Author Topic: tranny time  (Read 1088 times)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
tranny time
« on: May 18, 2012, 11:04:21 AM »
So. I can get into nuetral rocking the wheel in drive direction. Started bike. Couldnt get first. Shifted up and went a foot and locked up. Shifted down and got first. Slowly got to 5 to 10, shift to 2nd locks up wheel, back to first works. Ride back to garage......rock in drive direction, nuetral.....so, can i adjust shift forks from to bottom pan, or is this a case split? What is incorrect also..? Thanks
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline skamagedon
Re: tranny time
« Reply #1 on: May 22, 2012, 10:21:22 AM »
So, update....i rebuilt motor, now, all the way down is nuetral, and up feels like 3rd gear....i am confused. I followed the book....anyone have this issue,what is wacked?
Offline LesterPiglet
  • 1977 CB550F2
Re: tranny time
« Reply #2 on: May 22, 2012, 10:25:31 AM »
What did you do different the second time you built it? You got a different result.
Offline skamagedon
Re: tranny time
« Reply #3 on: May 22, 2012, 10:35:47 AM »
I put the shift forks where they belong
Offline bikerbart
Re: tranny time
« Reply #4 on: May 22, 2012, 12:47:33 PM »
Oh,transmissions.I thought we were talking about chicks with dicks
  • 1977 CB550F2
Re: tranny time
« Reply #5 on: May 22, 2012, 04:07:33 PM »
Are you selecting gears with the engine on the bench? You do know you need to turn the transmission to properly select the gears. Give the chain sprocket a few turns when trying to select.
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: tranny time
« Reply #6 on: May 22, 2012, 04:34:20 PM »
Nine times out of 10 when someone is certain They did something right that's the first place to start to look for mistakes
Offline skamagedon
Re: tranny time
« Reply #7 on: May 22, 2012, 05:28:40 PM »
This is in bike, trying to break in rings. I can shift up rocking the rear wheel all the way up. Down all the way to nuetral is in first gears position. Maybe the gear selector drum assembly deal? Can't get 1st gear. I think one up was second gear....so that info
Offline skamagedon
Re: tranny time
« Reply #8 on: May 22, 2012, 05:30:18 PM »
By all the way up i mean top gear....
  • 1977 CB550F2
Re: tranny time
« Reply #9 on: May 22, 2012, 06:16:23 PM »
Check the round assembly the pins go into. I've no idea what you call it. You are not following the manual.
