Author Topic: Cafe Project, few questions...  (Read 9256 times)
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
Re: Cafe Project, few questions...
« Reply #75 on: October 07, 2012, 06:16:59 PM »
You need to rethink not putting on a Gordon Kit. It will be under the tank so it wont be seen, you WILL wish you had. Very functional
Offline kidrcth
« Reply #76 on: October 07, 2012, 07:40:58 PM »
i have thought about it. we shall see.. i may
Offline madScientist
« Reply #77 on: October 07, 2012, 07:48:46 PM »
+1 on the frame kit. I just put mine in this last week. It was not difficult and was more of an experiment since, if it worked as well as claimed, I was going to use it in all of my vintage bike builds...or some version of it.
I left the engine in the frame while I worked on it. After I put it in I timed myself on the removal of my engine (carbs and all ancillary equipment removed). From start to finish...removing the engine took me less than 5 minutes. Because I'm SUPER anal I put the engine back in...<4 minutes. Then I wiped the bottom of the engine down with baby powder and removed the engine again. Once again less than 5 minutes but this time I had proof that the engine did not touch the frame anywhere. This was all done with a floor jack under the engine and a motorcycle lift next to it.
i also pulled the head off the engine with it in the frame. Just take a moment to imagine how much nicer it would be to work on your engine if you didn't have to worry about messing up a beautifully coated frame by banging your engine against it when, undoubtedly in the future you want to hot rod that motor...
Long story short...i'm designing a similar kit for a Kaw H2 Triple, a GL1000(more for carb removal), a KZ1100, and a KZ1000.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline kidrcth
« Reply #78 on: October 07, 2012, 07:59:47 PM »
the frame kit is a nice add-on. money isnt the issue. just weather i actually want it. Keeping the frame straight and true is always an issue. for the section of the frame i had to replace from a donor bike i jigged it with 1/4in steel before i cut it, and removed after new piece was in place. i cant really do that with this kit.
im sure if i dont use it, and after this fresh rebuilt motor is broken in. as i know these motors are known to need a re-torque on the head bolts. ill have wished i added the frame kit.
can i remove the valve cover with the motor in without this kit?
but otherwise, i have a spare engine to build if i decide down the road to build it.
« Reply #79 on: October 07, 2012, 08:05:25 PM »
You don't need to...
Can't work on the top end in the frame without the kit at all....  Don't worry mate, i am as fussy as hell with my bikes and would never do anything that would hurt the integrity of the frame, actually quite the opposite, i always brace these frames and am now adding frame kits to all 3 of my projects, i wouldn't even think about it if i thought it was a problem... Mine are all big Horse power projects....
Offline kidrcth
« Reply #80 on: November 11, 2012, 04:52:01 PM »
What am i missing here? can anyone send me a pic of what exactly im missing.
will this auction supply me with what i need?
http://www.ebay.com/itm/honda-cb750f-supersport-cb750-rear-wheel-axle-spacers-adjusters-1978-1977-77-78-/370618066893?pt=Motorcycles_Parts_Accessories&hash=item564a8ee7cd&vxp=mtr
« Last Edit: November 11, 2012, 05:12:16 PM by kidrcth »
Offline kidrcth
« Reply #81 on: November 11, 2012, 05:12:35 PM »
forgot to attach pics, fixed it tho
Offline andrewk
  • doin' it.
« Reply #82 on: November 11, 2012, 05:39:27 PM »
You'll need the spacers on that axle in the auction you linked, plus you'll need a rear caliper holder-
http://www.ebay.com/itm/78-Honda-CB750-CB750F-rear-brake-caliper-bracket-/230540797494
If you're running an early engine (pre-77) you will need to do some work to fix the chainline- late model 750's have more offset in the final drive.  There's a couple options to fix it, if you haven't already.
Offline kidrcth
« Reply #83 on: November 11, 2012, 06:12:06 PM »
ahhhh thats it... i knew something was missing there was too much space. its my caliper bracket.... i do have one, haha... thanks man... thats embarassing
Offline kidrcth
« Reply #84 on: November 11, 2012, 06:18:35 PM »
Otherwise, here is some progress...
Offline kidrcth
« Reply #85 on: November 11, 2012, 06:20:43 PM »
more
i call the jig we created the "chinese frame jig"...
