Author Topic: I fought my bike and my bike won  (Read 12725 times)
Offline Magilla
  • My bike: 1976 CB750F
Re: I fought my bike and my bike won
« Reply #75 on: June 01, 2012, 03:37:36 AM »
TwoTired should change his name the TheCarbWhisperer.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline iron_worker
« Reply #76 on: June 01, 2012, 07:08:03 AM »
Great info. I enjoyed the read.
IW
Offline Magilla
« Reply #77 on: June 01, 2012, 08:15:25 AM »
Bad news:  Carb one started to overflow again today.  Just when I thought I had it fix.  For two days it worked fine and today it started to overflow again.  Have I mentioned how much I hate these carbs?  I need an Atkins bike, one with no carbs!!
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #78 on: June 01, 2012, 09:49:39 AM »
Do you shut the fuel off while it is parked?
Are you parking on the side stand or center stand when it leaks?
Have you checked the bowl stand pipe for cracks?
Offline Magilla
« Reply #79 on: June 01, 2012, 10:41:16 AM »
I always shut the fuel off when its parked or at least when I remember too. :)
It leaks while on the side stand.  I have yet to see it leak on the center stand.
I have not.  Not sure that this would cause such an intermittent issue BUT I will check it out.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Magilla
« Reply #80 on: June 01, 2012, 11:56:49 AM »
Still fighting with the bike.
It started on the first kick on Wednesday night.  Today I had to kick it about 50 times.  When it started it would barely run.  Then it warmed up and seemed OK.  I am guessing that this may be due to leaning it out and maybe now it will require a choke to start when its cold.
After a few miles and the bike was warm the idle crept up to about 2000.  So i turned it back with the big idle screw.  After a few more miles the RPMs crept up a few hundred and I had to readjust the idle again.  No big deal.
The new problem is that when you let off the throttle it sticks for a few seconds and then drops back down.  Not a good thing.  I am going to check to see if I pinched a cable the last time I put the tank back on.  That seems to be the variable on this trip.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Roach Carver
« Reply #81 on: June 01, 2012, 03:40:16 PM »
Sluggish return to idle can be an intake rubber leak.
« Reply #82 on: June 01, 2012, 03:41:51 PM »
..or carbs out of vacuum sync...or
Offline Magilla
« Reply #83 on: June 01, 2012, 05:15:08 PM »
Carbs out of vacuum sync?  What is this, how do I check for it and how do I fix it?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #84 on: June 01, 2012, 08:05:04 PM »
See The Honda cb750  shop manual,  Chapter 20 supplement, page 194.
Offline Magilla
« Reply #85 on: June 02, 2012, 04:47:48 AM »
Unfortunately I don't have a Honda manual.  I have a crappy Cylmers (spelling?) manual.
Everything I think I'm close with this bike it kicks me in the nuts ant lets me know that I'm not close at all.  Very frustrating.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #86 on: June 02, 2012, 06:38:24 AM »
I dont have a " shop manual " or the supplements either. I do have 3 cb 750's that all run well. Like I said. What do the intake boots look like. If they are original, you may want to replace them.  If you want to try and use them a little longer you can try and replace the clamps with a conventional style that you can tighten abit more. Your cable is good right?
« Reply #87 on: June 02, 2012, 06:40:47 AM »
Also, you may want to replace that needle and seat. If it stll leaks after that, it can only be 3 things. The float, float height or sediment in the fuel.
Offline Magilla
« Reply #88 on: June 02, 2012, 07:13:48 AM »
Where do I get a new needle and seat?  I will order it today. Is the "intake boot" the one on the air box side or the motor side of the carb?
Motor side connectors look great.  I tested and they have no leaks.  Air box side connectors are not good.  Rock hard.  I have new ones on order.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline DJ_AX
« Reply #89 on: June 02, 2012, 07:15:07 AM »
uhhh... the Honda Manuals.... the first post on this forum. free download.
And chasing the "thing" that will get it running well, is part of it all. You'll know all of those other things  you've fixed and tidied up won't need replacing next... and  while they are not the one "thing" that makes a significantly noticeable difference, collectively they do.
Offline DJ_AX
« Reply #90 on: June 02, 2012, 07:16:41 AM »
I got needles and seats from PartsNMore.com
good price, selection, and service.
don't get the rubber tipped ones!
« Reply #91 on: June 02, 2012, 10:10:41 AM »
You can buy a Honda manual at helminc.com.  It's where I bought mine.
Hard to imagine successfully working on an unknown bike without one.   It's possible to fix a bike with random replacement of components and eventually fix the real problem.  Not that I recommend that.  I always figure, if I know how it's supposed to work, I can figure out why it doesn't.  I believe the shop manual helps in that regard.
The Honda manual is the most knowledgeable source I know of.   Better than most "internet experts", imo.
Offline shinyribs
« Reply #92 on: June 02, 2012, 03:54:56 PM »
I am away from my computer right now ( on phone)  but I can give you a link to a free download in a little while. No need to buy one.
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline Magilla
« Reply #93 on: June 04, 2012, 12:14:56 PM »
New intake tubes on order.  New needle and seat on order.
Took the bike for a nice 20 run on Sunday.  I hit a highway, a state road and inner city streets.  The bike ran well for the entire ride.  The throttle stick/vacuum issue is still there but replacement parts should clear that up this week.  I put new plugs in before the ride and check them after the ride.  Here is what I found
Plug one:  slight carbon build up
Plug two:  very slight carbon build up
Plug three: looks good
Plug four: looks good
When riding at low rpms (under 2500) the pipes on the left side sound different then those on the right.  They have a slight sputter to them.  It all goes away above 3000 RPMs.
All in all it was a good test run.  I feel like I am finally pointed in the right direction.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Magilla
« Reply #94 on: June 08, 2012, 02:29:37 PM »
yep....
http://www.powersportsplus.com/parts/detail/honda/HP-17253-405-300.html
What a pisser.  The new tubes and clamps came in today, after a week of waiting.  They were the wrong size.  I needed 17253-341-300 not the 405s.  My carb inlet is 1.6 inches in diameter.  The old tubes are 1.5 inches in diameter.  The new ones were 1.8 inches in diameter.  That sucked.  Now I have to wait another week for the correct ones to come in.  Another down week.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
