Author Topic: I fought my bike and my bike won  (Read 11653 times)
Offline Magilla
  • My bike: 1976 CB750F
Re: I fought my bike and my bike won
« Reply #50 on: May 30, 2012, 08:08:31 AM »
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline iron_worker
« Reply #51 on: May 30, 2012, 08:20:35 AM »
You know that the carb vent lines and overflow lines are two different lines right?
Overflow line comes from the bottom of the bowl.
Vent lines are nipples near where the fuel line connects between 1&2 and 2&3.
Just checking... All of these lines should have a clear passage from atmosphere to the fuel bowl.
Sounds to me like your needle/needle seat may be not completely shutting off the fuel flow and the fuel is slowly leaking into the float bowl. If the overflow line is clogged then the level will continue to rise until it is in the venturi of the carb and then it will pour out into the airbox and/or into the engine. (Check your oil to see if it smells like gas ... if it does you will have to change it).
IW
Offline phil71
« Reply #52 on: May 30, 2012, 08:34:42 AM »
Yes, if you see the slot, the jets are still in their holders. Does it run rich even at idle, or only when you're riding?
You may have a weak or poorly tuned ignition system.
« Reply #53 on: May 30, 2012, 08:43:21 AM »
That spark plug in your pic is trash after 1/4 mile. Try Phils advice also to make sure you are getting a good spark.Pull the plugs,ground them to the head and turn over the engine in a dimly lit area or at night and see how intense the spark color is on all 4 plugs.  WARNING though,turn the engine over first a little with no plugs or sparking to empty residual or excess fuel if any from the cylinders so nothing goes boom.
Offline Magilla
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline iron_worker
« Reply #56 on: May 30, 2012, 10:05:40 AM »
As far as it being a spark issue ... I really think the root of your issue is carb related. If your carbs are filling up so much that gas is getting into your airbox you have a serious fuel delivery problem that could easily cause the wetted and sooty plugs as shown.
You could try bringing some life back into those plugs by taking a torch to them and burning the soot off.
IW
Offline Magilla
« Reply #57 on: May 30, 2012, 12:09:22 PM »
Update:  I finally had the gas overflow while I was watching it.  Carb 1 had an issue.  The float was set to high ever so slightly and would not shut off some of the time.  I pulled it apart, cleaned it, reinstalled it and adjusted it. So far so good.
Theory on gas in the air box;  If the float does not work correctly the gas is coming in at a greater volume than it can exit through the overflow tube.  The internal hole is real small.  If gas kept coming in it may have filled the carb and then into the airbox.
For sure I will change the oil tonight!!
Cylinders 3&4 seemed to be running correctly and with little carbon buildup on the plugs.  Cylinders 1&2 were not firing correctly.  Both pipes were simply luke warm while pipes 3&4 were getting hot.  Also if I sprayed either into 3 or 4 the bike would die.   If I sprayed it into 1 or 2 nothing happened.  Then I remembered the idle air screws were turned in on 1&2.  After opening them up it seems like all 4 cylinders are now firing and there is very little carbon on any of the plugs.
If the rain holds off I will take it for a ride and see how it is.
Question:  if it seems to run good AND its not running rich, should I open the idle air screws once I put the airbox back on?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline phil71
« Reply #58 on: May 30, 2012, 02:57:34 PM »
Take them out 1.5 turns each from lightly seated. When you sync the carbs, you can do a little idle screw fine tuning with a thermometer, or by feel from exhaust pressures, assuming you have 4 into 4 and they're not leaky
Offline shinyribs
« Reply #59 on: May 30, 2012, 03:44:27 PM »
The most accurate way to adjust the idle mixture is to slowly and evenly open all four screws at the same time by the same amount. Keep opening them as long as the engine responds with increased rpms. If it increases in engine speed that is your indicator that the engine needed that extra fuel.Once it stops responding to the extra fuel you know that you have found the correct amount of idle mixture for your particular bike.
1 1/2 turns is a great place to start tuning from,but it is simply the base line. Good luck!
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
« Reply #60 on: May 30, 2012, 03:59:15 PM »
Your gonna need more than luck unless your bike has PD carbs.  Then this procedure is correct.  For the early style carbs without accelerator pumps and air bleed type pilot screws, it is flat wrong and backwards.  If you tune the pilot screws on these outward for fastest idle, it will idle perfectly, but the throttle response from idle will be dismal to undriveable.
Offline shinyribs
« Reply #61 on: May 30, 2012, 08:41:31 PM »
Worked good on my round tops,but I am always ready to learn something new.What is the correct way?
« Reply #62 on: May 30, 2012, 11:06:03 PM »
Round tops are CV carbs.  The slides move in relation to engine suction.  So, they never open suddenly no matter what you do with the twist grip.  The pilot circuits provide only idle mixture control, so the best adjustment for them is what gets the best most efficient idle.
Magilla's bike is a 76 Cb750. The carbs are mechanical slide type, where the slides are directly coupled to the twist grip.  There is no accelerator pump to add gas when the slides are suddenly opened.  Sudden opening lets the vacuum level drop along with a big gulp of air However, the carb throat pressure rises drastically reducing the jet flow making for a very lean mixture.  You cannot snap the throttle full open from idle as the engine will simply wheeze and die.  Some call it "stumble".  This type carb relies on and over rich idle mixture setting to minimize stumble and throttle twist.  The correct pilot air screw setting is one where the throttle can be twisted up to one half of remaining throttle travel and have the engine pick up smoothly, in and any gear from idle RPM.
Turning the air screw outward on these carb leans the idle mixture.  The leaner it gets, the faster the engine runs at idle, as a leaner mixture is more efficient.  However, there is no "extra" fuel available when the throttle is twisted, and you get horrific stumble.
So, you tune the air bleed screws in concert with how the engine pick up from idle with a throttle twist.  And the "balance point" is where you get good pickup without stumble yet don't foul the plug during a prolonged idle.
If it is stock, use stock setting, if there are induction and exhaust mods, there is yet another tuning effort to find the correct pilot screw setting.
Offline Magilla
« Reply #63 on: May 31, 2012, 03:40:52 AM »
The rain held off so I was able to take the CB for a ride last night.  It ran well.  No popping, no stalling at stop signs.  The throttle response was great.  A quick snap of the throttle breaks the rear tire lose.  The power felt smooth through 5000 RPMs.  I did not take it any higher than that.  The ride was only about 2 miles total.  When I pulled the plugs, three out of four were carbonless.  The number one cylinder had a small amount on it but not much.  I opened the idle air screw an 1/8 turn on that one carb after I reinstalled the plugs.  None of the plugs were wet and there was no gas overflow issues.
So far so good.  I would like to thank all of you for your help.  If not for this forum I would have had to send the bike to the shop to be fixed.  The point in buying it was to putter with it so sending it to the shop would have defeated that.
Tomorrow the weather is supposed to be nice so I will take the bike to work.  That will put a quick hundred miles on it so we will see how it fares.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Roach Carver
« Reply #64 on: May 31, 2012, 05:07:27 AM »
Does you clutch lever have some free play?it should have no real tension on it when you first pull it for maybe 1/4 inch.
Offline Magilla
« Reply #65 on: May 31, 2012, 05:21:56 AM »
What makes you ask this question?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #66 on: May 31, 2012, 06:36:44 AM »
Well, i am concerned about this spinning you feel when you give it the gas. These things dont make huge h.p. So slipping of the clutch is more likely than spinning the tire. Who know though.
Offline Magilla
« Reply #67 on: May 31, 2012, 06:46:00 AM »
The mark on the street indicates tire spin and not clutch spin. . . .thank God.  To be fair we have had a bit of rain so the road was a bit wet.
Tonight the airbox goes back on.  I hope it continues to run well.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #68 on: May 31, 2012, 06:50:04 AM »
sounds good. Just wanted to make sure you werent smoking your clutch. Carry on.
Offline iron_worker
« Reply #69 on: May 31, 2012, 07:24:32 AM »
That's awesome man. Glad you got it figured.
Also, I hope you changed that oil!
IW
Offline jneuf
« Reply #70 on: May 31, 2012, 07:28:17 AM »
It's great to read these threads and see someone successfully fix their bike by the end of it. Bravo!
'75 CB400f
Offline Magilla
« Reply #71 on: May 31, 2012, 07:55:18 AM »
IW
Indeed the oil was changed last night. Oil is NEVER the place to save money.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline shinyribs
« Reply #72 on: May 31, 2012, 02:54:19 PM »
My carbs are '76 model round tops just like the OP's. You can see them in my avatar,not that i expected anyone to know that,of course. The CV carbs are the constant vacuum carbs like you would see on a DOHC. I understand that the roundtops like I have do not have an accelerator pump.They will die if you whack the throttle open too fast.Nature of the beast.It is also the reason,I suspect,that Honda eventually went to an accelerator pump. You CAN band-aid this issue with extremely fat idle mixture,but it will never cure the root issue of a lack of a accelerator circuit. It will just waste fuel,carbon up things and create a stinky bike that nobody wants to be near when it is idling.But that is beside the point. The question the OP asked was how to correctly set his idle mixture. I offered the system that has worked flawlessly for years on my own vehicles,but now I hear I am doing it backwards. So I ask again,if I am doing it wrong what is the correct way? And restricting fuel AWAY from an engine will not make it run faster.More throttle = more fuel=more rpm=go faster
« Reply #73 on: May 31, 2012, 06:15:41 PM »
I've never heard of "round top" being applied to anything other than CV carbs (that have the big round top).
Apparently CB750 folk lore has it's own meaning for terms, that do not appear in the shop manual.
Since there are only three styles of carbs for the CB750, I've only known them to be identified by either their set up number (stamped on them), or PD for the late model, and "early", with a separate designator for the ones with 4 cable actuators (really early) rather than the bellcrank/rod/lifter arm types found on 71 through 76 models.
It doesn't matter what you call them, you should be able to snap the throttle to one half of remaining travel while at idle in any gear including 5th, and the engine will pick up reliably and smoothly.  No you can't snap them full open.  But, you can snap them half way, and that is the true nature of the beast when properly tuned.  At higher engine revs where there is more air velocity through the carbs, the venturi effect produces such a reliable vacuum source, that throttle position changes don't produce any stumble.
If it is stock, you set the air screws to book values.  See page 195 of supplement chapter 20 of the Honda CB750 Shop manual.  The relevant exerpt is:
Carburetor air screw adjustment
... The standard adjustment that gives the best performance is 3/4 to 1 1/4 turns open from the full close position.
I disagree with this statement.  The fuel doesn't make it run.  The fuel won't do anything without the oxygen to combine with and combust.  With fuel ratios greater than 5:1, the engine won't even run no matter how much throttle you give it.  So, "more fuel=more rpm=go faster" is only wishful thinking.  Over rich fuel mixtures do not burn completely and don't reach maximum expansion pressure onto the piston crown.  Clearly more fuel is NOT the answer, unless more oxygen is available for that extra fuel.
These carbs have air bleed screws which adjust the amount of air mixed with the fuel at the pilot jet emulsion tube.
This becomes a premix froth, which is lighter than the raw gas alone, and is far easier to be pulled into the carb throat with engine vacuum.
Turning the air screw outward allows more air to be mixed with the fuel and a leaner ratio fuel air mix burns more efficiently and the engine increases in speed as all (or more of) the fuel is burnt rather than just a portion of it.  To compensate, the slides are lowered to shut off more air flow.  If you were able to add enough air to the premix, you could shut the slide completely, but there is an air jet to limit that and so the slide can only be lowered just so far.
The engine will run with an air fuel mix between 5:1 and 22:1.  Stoichiometric is 14.7 ish :1 and best power is about 12 or 13 :1.
Let's say you were actually able to adjust the idle fuel mixture to a perfect 14.7 to one.  The engine purrs, producing only enough power to overcome internal friction.  Opening a mechanical slide does two things.  1) it suddenly makes more air available inside the carb throat leaning the mixture well away from any ideal power mix.  2), the engine vacuum in the carb throat is suddenly polluted with the pressure from the intake tract upstream the carb slides, from about 16 inches Hg less than atmospheric pressure, to 5 or less.  The pressure differential is what drives fuel through ALL the fuel metering orifices, and reducing that differential severely reduces the fuel available for that sudden inrush of air when the slide is opened.
The result is engine stumble (I call it wheeze) when the throttle is opened suddenly and too far, due to extremely lean A/F fuel mixture.
To combat this, the idle mixture is purposely set rich.  Not rich enough to carbon foul plugs during prolonged idle.  But, rich enough that the A/F ratio remains in the combustible range when the slide is moved to the half way position.
I've told about this experience before in this forum.  But, here it is again to prove my point.  The carbs on the CB550 (022a) are internally designed the same way that the 76 CB750 carbs are designed.   About 20 years ago, I intended to put the extreme fine tune on my 74 CB550.  I obtained an exhaust gas analyzer.  I did the standard tune up to the bike renewing plugs, air filter, etc., synced the carbs, and then set about to optimize the air screws for least hydrocarbons at each of the four exhaust pipes.  As I opened up the air screws, I watched hydrocarbon levels fall, and the idle RPMs went up, so I repeatedly kept backing off the big idle knob to keep the 1000 RPM idle.  It took about 20-30 minutes behind the engine heat from the fan in front.  But, finally I had the lowest HC reading on the analyzer and a perfect 1000 rpm idle and the engine purred pleasingly.  I was quite surprised that the 5-5.5 turns out from seated was so different from book value setting of the air screws.  Still, I eagerly set about to road test my latest toil expecting the best experience to date.
First observation was that even while on the center stand, throttle twist was pretty touchy.  Still, I geared up and headed out the garage toward the street.  The only way to get the bike to move was to rev it up way high and ever so slowly ease the clutch out.  The bike had no power on throttle twist at all, and almost total wheeze.  I didn't get 50 feet from the garage, before realizing there was no way to ride the bike this way.  So, I nursed it/ struggled back up the very shallow grade to the garage.  I realized I had done tune ups before and never had this happen. The only difference was the "super-tune" of the air screws, so I cranked in a turn on each, and noticed the throttle response on the center stand (no engine load) improved greatly.  Now off for the second try road test.  It still sucked, with no acceleration power, only inertia from RPM and slipping the clutch got me any forward advancement.  Back to the garage, for another 1 full turn inward on the each air screw, and off again for another road test, this time bringing the screwdriver with me.
Better, but still not good.  So, I'd give the screws another turn and test, stop and turn the screws in some more and test, in repetition, until I could get predictable and reliable power from the engine in any gear from 1000 RPM, simply by turning the throttle grip, up to half way of remaining throttle travel.
Back to the garage. Shed gear.  And, now to find out the final air screw setting. I count 1 1/4 turns out from seated...which is the book value for the CB550 and 022A carbs.
So, it took me about two hours to learn that book value works the best.  ::)
For your bike, either set the air screws for book value, or mark your throttle and go test drive the bike.  Open the air screws to the max open setting while still maintaining smooth power from idle under load in any gear (including 5th).  It won't be fast in fifth gear from idle, but it will be reliable.  If you open the screws too far, you will get stumble from low RPM, and that tells you to turn those air screws back in.
You can't find this correct setting in the garage, hunting for max engine RPM with slides closed at idle.  I've tried that.
You actually have this backwards.  Your carbs have air bleed screws placed in the path between air jet and pilot emulsion tube. Turning them outward increases air flow from the air jet to the pilot emulsion tubes, and thus leans the mixture.  You aren't giving it ANY extra fuel with a more open screw setting, just the opposite, in fact.
The engine is increasing RPMs because the standard over rich idle mixture is getting a more efficient burn with the added air so more fuel is actually being burnt.  So, more air = less fuel in the mix which increases RPM in this situation with the slides nearly closed.
Offline shinyribs
« Reply #74 on: May 31, 2012, 09:05:02 PM »
I did not realize that the idle mixture screws on my bike were dry. So it appears i was doing it your way after all! ;D
No need to ''prove your point'' with me. Like I said,I am always ready to learn the correct way if I am doing something wrong. Thanks for the info,and again,you dont have to prove yourself to me.I'll take your word for it ;)
