Author Topic: Quick one, Is a CB550F headlight the same as CB350F headlight?  (Read 2395 times)
Offline UK350F
Hi All, I'm struggling to find a CB350F headlight here. Is a CB550F 1975 headlight the same as CB350F headlight?
Or which other headlight (complete) would fit?
Thanks in advance
Offline LesterPiglet
  • 1977 CB550F2
« Last Edit: May 11, 2012, 05:08:44 AM by LesterPiglet »
bollingball
Re: Quick one, Is a CB550F headlight the same as CB350F headlight?
« Reply #2 on: May 11, 2012, 04:37:25 AM »
Most of these old sealed beam lights are 5 3/4in. or 7in. diameter. measure yours. This may be a good time for a H4 conversion. If your charging system is up to it. With a 350 or a 550 this may be a challenge. Either way check the wattage of your old bulb and try to stay close to that on your new one what ever kind you go with.
edit  After a reread looks like you have the 350F. I would guess it is 5 3/4in. Do you still have the old one to measure? Or the bucket?
Ken
« Last Edit: May 11, 2012, 04:42:48 AM by bollingball »
Offline Bodi
« Reply #3 on: May 11, 2012, 04:45:21 AM »
No, the 550 has a "normal" 7" lamp. The 350-4 and 400F (and a bunch of other smallish 70's Hondas) use a now rare size: 160mm or 6 3/8 I think.
You can still get the 33120-333-670 OEM sealed beam some places, I would ask at a Honda parts desk. There's also a H4 unit available from candlepower.com but this does not fit the OEM aiming ring mount, you have to McGuyver it in (not too hard). With a 35/35W H4 bulb (found at scooter shops) the resulting road light is much better that the stock unit. A higher wattage lamp is likely to overtax the anemic alternators on the 350/400 engines
bollingball
« Reply #4 on: May 11, 2012, 04:57:57 AM »
Good call Bodi Also I just noticed he is over seas don't they have a different aim pattern for driving on the other side of the road? Did the one you gave the # for account for this? I don't know just asking.
Ken
Offline UK350F
« Reply #5 on: May 11, 2012, 07:21:52 AM »
Thank you for your reply's.
when I bought the bike it had a cracked bucket with HM16-M on it and no lens.
I have been searching Ebay, but they all look the same. I'm thinking a Cb200 may fit?
Until I get the correct bucket I can't buy the lens.
Thanks again
Offline grcamna2
« Reply #6 on: May 11, 2012, 07:37:04 AM »
The CB250, CB350 & CB360 will also fit;with the CB250/350 it will help to get the headlight case/bucket that matches your number from 1972'- & up K4 or K5.the older ones..K0-K3 are different & I know all the CB360 model headlights will fit. ;)
Offline UK350F
« Reply #7 on: May 11, 2012, 08:04:14 AM »
Ok that helps to narrow it down more, thanks
  • 1977 CB550F2
« Reply #8 on: May 11, 2012, 09:51:55 AM »
Maybe if you had looked at my links you would have cleared this up sooner.   ::)
Offline matt mattison
« Reply #9 on: May 11, 2012, 12:14:48 PM »
I bought a new cb350 bucket from Sean @ Roc City Cafe racers and sourced the trim ring and lamp from eBay.
1975 CB550F
2011 MV Agusta Brutale 1090RR
