Author Topic: clean carbs, fixed leaks, no start.  (Read 1532 times)
Offline stereosilence
  • 1975 CB550K
« on: May 24, 2012, 04:05:22 PM »
*Update* I got the leaks fixed (one fuel line wasn't *quite* seated properly and one of those small horizontal tubes between two carbs wasn't quite in the middle and was leaking.
Still no start. When I use the starter, it is really high pitched with no difference whether the choke is on or off. What should I try?
Clean the carbs, they said. It'll run great, they said. It's not that hard, they said.
So, I took my carbs to pieces, reassembled them, did a bench sync, put them back on and...they leak a little. They only leak when I have the petcock turned on and for a bit after I turn it off. Does this mean it is the T's? I suppose it could be the float bowls...but the gas shouldn't get up that high due to the floats (which I set meticulously with calipers), right?
Next, I figured I would run the engine a bit and burn off the gas in the bowls before I removed the carbs again. I fire away with the electric starter....nothing. If the gaskets at the top of each piston leak, that would kill the vacuum and no gas would reach the engine right? But wouldn't there be firing on at least one cylinder? It sounded like I wasn't getting anything.
Where do I go from here guys? I've done tons of work and the bike looks great. I am ready to be back on the road and this is all that stands in my way!
« Last Edit: May 24, 2012, 05:58:16 PM by stereosilence »
Offline LesterPiglet
  • 1977 CB550F2
Re: cleaned the carbs, need help.
« Reply #1 on: May 24, 2012, 04:50:07 PM »
What process did you use to set the float heights? This should be done with the carb on it's side, not upside down.
Online Johnie
« Reply #2 on: May 24, 2012, 05:06:16 PM »
First thing you need to do is identify where the leak is coming from and go from there. Could be the T's, float bowl gaskets, float valve worn, etc.
« Last Edit: May 24, 2012, 07:51:03 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline adamlwvdc36
« Reply #3 on: May 24, 2012, 05:20:41 PM »
If its leaking from your overflows (on the bottom of the bowls) then it is something to do with your floats.  with the floats installed, flip the carbs upside down.  The distance from the bottom (now the top because its upside down) of the floats to the body of the carbs is 22mm for spec.  if you did that, and its still leaking, then your float valves are not seating properly.  could be gunk up in there.  after I rebuilt mine, my #1 leaked for a day, I ignored it (turning fuel off when not riding) then the gas/seafoam combination dissolved whatever was up there and now they dont leak.... this worked for MY bike but it may not for yours.
If all else fails, read this thread:
http://forums.sohc4.net/index.php?topic=73521.0
_ADaM
Be a COWBOY, not a NERD!  youre riding an antique bad ass motorcycle for God's sake...
75 CB550 Named "Don Casper"  Don for grandpa, Casper for the guy that mentored me to riding... RIP Kenny...
  • 1977 CB550F2
« Reply #4 on: May 24, 2012, 05:22:31 PM »
I'll say this again. The float heights are not measured with the carbs upside down.
  • 1975 CB550K
« Reply #5 on: May 24, 2012, 05:24:20 PM »
I set the float valves properly. I read a lot of posts about people doing them wrong. The gas is not coming from the overflow valves so I don't think that is the issue
Any idea how to identify the source of the leak? Gas is basically clear...
  • 1977 CB550F2
« Reply #6 on: May 24, 2012, 05:28:54 PM »
Do you have overflow tubes on? If the float heights were wrong this is where the fuel would come from. Completely empty the carbs using the drains. Dry them off. Sprinkle some talc over the carbs and switch on the fuel and see what gets wet first.
bollingball
« Reply #7 on: May 24, 2012, 05:51:19 PM »
You are not explaining it very well. Give us some idea of where you see the leak. Do what Lester said. Remember you are our eyes.
Ken
Offline luap
  • LAWL
Re: clean carbs, fixed leaks, no start.
« Reply #8 on: May 24, 2012, 06:26:25 PM »
you try putting your hand over the back of each carb, good vaccum should suck your hand in,
are you getting any spark
paul
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
  • 1975 CB550K
« Reply #9 on: May 24, 2012, 07:08:07 PM »
I think I am getting spark. Everything worked before I took it apart. I think I did remove the spark plug wires. Maybe I hooked them up wrong?
Do you mean to put my hand over the air intake?
