Logo merchandise is available at the SOHC/4 Shop
If a fuse blew than it means 12v got connected to ground.The flasher is now suspect.
My guess is that you connected the wires up wrong. The markings on your relay are a bit ambiguous to me but I suspect that the P goes to the battery 12v +, the L goes to the load (lights) and the X by the process of elimination goes to ground. If you connected the ground to L you probably short circuited the relay. According to my wiring diagram the black wire is power from the battery, the gray wire is the lead to the load and the green wire is ground. Hope this helps.
P (positive) to black wireL (lamp, lights, load) to grey wireand then by elimination it's X (negative) to green wire
