Author Topic: Dreaded MAC muffler buzz kill what does, and doesn't work  (Read 1565 times)
Offline Rigid
  • She likes a
    • KingCustomCycles
« on: May 24, 2012, 02:25:39 PM »
Installed a pretty little 4-1 MAC header and muffler.  No surprise, it buzzes from 2-5 K rpm.  Not a little hum, this was BAD.  I ground off the rivet head holding the baffle and used a slide hammer to force the very tight baffle out.  First I bent the edges of the inside support ring out to make it fit tighter.  No change.  Slide hammer it out again, cut grooves in the same support and bent them out to tighten the fit.  Still bad.   I then drilled 4 quarter inch holes in the support and coated the outside edge with high temp rv.  Problem cured.  Sounds good, no rattle or buzz.
Offline LesterPiglet
  • 1977 CB550F2
Re: Dreaded MAC muffler buzz kill what does, and doesn't work
« Reply #1 on: May 24, 2012, 02:45:08 PM »
Probably the holes cured it. The originals were causing resonance at certain rpm's.
Offline mrrch
« Reply #2 on: May 24, 2012, 08:53:22 PM »
I added a second mounting screw for the baffle as well spreading the inner support flange, no buzz.
my build
