Author Topic: race pistons  (Read 1999 times)
Offline Colin Tweedie
race pistons
« on: May 31, 2012, 02:10:43 PM »
Got a 500/4 engine to rebuild and tune can anybody recommend which pistons I should use ( I was told CG pistons fit ) I would also like to do some work on the crank but not sure how much to shave off any help tips greatly appreciated
Offline turboguzzi
Re: race pistons
« Reply #1 on: May 31, 2012, 04:31:10 PM »
edit as i see that you do race in scotland
go for stock pistons, head/block milled 1.6mm, pistons edge turned with a 15 degs slope to match the combustion chamber chamfer.  bump in compression will be notable, its simple and cheap to do. did 1.5 seasons like that
XL125 pistons, you will have to turn down the crowns as CR will be too high
Davies motorsports in UK were working on producing dedicated 500 race pistons last time they were seen
no easy solutions, the days that yoshimura made race pistons for the cb500/4 are long gone
« Last Edit: May 31, 2012, 09:59:00 PM by turboguzzi »
Offline Jim F
  • go baby go
Re: race pistons
« Reply #2 on: May 31, 2012, 06:22:47 PM »
CP out of California makes an excellent piston but expensive
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline specweld
Re: race pistons
« Reply #3 on: May 31, 2012, 11:52:08 PM »
S.E.P. in Kegworth will sort the crank for you Col.
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
Re: race pistons
« Reply #4 on: June 01, 2012, 02:09:04 AM »
take a look at this topic   you find olmost everything
http://forums.sohc4.net/index.php?topic=63228.0
Re: race pistons
« Reply #5 on: June 01, 2012, 04:38:49 AM »
1.6mm  seems an awful lot?  Do you have to  machine the valve pockets as well to avoid the valves and the pistons colliding.  Where can I get a race cam in UK
Offline turboguzzi
Re: race pistons
« Reply #6 on: June 01, 2012, 06:48:01 AM »
will have to check my numbers again but it was about it, 1.6-1.2 and yes, pockets were deeper also because of the megacycle 126-20 cam . if you feel uncomfortable about so much milling, then go with XL125S pistons but these will require crown lowering as well as re-pocketing...
