Author Topic: 1978 CB750F Low Bars?  (Read 1348 times)
Offline 736cc
« on: May 31, 2012, 07:25:39 AM »
I plan on replacing the stock 1978 CB750F SS handlebars w/ superbike low bars. Anybody try that? I would guess w/ the swap the throttle cables would foul the tank at full lock, brake line needs a shorter version and clutch cable is probably too long as well. What else should I plan on? Solutions?
Offline DJ_AX
Re: 1978 CB750F Low Bars?
« Reply #1 on: May 31, 2012, 07:40:29 AM »
I put on "Euro Bars" with only a simple cable re-routing required.
The brake line does have an extra curve or two in it but it looks ok and works great!
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #2 on: May 31, 2012, 07:42:11 AM »
Same for me with Norman Hyde M bars.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
« Reply #3 on: May 31, 2012, 07:51:27 AM »
Norman Hyde M bars on my K8.
throttle cables extend forward from the controls, and then loop around between the gauges and headlamp bucket.  no binding here.  Superbike bar routing should even be easier as there is more rise.
shorter brake line was needed.  I went with stainless 31" eye to eye and its still a bit long but much less snaking than original.  28" probably would be best for these bars.  i'm sure a new line around 31-32" would fit well for the SB bars. Slingshot cycles does good work.
Offline Pat_at_APE
    • APE Race Parts
« Reply #4 on: May 31, 2012, 08:03:16 AM »
I think I've got the superbike bars on my 77 CB750F2 put on by a PO.  They are comfortable when riding at speed.
I also have the original bars (according to the PO) in the garage and they are high and wide in comparison.
Pat at APE
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: May 31, 2012, 08:05:17 AM »
+1 for Slingshot for brake lines. I run a -3.5" clutch cable on my euro bars and it's exactly the correct length. Stock throttle cable.
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
« Reply #6 on: May 31, 2012, 12:29:31 PM »
I have superbike bars on on my 78 750F. All stock length cables. I find them very comfortable. No problems with binding. No interference with the tank at full steering stops.
