cleaning carbs last night for both bikes.
The carbs for the Custom is finished and all passages clear. I put them on the bike this morning, and got it started for the first time in several years. Sounds like the cam chain needs adjusted, and while I am at it, the valve clearances will be adjusted too. Carbs need another look too, #1 and #2 float bowls overflowed.
Carbs for the standard still need work too. All passages are clear except for 2 of the accelerator pump openings, #1 and #3.
I'll post some pictures later from the spare set of carbs. They need a ton more work before the floats can even be taken out. There was about 1/8 inch of lacquer in them. I did get the main jets and the float bowls cleaned through.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #24 on: September 07, 2012, 08:16:57 PM »
Last year I bought a spare rack of carbs for the CB650 from Ebay. I opened the box to be sure nothing was visibly broken, and was greeted by stale gas smell and wet packing material. I put them on the shelf as they were not really needed. I decided it was time to clean them along with the other 2 sets, and this is what I found.
I put 2 of the bowls in a good solvent  and 2 into Simple green to compare results.
These 2 were in the solvent.
And these 2 in the simple green.
So the solvent ones went into the simple green too along with the main jets and emulsion tubes(which I forgot to take a picture of)
The passages and slow jets still need to be cleaned, as well as the floats. I need to soak them just to free up the floats for removal.
More to follow next week.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
