Author Topic: 400F slow blinkers  (Read 2443 times)
Offline tory b
400F slow blinkers
« on: May 19, 2012, 06:59:30 PM »
  The turnsignals on my 75 cb400f blink really slow.Any input on how the fix it?
1975 CB400F
1973 CB500
1982 CB900F
1983 GL1100 W/Vetter sidecar
www.vintagericeburners.com
bollingball
Re: 400F slow blinkers
« Reply #1 on: May 19, 2012, 08:54:25 PM »
Clean all contacts in the circuit and get a solid state flasher from any auto parts store. The thermal flasher that came with the bike needs a fully charge battery.
Ken
Offline tory b
« Reply #2 on: May 20, 2012, 05:46:43 PM »
  I will check all the connections,but the battery is new and all other electrical devises are working fine.
Could a bad thermo flasher cause this?And where is it?
1975 CB400F
1973 CB500
1982 CB900F
« Reply #3 on: May 20, 2012, 06:05:07 PM »
But what is the voltage of that new battery when the flashers are slow?! First/easiest thing to check/eliminate for us to help.
On my bike I use that as my voltage indicator since my high performance coils use more power and the battery can get low around town. Blinking slow, down shift/run up the rpms to increase the charging system output then the headlight brightens and the turn signals speed up and I make it home just fine.
Offline Bodi
« Reply #4 on: May 20, 2012, 06:33:20 PM »
If front and rear signals are good and bright but flash slowly, replace the flasher. This is likely to be all that's wrong.
Offline tory b
« Reply #5 on: May 20, 2012, 06:52:40 PM »
Although the headlamp brightens a little when I rev the engine,the tursignals do not speeed up.
1975 CB400F
1973 CB500
1982 CB900F
Offline tomkimberly
« Reply #6 on: May 20, 2012, 07:25:06 PM »
The flasher unit is located at the back side of the battery box. There are three wires however ony two are used. Replace with any 12 volt unit from your local auto parts store. And yes, it is OK to just let it hang there or you can secure it with a tie wrap.
Tom
Offline tory b
« Reply #7 on: May 21, 2012, 01:52:31 PM »
  Thanks guys.
I will check voltage tonight,however,they are consistantly slow through out the RPM range.Reguardless of how dim or bright the headlight gets.
  While I am in there I will replace the flasher.
1975 CB400F
1973 CB500
1982 CB900F
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: May 21, 2012, 01:56:14 PM »
Make sure you have the correct bulbs and that the sockets are not corroded along with the other suggestions...Larry
Offline LesterPiglet
  • 1977 CB550F2
« Reply #9 on: May 21, 2012, 02:20:58 PM »
If the wattage of the bulbs is too low they will flash slowly or not at all. I've discovered this after a week of head scratching, my new winkers had 10w instead of 21w bulbs.
Offline tory b
« Reply #10 on: May 21, 2012, 07:41:42 PM »
Thanks again,
I installed  a 552 flasher can and everything works great.
1975 CB400F
1973 CB500
1982 CB900F
Offline adamlwvdc36
« Reply #11 on: May 21, 2012, 08:47:27 PM »
+1 on this... seriously, my 75 550 had the same problem when I put some trailer lights on it (until I pulled original lights off my parts bike).  All I did was put bigger bulbs in it and it fixed the problem.  Think of it this way, the flasher is a bimetallic strip that heats up, curls to break the flow of electricity, cools down then makes contact again... then repeats.  Bigger bulbs means more current, means strip heats up faster.  The only exception is if youre using LED bulbs. Then youll have to get an electronic flasher.
Just noticed you got it to work a different way... for anyone else, bulbs work too
« Last Edit: May 21, 2012, 08:49:20 PM by adamlwvdc36 »
_ADaM
Be a COWBOY, not a NERD!  youre riding an antique bad ass motorcycle for God's sake...
75 CB550 Named "Don Casper"  Don for grandpa, Casper for the guy that mentored me to riding... RIP Kenny...
Offline tomkimberly
« Reply #12 on: May 21, 2012, 10:41:48 PM »
Thanks again,
Good job!    ;)
