Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
the compression, should rise as the rings bed inpeaceregarding the oil pump, if it has oil, take the plugs out, take the inspection caps for the rockers off, and see if there is oil in the top end.....its what i do?just a suggestionpeace
Try this . Its worked for me .http://forums.sohc4.net/index.php?topic=105999.msg1185531#msg1185531
The last time I re built an engine it took a minute total of cranking to get pressure up. I've been toying with pumps (replacing seals, lapping pump body sides to reduce rotor side clearance ) and ended up needing to prime them after installing as I forgot to prime them. I ran into the tread about putting some pressure into the tank. It's worked twice for me now. Once I have pressure from the pump I see oil at the head about 20 sec later. The area where the cam sits will need to fill with oil before it spills over the cam bearings and makes its way to the front of the head. ---I am here: http://tapatalk.com/map.php?xnufce
Relay? When I used air pressure in the tank it worked both times. I just put my fingers over the tank fill hole and put the air chuck between my fingers. I also put a vice grip on the tank vent hose to keep pressure in the tank. Air will leak around your fingers but it takes very little pressure to get the oil to move down and displace the air. Do this with the plugs out. From earlier posts it seems you've go the pump primed if you get oil at the filter housing. Don't delay. Start it today ( if you see oil at the exhaust tapper holes ) .No sorry the SOHC4 bike relay. I got oil pressure and am fine on this issue. Think the relay is coming to Update NY in August and since your near Buffalo was wondering if you were going to join in. Maybe they go right through toronto.---I am here: http://tapatalk.com/map.php?yws5jf
