Author Topic: How to remove footrest rubbers  (Read 2075 times)
Offline thomellis
« on: May 30, 2012, 03:17:48 PM »
So I'm looking to replace my old footrest rubbers, they're just scuffed and not looking too sharp.  I'm about to the point where I'm just going to find a way to cut them off, but I thought I'd check and see if anyone had any tips on pulling the old ones off.  For the life of me, I can't get the damn things to budge.
Thanks!
Offline Johnie
Re: How to remove footrest rubbers
« Reply #1 on: May 30, 2012, 04:30:56 PM »
There is a little hole on the outside end. Try blasting some air from your compressor in there and pulling at the same time. I have had that work to get them off. If not, you may have to cut. I have also sprayed some lubricant in the area the shaft goes through the rubber.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mrrch
« Reply #2 on: May 30, 2012, 06:58:49 PM »
I don't have a picture handy or near my bike but isn't there a bolt and plate at the end to remove first?
my build
Offline Johnie
« Reply #3 on: May 30, 2012, 07:46:03 PM »
Well, I take it he is talking about the 69-76 CB750 and there is no bolt plate on the front pegs of that bike.
Oshkosh, WI  USA
Offline tango911
« Reply #4 on: May 31, 2012, 11:55:20 AM »
the air trick for the win.   i spray some pb blaster downt he square perimeter. then blow air in the little hole on the end and pull off at the same time.  works like a charm.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline thomellis
« Reply #5 on: May 31, 2012, 12:24:55 PM »
Yeah it's a 72.
Thanks for the tips guys.  I'll give it a shot and see if I can get lucky this time!
Offline Johnie
« Reply #6 on: May 31, 2012, 03:02:20 PM »
Don't be afraid to put some lubricant down the hole too. Just be careful the air does not get it in your eyes os she will burn my friend.
Oshkosh, WI  USA
« Reply #7 on: May 31, 2012, 07:15:07 PM »
Ride it, it will fell of on its own. At least thats what my replacement rubber did :(
