Author Topic: GL500 wiring opps  (Read 829 times)
Offline Sparked
  • Cheaper then therapy
GL500 wiring opps
« on: May 12, 2012, 10:30:20 AM »
So last night I changed out the steering stem bearings on my 1981 GL500 for a set of taper rollers.  All went well and took the bike out for a testride.  All was well except that the right signal indicator wasn't working nor the engine temp gauge.  I pulled the headlight open and found that I had wired the green/blue wire to a green ground wire this morning so I fixed that but neither are working still.  I double checked all the connection and it looks good, anyone have a suggestion of where to look next?   Might I have broken a wire in the wiring harness?
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline grcamna2
Re: GL500 wiring opps
« Reply #1 on: May 12, 2012, 11:52:22 AM »
I would just recommend keep double checking All your connections until you find where the wires have lost contact..possibly in the handle bar to frame ground connectors ? I think the top triple needs to be grounded to a frame ground,or to a green harness ground if nothing else.
Offline Sparked
« Reply #2 on: May 12, 2012, 05:16:15 PM »
Walking away for a couple hours and then looking coming back to the problem sometimes really helps.  I am not sure why but there was an extra black wire and a missing black/brown wire.  put the two together and I have a temp gauge again.  I then switched the wire from the indicators to the opposite  sides and have concluded the wiring to be good,  the bulb burnt out.
Now it is riding time!
1972 CB350F
1982 CM450A
Offline grcamna2
« Reply #3 on: May 12, 2012, 05:27:09 PM »
Good to hear it; that "spaghetti" can be a little heavy in the diet sometimes  :).
