So more problems cropped up. First, I decided to fab up a bracket of sorts to keep the speedometer cable out of the front wheel. I decided on a bolt to secure it to on the front fork. Turned out that bolt drained all of the fork oil out. Oops! When I put the bolt back in, it broke off, deep, without any effort!
![](http://i527.photobucket.com/albums/cc356/03rangerxlt/Cafe%20Bike/IMAG0198.jpg)
I purchased about $50 worth of tools to get it out, and ended up only using one of the drillbits from the $25 set, but it came out.
![](http://i527.photobucket.com/albums/cc356/03rangerxlt/Cafe%20Bike/IMAG0200.jpg)
I then ran into some issues with the front brake. I cleaned up the caliper, installed new braided stainless lines, and then rebuilt the master cylinder. When I went to bleed it, nothing came out of the bleed nipple. But lots of fluid came out of the master cylinder and ate the really nice paint off of that. I rebuilt the master cylinder, and it actually was able to bleed the air out. But now, it wont squeeze! So I have to mess with that.
Also, with the exhaust on, the rear brake rear-set hits the exhaust before the brake engages. So thats going to take some tweaking.
Other than that, I need to finish up the wiring and figure out the jets in the carbs. The tank needs coated, and and all of the fluids need topped off.
After that, going to have a safety check done on the bike. Keep in mind, I have never worked on a motorcycle before this project, and I have had absolutely no clue what I was doing during any of it. Hopefully soon, it will be running!
Here is what she looks like today:
![](http://i527.photobucket.com/albums/cc356/03rangerxlt/Cafe%20Bike/IMAG0158.jpg)
