Author Topic: Can you flip headlight mounting sleeves?  (Read 1415 times)
Offline 72BlackonBlack
« on: May 15, 2012, 06:15:41 am »
I have always hated how high the headlight was in relation to the rest of the bike on stock 70's CBs.
Simple question... Can you take off the stock headlight mounting sleeves and turn them upside down without any other modifications? If you do have to make modifications, what exactly are they? Does anyone have any before/after pictures?
1976 CB550 Cafe (in progress)
1990 Yamaha Radian YX600 Fighter
1972 Ford Torino 472 BBF...
Offline lucky
Re: Can you flip headlight mounting sleeves?
« Reply #1 on: May 15, 2012, 06:44:18 am »
Yes it is possible depending on the design of the headlight brackets.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: May 15, 2012, 06:45:22 am »
Aren't they tapered? smaller at the top and larger at the bottom?  If so, I think that'd look odd...Larry
« Reply #3 on: May 15, 2012, 08:09:33 am »
Ah, ok... I didn't realize that they were tapered...
I guess that just means I'll pull the sleeves off and polish the upper forks and then put other mounting brackets on there.
Offline Xnavylfr
« Reply #4 on: May 15, 2012, 08:31:52 am »
Why not get you a set of those clamps that hook around the fork tubes and attach the headlight. You could then move the light down as much as possible to give you the clearance you are looking for!!
Xnavylfr(CHUCK)
« Reply #5 on: May 15, 2012, 08:36:10 am »
Xnavylfr(CHUCK)
I already have the brackets that youre talking about so as soon as i strip the forks those are going on.
Offline socalenduro
« Reply #6 on: May 16, 2012, 12:04:38 pm »
and those you can flip side...
i have mine so that they reach straight out, vs (i think the right way) the arms reach up to the final position of the headlight.
so you can get a different look with the same mounting position
