Author Topic: Cables: OEM vs. Motion Pro  (Read 10247 times)
Offline Scott S
« on: May 22, 2012, 12:20:46 PM »
 What's everyones opinion on OEM cabes vs. aftermarket? Namely, Motion Pro?
 I tried aftermarket cables on my CB500. The throttle cable was too long, even when adjusted all the way out. The clutch cable fit and I was happy with it....until I rode a bike with genuine Honda cables.
 I'm now riding my '78 550K project bike. The throttle cable seems stiff and the clutch cable seems stretched (I'm running out of adjustment at the grip).
 A few people on here have said they're happy with the Motion Pro throttle cables.
 I can get BOTH cables for what just the OEM Honda throttle cable costs. There's also a very good chance I can get them locally, too. I'd have to order the Honda cables.
 What would you do?
 FWIW, the bars are Euro Stle bars, so, a little bit lower than stock.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline dhall57
Re: Cables: OEM vs. Motion Pro
« Reply #1 on: May 22, 2012, 12:54:57 PM »
I always get OEM on my 750KO and K6.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline IndyFour
« Reply #2 on: May 22, 2012, 01:27:53 PM »
I replaced my original (I assume) clutch cable with a Motion Pro last year just as a precaution....the old cable was working fine when removed, just old.  The regardless of routing, the new cable always seemed stiff.  Just last week while out on a ride, the new cable (one year old) failed.  Now the original cable is back on and working great....will still get a replacement and keep it on the bike just in case the old one fails someday.
The failure of the Motion Pro was probably a fluke or I just got a bad one....I'll probably get a different brand or OEM next time, though.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline DJ_AX
« Reply #3 on: May 22, 2012, 01:30:43 PM »
Motion Pros have worked ok for me so far... no failures for 5 years and about 30k miles.
Offline Deltarider
« Reply #4 on: May 22, 2012, 01:38:14 PM »
Have a close look at OEM cables and you'll be convinced. It's build quality and... Honda has different models to fit the various handlebars.
CB500K2-ED Excel black
Offline Flying J
« Reply #5 on: May 22, 2012, 01:53:07 PM »
I have been hit and miss with the Motion pro cables. some fit well some dont. OEM is hands down the best but when i build a custom bike I like to get custom length cables from motion pro.
Offline Scott S
« Reply #6 on: May 23, 2012, 09:54:44 AM »
 Ordered new OEM clutch and throttle cables today from Western Hills. I'll wait until it's time for the next valve adjustment and swap the cables when the tank is off. I'll let you know if it makes a difference.
'71 CB500 K0
'81 Yamaha XS650
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7 on: May 23, 2012, 10:31:27 AM »
Note that Motion Pro cables are dry when you get 'em.... might explain why yours is stiff? Also, I have the -3.5" MP clutch cable on my 750F w/ Euro bars.. fits perfectly.
BrockSamson
« Reply #8 on: May 23, 2012, 10:34:01 AM »
+1 you need to lube the cables from Motion Pro.  If you read accounts of premature failure of these cables that is most likely the reason.  I haven't had any fitment issues with their throttle cables.
Offline Really?
« Reply #9 on: May 23, 2012, 11:06:57 AM »
Ditto but on the K5.  Lubing is a PITA though, even using the tool they sell.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #10 on: May 23, 2012, 01:38:58 PM »
OEM all day if you are keeping stock length.
Offline westondc
  • Wes Mantooth
« Reply #11 on: May 23, 2012, 02:03:08 PM »
I've switched to Motion Pro cables on my CB500 and my quads. Really just because the local bike shop sells them and not the OEM. If i have an issue with the cable not fitting for some reason or prematurely breaking i can take it to them for a return... but I've never had a problem with the MP cables.
« Last Edit: May 23, 2012, 02:04:41 PM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline becken
« Reply #12 on: May 24, 2012, 04:44:42 AM »
I use stock Honda cables on my 550 set up stock and don't think you can find better. That being said, I put pullback risers on my VStar and needed 2" over stock cables and went with the Motion Pro and am very satisfied. You should lube the cables every year and don't forget to put a little grease on the barrel on the end of the cable where it fits into the lever as the barrel needs to pivot a little when you pull the clutch lever. If it doesn't pivot you will be bending the cable at the barrel and cause it to work harden and eventually break. If the cable breaks at the barrel this is most likely the reason.
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline CBNJ74
  • Sweep the leg!
« Reply #13 on: May 24, 2012, 08:11:28 AM »
 I just snapped a motion pro pull cable after about month of use...never again. I just installed an OEM cable last night and it is the way to go.
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline Deltarider
« Reply #14 on: May 24, 2012, 08:52:56 AM »
OEM never ever need lubrification. Teflon inside. >130.000 kms, all cables are renewed only once.
« Reply #15 on: May 24, 2012, 09:44:38 PM »
It is easy to accidentally get the wrong cable: in particular, the PD carbs take slightly longer cable free-end than the earlier carbs, and trying to use a PD cable on early carbs results in slack that can't be removed. Going the 'other way' results in a very tight (if at all possible) fit-up. When I get these "grab bags" of old shop parts from "sales", the cables are often in the wrong bag, and I suffer wasted time (and $$) from it.
The Honda cables last for YEARS. My Honda throttle cables are 21 years old. The Motion-Pro sets are not as smooth and don't have the 'feel' of the superior cables, but are serviceable and in some cases, the only option. It's great of them to still make them available!
Offline Scott S
« Reply #16 on: May 25, 2012, 04:30:10 AM »
 Well, I ordered my OEM cables from Western Hills and used their parts fiche to find the proper #'s for my '78 550K. Hopefully, they'll be correct. I'll let you know how they feel once I get them on.
'71 CB500 K0
'81 Yamaha XS650
Offline john_matrix
« Reply #17 on: May 25, 2012, 01:13:23 PM »
I just replaced my original clutch cable with an OEM one.
Pricey, yes, but you use the clutch a lot. And it pulls sooo smooth. About the only thing on my bike that operates as nicely as a modern bike. :)
1977 CB 750K
Offline Tamothy
« Reply #18 on: May 25, 2012, 01:42:45 PM »
Testament to the criticism of Motion Pro cables as replacement. . . .
New throttle cables from Motion Pro for my '77 CB550F leave little room for future adjustment.  Definitely not the proper length for my application.
Current Bikes:
'76 XL350 - just picked it up, will be my forest road/camping machine
'77 CB550F - going to get it top-notch, like ride across the country top-notch, like it is 1980 and it has 12k miles with a loving, original owner
'82 CB900F - my (sometimes) daily rider
'74 RD350 - 6k miles, straight out of a barn, waiting for restoration
These old bikes are teaching me a big boat load!  I love 'em!
« Reply #19 on: May 25, 2012, 08:51:44 PM »
Their CB750F2/3 throttle cables are like that, too...
Offline 1977_cb550k
« Reply #20 on: December 30, 2017, 07:53:06 PM »
Partzilla have cb550 OEM cables at a reasonable price with low international shipping fees.
https://www.partzilla.com/product/honda/22870-374-000
1977 CB550k3
