Author Topic: 2.5 exhaust baffle question  (Read 1211 times)
Offline Matt Hubbell
« on: May 15, 2012, 01:02:39 PM »
If my CR29 carbs are tuned with a 2"  exhaust baffle and I go to a 2.5 will I need to get my carbs re-set?
Offline Old Scrambler
Re: 2.5 exhaust baffle question
« Reply #1 on: May 15, 2012, 02:40:43 PM »
I'm guessing you are looking for smoother mid-range power......probably no change but the proof will in the vinyl seat-pad. If you find very little or no change......consider a 3-inch baffle before playing with the carbs.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: May 15, 2012, 04:26:21 PM »
Do they make a 3 inch for a Kerker?
« Reply #3 on: May 15, 2012, 04:48:31 PM »
Not too hard to have a test unit made-up......or add to the 2-inch if you know the 2.5 was an improvement. I do exhaust tuning on my single-cylinder landspeed bike to run at Bonneville.........On the first attempt we were lucky, no carb changes were required for the change in altitude, just removed the baffle completely to run best at WOT.
My brother-in-law built his CB750 to an 836 with a mild cam and Kerker exhaust. Too bad he stayed with stock carbs......the bike actually runs much better on the highway with stock 341 exhaust pipes.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
