Author Topic: cb400f, misfire under load, coils?  (Read 5321 times)
Offline kajtek
« on: May 24, 2012, 04:56:17 AM »
Hi all,
we are having some very good weather here in england (27 degrees), so of course.. my bike stops working.
rode to work fine yesterday morning, on the way home2 mins down the road it starts to misfire, and fall to pieces under load. cant really get over 6k and when i roll off the throttle it backfires lots, more engine braking too. seems to idle fairly ok and i can sortof bimble around if i need to.
the misfiring is quite jerky and inconsistent, which leads me to think its electrical not fuel starvation. it feels a lot like when i had problems woth rain stopping play.
i pulled my plugs last night and all looked ok, a couple were slighlty lean but nothing significant. checked fuel and fuel lines, undid fuel cap (incase breather hole was blocked), checked air filter. all ok.
checked points using timing light and they were a bit out, ive nearly run out of adjustment so im having to close the gap a little to keep the timing on. i noticed though that the light was skipping about on 2,3 as i it was firing sometimes advanced sometimes retarded. basically all over the place.
so im thinking coils could be bad. obviously need new points (gonna go with pamco when i get paid), david silvers is out of stock but ive found these two on ebay:
http://www.ebay.co.uk/itm/160796295309?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/190495947136?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
would these be ok?
any other suggestions or ideas please, just incase im missing something..
ashley
1978 honda cb400f supersport
Offline iron_worker
Re: cb400f, misfire under load, coils?
« Reply #1 on: May 24, 2012, 07:29:26 AM »
My guess would be points. You've possibly closed the gap too much and the arc is not extinguishing completely when the points open. This could cause an inconsistent spark.
I can't see a reason why a bad coil would sometimes fire early and sometimes fire late. The coil must be charged and the points circuit opened in order to fire.
Anyway, I'm no expert but that is my take. Sounds like you need points anyway so I would go for a nice set of genuine Honda points if possible. (trust me the Daiichi points are no fun to set up!)
IW
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #2 on: May 24, 2012, 08:53:10 AM »
I was having a very similar problem and thought it was my 2/3 coil.  It was in fact something as simple as the very small nut holding the blue wire to the points plate.  Tightened it up and solved the problem.
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline iron_worker
« Reply #3 on: May 24, 2012, 08:55:40 AM »
Good point. Check your connections!
IW
« Reply #4 on: May 24, 2012, 09:37:36 AM »
It's amazing how it can be something that simple.  Check blue and yellow connections at the coils and points, and pay special attention to the black/white wire.  It supplies power to the coils from the ignition/kill switch and could come loose at the coils, or in the headlight bucket.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Psychonaut
« Reply #5 on: May 24, 2012, 12:42:28 PM »
What's your plug gap? Too wide a gap will cause WOT miss.
« Reply #6 on: May 24, 2012, 12:44:38 PM »
check the plug cap resistance,if rain upsets it easily the caps are probably too old and gone high resistance.
Offline kajtek
« Reply #7 on: May 24, 2012, 12:54:55 PM »
Thanks for the suggestions guys, tank off and checking all connections tomorrow!
Will check plug caps but I replaced the due to the terrible originals shorting out.
Offline kajtek
« Reply #8 on: May 24, 2012, 12:55:26 PM »
Also, checked plug gap, 0.7mm across the board.
Offline iron_worker
« Reply #9 on: May 24, 2012, 12:58:27 PM »
Points gap?
« Reply #10 on: May 24, 2012, 12:59:25 PM »
ok if the caps were new theyll be ok,if they were used id look at them.
Offline Drewster
« Reply #11 on: May 24, 2012, 01:38:25 PM »
+1 on the "keep it simple".  I've been trying to get right my '77K, with similar problems as yours and tried a lot of fixes.  Changing coils, cleaning the carbs, setting and resetting points.  Came down to the new $5.00 Daiwa  #2-3 condenser was bad.  Running like a top now.
Good luck
« Reply #12 on: May 24, 2012, 01:54:45 PM »
There it is!
Gap the points and time it correctly.  The points control the charge and discharge of the coils.  Coils will "look" bad if the points aren't working as they should.  That's why they are part of the routine 3000 mile tune up.
Offline kajtek
« Reply #13 on: May 25, 2012, 03:26:30 AM »
ive got a spare set of condensors so will try those out, also will see if i can get a little more life out of my points. its a honda set with the better fitting tek plate, i have an aftermarket one but spent ages trying to make it work right, was at max adjustment and still coudnt time it. either im an idiot or its junk!
any tips on how to extend the life of some points that are running out of adjustment? just need it to work a bit longer until i can afford a pamco..
ashley
« Reply #14 on: May 25, 2012, 09:47:09 AM »
Have you tried...
http://forums.sohc4.net/index.php?topic=5752.msg47539#msg47539
Also, if you peen (mashing it between hammer and anvil at the fitment places) a loose fitting plate can be made to fit snugly within the mount posts.  Personally, I'd find out which position the shim gets the point adjustment in range first, and then peen the plate there.
Are you putting lube on the points cam?  (Keeps the rubbing block from wearing down quickly on the cam.)
Offline kajtek
« Reply #15 on: May 26, 2012, 09:47:46 AM »
All fixed! Switched out the daichi points for sim no name ones I had, cleaned and checked all the connections, re timed and works great!
I add a bit of oil to the pad that ribs against the cam, should I be using some sort of grease instead?
« Reply #16 on: May 26, 2012, 10:35:03 AM »
Oil is better than nothing.  Grease would be better.
I recall when changing points in cars that new ones would come with little pill capsule of grease to put on the cam.  It is placed where the rubbing block hits the cam on the counter clockwise side, so the cam can pick up grease and move it under the rubbing block.
Offline kajtek
« Reply #17 on: May 27, 2012, 05:04:51 AM »
Thanks will try find some grease that can take the high temperatures :)
Offline tory b
« Reply #18 on: May 27, 2012, 10:55:32 AM »
   I am not familier with a 1978 400f.
Do you have pictures of it?
1975 CB400F
1973 CB500
1982 CB900F
1983 GL1100 W/Vetter sidecar
www.vintagericeburners.com
