Since my last post, I was waiting for my new Dyna ignition module to arrive to replace my faulty Dyna ignition module (at least I think it was faulty). At last it arrived today (yahoo!). After a quick install and prior to fine tuning, I first checked to see if I was getting spark as I wanted to see if I was getting spark where I was not before (to validate if my prior module was indeed faulty). I checked cylinder 3 and got spark and I checked cylinder 4 and got spark (thereby essentially checking both sides of the ignition coil/module). Great!
Note: During the spark check process I noticed that the starter was not doing well and was struggling to facilitate turning the engine over (not sure why as my 2 month old battery was fully charged according to my charger).
Anyway, I then went to timing the ignition module and believe I got it timed fairly close to were it should be based on the installation instructions, the spark advancer markings, my timing light, etc. Accordingly, I tried to start the bike full on. I got the engine to start but only for a brief moment as the engine at constant throttle would rev well then putter down, rev well then putter down, rev well then full stop.
My thought was it was bad timing addjustments on my part so I want back to re-check my timing adjustments. After tweaking the timing a bit I attempted to again start the bike, this time the starter was barely helping to turn over the bike and as a result I was unable to crank her over to check my timing. Note: I checked my pipes out of curiosity and oddley 1 & 2 were still hot from my first attempt but 3 & 4 were cool (how is this even possible given they are on different sides of the coil/ignition?)
Anyway, after fussing a bit more, re-reading the Clymer manual, Dyna instructions, scratching my head, etc. I went back to try her again. All the while I was thinking...I just spent $300 for a new ignition coil and a new ignition module and neither of them have solved my problem. Anyway, I tried her again, this time no starter crank at all. Completely silent (dead). I tried to kick start the engine but could not get her to turn over that way either. No, I did not have my kill switch on.
At this point, I am done (at least until such time that I can rationally think again). In the meantime, any thoughts from the forum would be helpful as I am fresh out of ideas. I really thought for sure a new ignition coil and/or new ignition module would have done the trick (and maybe they did solve my problem and I just installed them wrong, or I did install correctly and now I have a new/different problem with the starter not working?). Most likely it's me being a very bad new mechanic!!
