Author Topic: Who's running Carpy's CB550 pipe?  (Read 9285 times)
Offline Scott S
« on: May 14, 2012, 03:26:58 AM »
 Has anyone got this on a running bike?
http://www.cb750cafe.com/products-page/exhaust/cb550-4-into-1-exhaust-system/
 He says "You will need to increase your main jet size for sure " and I was just wondering where everyone ended up? Did you go up on the main? How much.....105? 110?  Needle position?
  Please list any other mods...pods vs. stock airbox, bigger cam, etc.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline matt mattison
Re: Who's running Carpy's CB550 pipe?
« Reply #1 on: May 14, 2012, 04:18:26 AM »
I have his 550 pipe. I got V stacks with the Hondaman ignition. Other than that I'm stock.  I'm running .38 slows and 110 mains @ 3rd notch down from the top on the needle. The pipe sounds real good IMHO and mine fitted up no problem. The only thing I don't like is you have to remove it for oil changes. That's why I just ordered the MotoGP Werks exhaust.
1975 CB550F
2011 MV Agusta Brutale 1090RR
Offline cb550inct
  • I am really good at buying parts
« Reply #2 on: May 14, 2012, 04:46:59 AM »
Scott I had a yosi replicas on mine I tried sever different combinations but I know this works runs and sounds great
105 main jets
Replace stock filter with uni filter( if you increase fuel you need to increase air)
Lastly I had the exhaust coated with a high temp ceramic coating..... Huge difference ran smoother and backfired less. I don't know for sure if it was the coating but they claim it increases horsepower and performance.
I tried 115 jets way too rich
110 jets .....no low end
100 jets ...no top end
By the way I had a 78 550k if it helps
1978 cb550k
1998 Harley Springer Softail
2004 Harley Heritage Softtail (sold)
2001 Vespa 150 (sold)
1980 Kawasaki Kx 80  (first Bike)
bollingball
« Reply #3 on: May 14, 2012, 04:47:02 AM »
I would not buy a set of pipes that had too be removed every oil change. If I order a set I would tell him to send them bare metal. Then I would send them to be jet coated inside & out.They would last a lot longer Just my opinion.
Ken
« Last Edit: May 14, 2012, 04:49:05 AM by bollingball »
Offline chewbacca5000
  • I polish covers!
« Reply #4 on: May 14, 2012, 04:58:51 AM »
What is jet coated and how much does it cost?  Thanks!
bollingball
« Reply #5 on: May 14, 2012, 05:46:17 AM »
http://www.jet-hot.com/
It is not cheap but worth it IMO
Ken
Offline cb550inct
« Reply #6 on: May 14, 2012, 02:41:37 PM »
I think thats the same product  I used at a local place
www.competitiveedgecoatings.com[/url]
« Last Edit: May 14, 2012, 02:44:39 PM by cb550inct »
1978 cb550k
Offline Scott S
« Reply #7 on: May 14, 2012, 05:19:11 PM »
Ken
 That's exactly why I went with the Jardine on my '78 550K.
 However, this is for my "Sweep The Floor" bike... a rat/cafe'/street fighter that will see limited usage. (I have several other bikes to ride, too) I don't mind taking it off once a year for an oil change.
 The pipes do come in bare metal.
'71 CB500 K0
'81 Yamaha XS650
« Reply #8 on: May 15, 2012, 02:28:15 AM »
I'm probably going to sell my Carpy pipe when I get my new one. I only ran it for a month. If your interested in a slightly used one, PM me your email address and I can send you a few pics. If you buy a new one you might want to weld on a rear mounting tab like I did prior to any painting or coating.
1975 CB550F
Offline Scott S
« Reply #9 on: May 15, 2012, 03:18:43 AM »
 Dangit, Matt! I already have one! I also have a muffler hanger bracket. I'm going to rig up something to hang it from the rear engine mount bolt somehow, since the P.O. cut off the passenger peg mounts.
 Unless the MotoGP Werks exhausts have changed, I'm pretty sure you have to remove it to change the oil filter, too....
 PM me some pics and a price anyway....I'm always looking for a good deal/ ;)
 CB550inCT, I ended up with the same jetting on my '78 550K as well. Slightly different set-up, but the plugs are the best looking plugs I've ever seen! Runs good so far, but I just finished it.
'71 CB500 K0
'81 Yamaha XS650
« Reply #10 on: May 15, 2012, 02:02:41 PM »
MotoGP Werks must have changed their design. It uses springs for easier removal  during servicing. I believe the pipe comes in 3 pieces, it's much like a dirt bike set up now.
1975 CB550F
Offline cb550inct
« Reply #11 on: May 15, 2012, 02:49:20 PM »
My yosi pipe was from , which was held together with springs, I'm pretty sure it was made by gp motoworks
1978 cb550k
Offline Triffecpa
« Reply #12 on: May 15, 2012, 03:28:24 PM »
Matt
Sent you a PM on your pipe.
Thanks
Tracy
Offline ngonerogwu
  • cb350/550
« Reply #13 on: May 15, 2012, 07:04:40 PM »
So what did you set needles at?? 105's felt AWFUL in the midrange
Offline Scott S
« Reply #14 on: May 16, 2012, 03:35:41 AM »
 Raised the needles one clip, 105 main. Air screws 1.5 turns out + just a little more.....not quite 1.75 turns.
 550K with ported and olished head, CB650 cam, Jardine 4-1, Pamco, stock air box with Uni-Filter.
 So far so good, but I just finished the bike.
'71 CB500 K0
'81 Yamaha XS650
Offline ngonerogwu
  • cb350/550
« Reply #15 on: May 16, 2012, 03:31:19 PM »
You raised the needles.... I bet that's my key. So easy to swap jets while the carbs are on, pretty sure my monster hands will necessitate carb removal to change needle position.
Offline manosteel
« Reply #16 on: June 28, 2012, 12:03:54 AM »
i want this pipe!
Offline m33p
« Reply #17 on: June 28, 2012, 06:25:36 AM »
i just received mine but i havent checked it out yet, waiting for my v stacks to come in and dime city is sold out of main jets in 110,115 and 120 so i gotta wait for them too.
Offline 03rangerxlt
« Reply #18 on: June 28, 2012, 07:19:18 AM »
I've got the Motowerks CP exhaust and I really like the construction quality and design.  It came with springs to hold it all together, and there is a numb for securing it with an exhaust hanger off the passenger peg.  I haven't yet heard it as I am still putting together my bike (CB500).
Don't expect the exhaust to just fit up to the bike easy peasy...
If the carpy exaust doesn't come like the Motorwerks GP setup, basically in three sections that are securred with springs, you might want to pass.  On the Motorwerks setup, you install the header extensions loosely to the motor, and using a rubber mallet, install the header to the extensions, then tighten down the header bolts and it draws the header into shape.
« Last Edit: June 28, 2012, 07:24:32 AM by 03rangerxlt »
1972 Honda CB500 Cafe "The War Eagle"
Offline lucky
« Reply #19 on: June 28, 2012, 09:29:22 AM »
105 main jets
Good jetting info on that main jet.
Was the idle jet stock?
Offline lucky
« Reply #20 on: June 28, 2012, 09:32:51 AM »
Thanks for that jetting info.
Offline FfejCB500four
  • 1972 CB500
« Reply #21 on: June 28, 2012, 06:43:07 PM »
Did you decide to sell the Carpy pipe?
PM sent if your selling it or its already sold let me know....
Jeff
