Author Topic: How to use the Search Function  (Read 1335 times)
Offline SohRon
« on: May 13, 2012, 09:28:26 PM »
 ??? There seem to be a lot of threads these days that start out "Why doesn't the search work anymore. I tried to search but nothing happened so now I need to repeat a question that's been answered literally thousands of times like: What oil should I use? Where can i get tapered bearings and how do you install them?" et cetera, et cetera, et cetera...
Well, the old search function, the one in the upper right of the page header, is dead (at least temporarily), but a new search is alive and well. It's called the "Google Custom Search" at the bottom left of the header, and it works (IMO) just as well as the old search did. There it is; see? Hiding just under the left side of the header on every page.
When you use Google custom search, the results appear in a different window with a Google format, so that may throw some people who think Google only searches the web. Not so. It's called a "custom search" because it searches only the site it's attached to (such as SOHC.net). So you're still only searching this site, just like the old search did.
Another thing that may confuse some is that the first four or five results are ads, so that may cause them to think they're being directed away from the site. If you look closely, there's a thin line that separates these ads from the actual search results. The ads are necessary because damn! somebody's got to pay for the site somehow and I know for a fact that none of you cheap bastards out there are shelling out any dough in order to keep the site alive... I know I haven't...
So, use the Custom Search just like the old one, and it works just fine.  I spend a lot of time searching when preparing my thread posts and, after having used both, I can say from experience that there's very little difference between the two.
The search function is dead; long live the search function.
Happy searching.  ;D
« Last Edit: May 13, 2012, 09:32:56 PM by SohRon »
Offline Dimitri13
  • 1974 CB550K
Re: How to use the Search Function
« Reply #1 on: May 13, 2012, 09:40:29 PM »
tl;dr
Offline Flying J
« Reply #2 on: May 13, 2012, 09:50:36 PM »
I completely disagree. Using the new search i have found it difficult to find threads that i could easily find with the old one.
Also the old search was Forum dependent or even post dependent. If you wanted to search a post for the word "swingarm" then while you were in that post you did a search and it only did a search in that post. So IMO the new search does less then the old one. I use the new one but would prefer to have the old one fixed.
Offline SohRon
« Reply #3 on: May 13, 2012, 10:21:47 PM »
I completely disagree!
Well, to each their own, and that's your right. I don't seem to have the same problems, but there you go.  ;D
I'm mainly trying to get people to use the search function. Period.
That, too would be fine with me.
« Reply #4 on: May 13, 2012, 10:37:22 PM »
I'm used to the old one and didn't think we had a functioning search. I didn't want to search the web, just our site. Dimitri showed me today. Thanks for the info Ron and to Dimitri. At least I can search again!
Offline Deltarider
« Reply #5 on: May 13, 2012, 11:00:47 PM »
Thanks for the info. I had the impression the search function was under reconstruction. What I miss is the Advanced Search. You could  narrow your search down to the contributions of one forummember. It was very useful if you remembered who it was and I've used it a lot in the past.
CB500K2-ED Excel black
