Author Topic: HELP...What can cause a stator to burn?  (Read 2624 times)
Offline quietlikeachurch
  • You meet the nicest people...
« on: June 11, 2006, 10:44:44 PM »
I just finished a top-end rebuild on a '70 CB350 twin.  While I was setting the ignition timing with a strobe, I spotted intermittent sparking inside the rotor case, followed by a garlicky-smelling smoke.  I removed the cover and found that part of the stator had burned and there was a brittle broken wire sticking out of the blackened insulation :o!  The burn is in a spot on the outer edge of the stator and is not near anything that could touch it and short it out.  I'm not very good at diagnosing electrical problems, so is there anything obvious I could have done to short the thing out?  All wires coming from the stator look fine and were plugged in correctly, and everything else electrical seems to be working fine.  I'm hoping it was just a freak failure...
Thanks,
-Ian
« Last Edit: June 13, 2006, 01:37:05 PM by quietlikeachurch »
'77 750F
Re: HELP...What can cause a stator to burn?
« Reply #1 on: June 13, 2006, 11:28:45 PM »
Wire isulation breakdown in the rotor.
Too high a load placed on the stator.
Charging a bad battery.
The wrath of the electron gods.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #2 on: June 14, 2006, 08:00:20 PM »
Loose the Elect Starter system before it takes out your "new" stator. The Honda Twins have a habit of sending mister weeder into the stator at fairly low milage. Thrashes around like a chainsaw when the clutch lets go.............like a grenade :'(
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline dusterdude
« Reply #3 on: June 15, 2006, 06:34:04 AM »
mister weeder?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: June 15, 2006, 06:42:23 AM »
Glad I wasn't the only one who didn't know what that was.  ???
Offline dusterdude
« Reply #5 on: June 15, 2006, 10:45:29 AM »
yea,but you coulda showed your ignorance first.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
