Author Topic: 1973 CB500 carb leaking woes.  (Read 2299 times)
Offline JamesM
« on: May 29, 2012, 05:56:40 PM »
I see there are a million carb threads on here, and didn't want to start another but I'm kind of stumped.
I just put in brand new #3 and #4 float bowl gaskets as they were leaking terribly, and after I got it all put back together... it's still leaking terribly.
Gas appears to only be coming out of the float bowls. Where do I go from here?
Thanks in advance,
-James
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline luap
  • LAWL
Re: 1973 CB500 carb leaking woes.
« Reply #1 on: May 29, 2012, 06:56:41 PM »
get the oring seated properly, lot of threads on how to keep the o ring in place
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline harisuluv
« Reply #2 on: May 29, 2012, 08:39:32 PM »
Those circular o-rings are a real pain to get in correctly.  I personally like the scotch tape method.  Holds it in place and then you get it just loose enough to slide the tape out while the gasket is still secured.
By the way, if you are having leaking issues out of your float bowl gaskets it would seem that your fuel level in the bowl might be a bit too high.  You might have to investigate a float level that is off.  I will assume that the valves are properly cutting off fuel since you did not mention anything about leaking out the drain tubes.
Offline JamesM
« Reply #3 on: May 30, 2012, 05:37:03 AM »
I used super glue in spots to keep the ring in place.
harisuluv- Thank you for the information, I'll have to check the float levels when I get it torn back down today.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline iron_worker
« Reply #4 on: May 30, 2012, 07:31:06 AM »
Also check your overflow lines. If the level is that high it should be overflowing out of the proper line not leaking around the bowl gasket.
IW
Offline luap
  • LAWL
« Reply #5 on: May 30, 2012, 10:39:34 AM »
If the oring got pinched an your looking to replace these work great just give them a little stetch an they seat perfect
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=1086
www.cb-town.com
Offline harisuluv
« Reply #6 on: May 30, 2012, 10:58:18 AM »
Superglue can work but needs to be used very sparingly.  Too much and then you don't have a gasket seal anymore.
A lot of times the overflow drains can get clogged.   Anyways, sounds like you will figure it out.
