Author Topic: throttle cable snapped. quick fix or solution? (nyc)  (Read 6671 times)
Offline AnthonyMichael
« on: May 31, 2012, 04:11:24 PM »
the pull cable snapped on my 76 550k throttle. It's parked in the city now and I want to get it fixed right away. I called two places and they said no one will have it and they'll have to order it. Monday is when it'll get here.
I'm looking for a quick/temporary solution that can get the thing working and get it home while I wait for the proper cable to come back.
Do you know if:
A: swap the push cable and put it in place of the pull?
B: find ANY throttle cable from any bike place and use that?
C: know a place in New York City that will have that cable on hand?
Thanks!
Offline Magilla
  • My bike: 1976 CB750F
Re: throttle cable snapped. quick fix or solution? (nyc)
« Reply #1 on: May 31, 2012, 04:38:00 PM »
Not sure if it will work but. . . . . .
Swap the push cable and finagle a return spring on the carbs.  Should be good enough to get you home
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #2 on: May 31, 2012, 04:52:32 PM »
Right hand on carb arm, left hand on bars and clutch, no front brake, ride the back streets.
Offline killersoundz
« Reply #3 on: May 31, 2012, 05:01:22 PM »
I don't understand the purpose of the 'push' cable? You surely don't need it do you?
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: May 31, 2012, 05:05:43 PM »
Both cables are pull, the idle return cable is a safety thing.  Since motorcycles are inherently unsafe anyway, many don't us it.
« Reply #5 on: May 31, 2012, 05:37:05 PM »
On the 750s you can change the position of closing cable on the wheel. Some have reported doing it.
The throttle may work backward. There are no quiet backstreets in NYC.
Offline adamlwvdc36
« Reply #6 on: May 31, 2012, 06:08:23 PM »
As a TEMPORARY fix I once had this happen... what I did was... you ready for this?  put the "push" cable end on the carbs where the pull is...  Now operate your throttle backwards (roll forward to accel)  *what you do to your bike is what you do to your bike... you asked for a temporary fix... this works in a pinch but if you do this, you accept all responsibility.
This will get you home if you are stranded but it does take some time to get used to
_ADaM
Be a COWBOY, not a NERD!  youre riding an antique bad ass motorcycle for God's sake...
75 CB550 Named "Don Casper"  Don for grandpa, Casper for the guy that mentored me to riding... RIP Kenny...
Offline 736cc
« Reply #7 on: May 31, 2012, 07:15:43 PM »
973-703-4120
347-792-1151
212-300-7666      call or text for mc towing
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #8 on: May 31, 2012, 08:03:36 PM »
bring the rpms up just enough by using the throttle screw, and go home.   8)
searching for a dr350se
Offline cameron
« Reply #9 on: May 31, 2012, 08:44:34 PM »
switch the cables.
That is the quick fix to a broken throttle cable.
Incidentally,
I actually prefer riding with the cables switched. I rocked that for many years.
1976 CB550F
