Author Topic: Torque Spec please  (Read 13358 times)
Offline fishslayeryo
Torque Spec please
« on: May 24, 2012, 05:00:12 PM »
Howdy gents, looking for the torque specs on the bolts/nutts that hold down the front disk to the hub on a CB750K1. Looked at the factory manual and nothing in the Wheel section for it. Also, looking through the pdf manuals I downloaded, I see some specs, but not much as far as torque specs, is there something I'm missing? Is the Clymer better for that? Thanks in advance!
~Yo Han
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
Offline adamlwvdc36
Re: Torque Spec please
« Reply #1 on: May 24, 2012, 05:09:21 PM »
13-18.1 ftlbs.  attached is a snip of the manual I have for a 550... but I would think the frame parts would be the same.
_ADaM
Be a COWBOY, not a NERD!  youre riding an antique bad ass motorcycle for God's sake...
75 CB550 Named "Don Casper"  Don for grandpa, Casper for the guy that mentored me to riding... RIP Kenny...
« Reply #2 on: May 24, 2012, 06:23:56 PM »
Thanks adamlwvdc36! Was that from a honda factory manual for the 550 you got that from?
Hinomaru
« Reply #3 on: May 24, 2012, 06:47:09 PM »
I’m showing that the disc brake rotor 8 mm nut torque specs are different between the CB550 and CB750. The CB750 uses 20.3 to 23.9 ft-lbs.
The original CB750 tanged washers are a PITA and unless you want your bike to be showroom correct, they can be removed along with the original 8 mm nuts. The 1969-75 750 K bike owners can take advantage of the new style 8 mm USB disc rotor nuts that began with the introduction of the 750 K6, part number: 90309-357-000
click on images for a larger view
« Reply #4 on: May 25, 2012, 06:16:45 AM »
Thank you Hinomaru! Is that page from the Honda Service Manual? I do not see those specs in the manuals I downloaded from here.
Hinomaru
« Reply #5 on: May 25, 2012, 06:39:19 AM »
Yo Han, Those specs I posted are taken from a Honda CB 750 shop manual.  It wouldn’t be the first time that a Honda published shop manual has had discrepancy and/or update to add to the confusion. What torque specs are you seeing?
« Reply #6 on: May 25, 2012, 06:54:55 AM »
Hello Hinomaru, I'm looking at the Honda Shop manuals I downloaded from here, but I do not see a general torque specs page nor torque specs in the Front wheel section. Maybe I'm missing a pdf? Thanks for the reply.
« Reply #7 on: May 25, 2012, 07:34:50 AM »
Ends up the Honda manual I downloaded was from elsewhere. Just downloaded all the manuals from here and see the torque specs in Honda CB750 1969 - 1978 Parts Lists - Service Manuals & More.pdf. Thanks again!
