Author Topic: High Idle??  (Read 7580 times)
Offline jstfkndi
Re: High Idle??
« Reply #50 on: June 18, 2012, 05:54:14 AM »
Ok. Have a question. Got everything taken apart and replaced the brass and gaskets, cleaned the hell out of the carbs and go them back on the bike :) Now the only brass I didn't replace was the jet needle (screws weren't budging and I was afraid of stripping them). On one of the needles, I decided to try and scrub the light gunk off with a green pad. I noticed it scored the surface a bit so decided against doing the others. Would this compromising of the surface of the jet needle affect the way the bike runs ie: cool, hot, rich, lean? Can it be THAT finicky?
Re: High Idle??
« Reply #51 on: June 18, 2012, 06:45:45 AM »
Should be fine.
Offline jstfkndi
Re: High Idle??
« Reply #52 on: June 18, 2012, 07:21:07 AM »
Then I have some investigating to do :(
Re: High Idle??
« Reply #53 on: June 18, 2012, 07:44:20 AM »
whats your symptom?
Offline jstfkndi
Re: High Idle??
« Reply #54 on: June 18, 2012, 08:35:14 AM »
Number four cylinder pipe is running cooler than the other three. I checked spark and have that. Going to compression test tonight on all cylinders. It was warm, but not sizzling like the others when water was sprayed at them.
Re: High Idle??
« Reply #55 on: June 18, 2012, 08:46:26 AM »
vacuum sync your carbs after you got them back on?
Offline jstfkndi
Re: High Idle??
« Reply #56 on: June 18, 2012, 10:03:24 AM »
Not yet. I need to also do the idle/air screw mixture. That could do it?
Offline JTF
Re: High Idle??
« Reply #57 on: July 25, 2014, 11:08:06 AM »
So what happened? Did you find a reason for high idle?
I have the very same problem in my CB350F.
BR Jussi
Offline Sparked
  • Cheaper then therapy
Re: High Idle??
« Reply #58 on: April 27, 2015, 09:05:46 PM »
Double check valve clearances. I loosened the valve gaps 0.001" and the high revs when warm seem to have gone away.
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
