Thanks tintin! I must confess though that it looks
way better in the picture than it does in person. The engine sidecovers are patchy from the finish coming off and the fins are all stained with burnt oil - someday though
Well, I sat down to rebuild my master cylinder and... totally chickened out. I have read a bunch of threads discussing removing the snap ring but I was not prepared for the actual thing. I couldn't even see the ring, let alone remove it. I would have had to destroy the rubber cap in order to get to it and I seriously doubted my ability reinstall the ring without also destroying the new rubber cap. Instead, I cleaned out the calliper piston and put a new seal in and then flushed and bled the fluid. That's something I guess...
I have an unused m/c rebuild kit if anyone wants to buy one.
Once I had the wheels and brakes put back together I sat on the bike to roll it back and forth, managing to back over the mirror that I placed on the ground when I took the master cylinder off. Yup, awesome work Chad
... at least now I have an excuse to look at aftermarket mirrors now... jeesh
- Chad
