Author Topic: #4 pipe warm... but not hot...  (Read 1091 times)
Offline DJ_AX
« on: May 20, 2012, 04:53:43 PM »
'75 550.. stock everything 'cept 4 into 1 mac pipes.
All timed and tuned including carb sync.
While everything appears to be ok.. running well, plugs look ok... the #4 pipe is not getting nearly as hot as the others. I'm sure it's firing as it wants to die if I pull the wire off while it's running. And like I said all the plugs looks a nice tan.
I do plan on brand new plugs but the stores are all closed right now.
So ... why is the #4 pipe warm... but not hot?
Re: #4 pipe warm... but not hot...
« Reply #1 on: May 20, 2012, 05:15:32 PM »
Don't be so sure, they can idle on 3 cylinders.  Pulling off a spark lead affects two cylinders, not just one.
I'll guess, an impeded pilot jet.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: May 20, 2012, 05:23:48 PM »
How old are your plug wires?  May be time to snip a little bit off the end of that plug's wire where it enters the cap.
Offline DJ_AX
« Reply #3 on: May 20, 2012, 05:53:33 PM »
Heh heh... probably originals .. already snipped a lot.. in fact on number 2 it was too short so I snipped it a couple inches from the coil and spliced a new wire in. The inside of the wire was goop  :o ... all the way up!
Offline Greggo
  • Somebody's
« Reply #4 on: May 20, 2012, 05:55:16 PM »
Yeah, plug wires are kinda important ;)  Sounds like it may be time to replace 'em even if they're not the real problem.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: May 20, 2012, 05:58:57 PM »
+1
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline DJ_AX
« Reply #6 on: May 26, 2012, 06:28:09 AM »
Yes that's what it was! Thanks...
When I looked at it the last two times (and it looked spotless) I neglected the thru hole. With a guitar string... I pushed out a tiny glob of gunk... smiled and said "oohhhh yeaaahhhhh"
Purring at all RPMS now.
