Author Topic: Oil light at idle after a warm ride  (Read 6067 times)
Offline Miob
« on: May 24, 2012, 12:20:29 AM »
No doubt there are already topics about this, but the search doesn't seem to work for me.
Summer has started here and yesterday was a very warm and humid day. Fearing a closing in thunderstorm I rushed home on my CB750 K2 over the highway. The last ~7km's on the highway there was a traffic jam. Luckily lane splitting is allowed over here, but still, speeds were low, the weather was warm and I was riding between very warm cars. I could really feel the bike getting hot.
At the traffic lights at the end of the highway the oil light came on at idle, minutes later,  back home, it came on at idle again. Oil level is at maximum.
I know it could mean serous damage to my engine, but is it also possible that the oil just got a bit thin because of the high temperatures? It's due to be replaced.
Re: Oil light at idle after a warm ride
« Reply #1 on: May 24, 2012, 12:24:55 AM »
replace the oil and see how it goes,its not uncommon for the light to flicker at idle,the sender may even be getting sus?
Offline Miob
« Reply #2 on: May 24, 2012, 12:33:53 AM »
I hope so, but I'm a bit reluctant to replace the oil when there's a reasonable change that the engine is (severely) damaged. It would be 50,- euro's 'wasted'.
Extra information: The engine ran like it always ran: Smooth, no change in idle speed.
« Reply #3 on: May 24, 2012, 12:37:12 AM »
itll be alright,how much is fifty euros?
edit,,i just worked out thats 64 aussie dollars!so much for super duper oil,mine cost about ten bucks to change.
« Last Edit: May 24, 2012, 12:39:32 AM by dave500 »
Offline Miob
« Reply #4 on: May 24, 2012, 12:53:30 AM »
That's why ;)
If the engine would need serious work, it is much cheaper to find a new engine, meaning I would have wasted the oil or would have to transfer it (with all the polution/possible metal) to the new one.
« Reply #5 on: May 24, 2012, 02:08:22 AM »
it wont need serious work.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #6 on: May 24, 2012, 03:23:50 AM »
Here we go guys, your engine was designed and built pre-synthetic oil.  That means it will perform best with common petroleum base stock oils (cheap) I use rotella at $12.00 American for 4 quarts.  That is one cheap experiment and will, no doubt, cure the thinness problem that is tripping the light.
« Reply #7 on: May 24, 2012, 05:03:54 AM »
What oil do you have in it? Brand/weight?
If there was serious damage to the engine, it would not get you home.
Offline xenoscr
  • 1975 Honda CB750 K5
« Reply #8 on: May 24, 2012, 05:14:24 AM »
Could be a faulty pressure sensor. Had a similar issue last year, scared the crap out of me as I was 6 hours from home on my own. After pulling a few tappet covers to see if things were still slathered in oil my heart stopped racing. One new oil sensor later, I'm good to go.
XeNoSCR
1975 Honda CB750 K5
bollingball
« Reply #9 on: May 24, 2012, 05:17:30 AM »
This came up a few days ago. I like to have a gauge on mine also.
http://forums.sohc4.net/index.php?topic=78643.0
« Last Edit: May 24, 2012, 05:19:04 AM by bollingball »
« Reply #10 on: May 24, 2012, 05:22:35 AM »
Yes, the gauge is proly the next best step. It will tell you much more than just the light.
Offline Spanner 1
« Reply #11 on: May 24, 2012, 05:26:55 AM »
Regular fossil oil 20/50 weight for Summer, whatever brand you like  ;).... anything lighter weight may show low pressure when hot @ idle rpms.
Offline Miob
« Reply #12 on: May 24, 2012, 05:28:33 AM »
Well, I have an oil temperature sensor (I have a very fancy ACEWELL speedo/tacho uni), but I never checked it for accuracy. I have the sensor in the side of the engine, just above/behind where the contact points are (I think I placed it in the place where you can connect an additional oil line to the head?).
Under normal circumstances the temperature does not read over ~72 degrees Celsius, yesterday it was 95 degrees Celsius at it's maximum. But I can't be sure that that's actual oil temperature (that's why I didn't mention it in the openings post, and I really could feel the engine getting way hotter than normal).
I don't remember the oil brand, but the weight is 15W40, considering the last reply that might be the problem...
Offline chewbacca5000
  • I polish covers!
« Reply #13 on: May 24, 2012, 05:30:56 AM »
Dave what is sus?  How do I know if my sending unit is bad?
« Reply #14 on: May 24, 2012, 05:35:14 AM »
I meant oil pressure gauge. The temperature is helpful but pressure is more important.
bollingball
« Reply #15 on: May 24, 2012, 05:51:04 AM »
suspect maybe? I think they either work or don't. I think they trip at about 7 pounds You could put a gauge on and watch the light to see what is going on. clean and tighten the wire connection.
Ken
« Reply #16 on: May 24, 2012, 06:14:16 AM »
Ken
My experience and observation: 99% of the time, a red oil light, even a flickering one, on a previously working engine, with no "event", its the sender. Best way to check it is to replace it. I've heard standard auto units work fine. Even from a Honda automobile.
Good luck!
Offline kpier883
  • is quite the
« Reply #17 on: May 24, 2012, 06:14:57 AM »
I have had no issues with 15w40 in my '74 CB750.  Would not hesitate to run 20w50 if my light was coming on with 15w40 though.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline fmctm1sw
« Reply #18 on: May 24, 2012, 07:03:58 AM »
Make sure the lead to the oil pressure switch isn't shorted somehow.  Usually that happens when the sprocket cover pinches it but you never know...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline iron_worker
« Reply #19 on: May 24, 2012, 07:11:41 AM »
Loads on the engine are very low at idle. I wouldn't worry too much about it.
A key to pressurized lubrication is FLOW. Flow is what draws the heat away from the parts. The pressure doesn't really tell you that much other than the pressure at that one point in the engine. You would have had a good amount of flow with the oil viscosity being low from the high heat.
That said, you do need a certain amount of pressure to keep the moving surfaces separated. A good rule of thumb that I've read is 10psi per 1000RPM.
These old engines are tough, I wouldn't be too too concerned.
IW
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #20 on: May 24, 2012, 08:08:20 AM »
I agree. I believe the Honda service manual even mentions that the light might come on under these conditions. Whether these switches are still accurate, I believe the light is said to come on whenever the oil pressure drops below seven pounds.
