Author Topic: cb750 1975K5 Cafe Racer  (Read 14825 times)
Offline Guns_Up
Re: cb750 1975K5 a bit of a brat (Now a Cafe Racer) UPDATED WITH PICS*
« Reply #25 on: February 20, 2014, 10:31:38 PM »
Well it's been about a yr since my last post, a lot has changed in the small detail side of things. Unfortunately with getting into the actual engineering courses of school (and as luck would have it only get professors that want to prove to students how well they can do it, with out actually teaching me) I've been stuck in books and dreaming about numbers rather than happily in the garage making things happen.
So here is a quick recap of the last yr.
The bike is LOUD, and I have one neighbor in-particular that thinks that calling the cops is a better way to deal with it than come and ask me to take it easy while I'm around his house. I would have no problem with that. Thankfully the cops that have come by the house are more interested in the bike than the noise  ;) and seeing their faces when I kick it over is priceless. However being the nice guy that I am I do take it easy around his house. This is just with the stock 4-into-2 pipes with the megaphones removed. I really wanted to get some Cycle X Roadster Shorty's. After awhile and saving some money I called up to Ken there and talked to him. They were out of Stainless Steal pipes and were on back order because they were getting a new pipe bender and needed custom dies made. BUT he had some Raw steel in stock and cut me a good deal on them so I snagged them up. and when they came in they looked AWESOME.
Some fitting was required to the ports and I had to get new crush washers for a good seal. but that was an easy fix, thanks to Dime City Cycle.
Now because I lowered the bike, and had to cut the kick stand to achieve the proper lean I had to trim the ends of the pipes. On the outside left side (kickstand side) I had to cut the "kickout" of the pipe completely off, but only after hours of trying to find a way around this. The major problem was when the kick stand was raised it was hitting the "kickout" leaving it inches away from the ground. The pipes them selves also kind of point down as you can see from the following pictures. I went to the local muffler shop and the old Marine there told me that I could "basically" heat treat these pipes by coating them with Transmax and them getting them hot to the point wear the metal absorbs the liquid (that is the smoking you'll see in the pictures) I then wrapped them and took them for a ride.
While I was out on the ride I leaned into a hard right turn and the right "kickout" hit the ground and kicked me and the bike upright (not cool) so after being completely frustrated with them I decided to change back to my old pipes. Keep in mind that the pipes are awesome if the bike was at the stock height with stock kickstand length.
after they hit the ground the wraps started unwrapping which was gettin hazardous when it was getting caught up in the rear tire.
See how the pipes shoot down on the underside, Also note the new headlight and bucket.
With the old stock Honda head light the beam was no where near that of a modern bike and I didn't feel safe with how dim it was, so after doing some research I came across a headlight and bucket. While I was at it I wanted to replace the acewell spedo I have, so I got it with the 2.5" and I love it.
This was the one -->     http://www.cb750cafe.com/products-page/lighting-electrical-gauges/universal-headlight-with-speedo/
Only ran into one problem with it that I need to contact Carpy about. I was a a straight road cruising around 80 and wanted to see what the could really do with the carbs re-jeted and adjusted for the open 4 into 2 pipes. I shifted up and went up to 110 when the speedo went back down to 0. I bought the bike home and pulled the speedo cable out do it still had its shape so I'm thinking that it might have stripped an internal gear when it was accelerated so quickly.
As for paint  >:( I stripped the bike and gave it to a buddy of mine (unfortunately in the middle of the summer) and he said it would take 2 weeks cause he was backed up. A month later I called him and he said it would take 2 more weeks. So 6 total weeks later he said two more weeks, so I went down and I picked it up, so its still not painted.
I ran into a problem with the electrical, not knowing what it was and digging and chassing wires and doing research I finally found it! My key switch bought the farm, so I went to Mark Paris' website and picked up one of these --> http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=49
with this installed, I went wrong some where and the bike now has constant current running through it, so without unplugging a ground it drains the battery. I also picked up a Transistorized Ignition for Dual Points  --->  http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=32    I haven't installed this yet though.
Future plans for the bike is as follows.
- Fix my front break squeal
         - I want to replace the rotor with an EBC 320mm rotor
         - replace the EBC pads I have for Ferodo pads
and see how far this gets me before it starts again
-I'd like to try my hand at upgrading the electrical system, to modern/minimal electronics. This will definitely be the most time consuming and I may wait till next winter to install it and give it a try.
Take it easy ya'll and for those of you lucky enough to be riding right now, ride safe.
Tony
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #26 on: February 21, 2014, 07:39:06 PM »
Thanks for the update Tony.
I really like your color combination of that sweet looking motor,black wheels and original tank. Leather in a number of places is a very nice touch also.
Yes you'll need to get some clamps on that pipe wrap before it starts feeding into the rear wheel again;very concerning.  Glad to see you've got your priorities in order with school. I enjoyed reading your whole thread.Bike will turn out just fine when the time is right.
GL!
Mike
Offline Guns_Up
« Reply #27 on: March 10, 2014, 08:53:14 PM »
Thanks Mike,
I took the time to sit down and look through my notes on the bike and get in contact with Mark Paris (Hondaman) about some of my issues. I sat down and read some of his book to, mostly the electrical chapter I skimmed thru because I can not stand the stuff, but I actually read it. (If you dont have the book and plan to do a rebuild I would put it at priority number one before you even start it will save you time and a lot of headaches)
My start button doesn't work at all, so I read how to rebuild them and also ordered a "Start Button Relay saver kit" and plan to install this within the next two weeks (after painting the GF's room of course :/ ) and with further inspection on my electrical I found that someone along the way had replaced one of the original blades in the white connector with a modern (shorter) blade, causing an arc and starting to melt my connector on my new wiring harness. So back to Mr. Paris I went again to order a blade fuse kit. Easy, drop in and go.
I also reset my speedometer back to "0" so hopefully this works, I also inspected the gear inside of it. The cable running thru the speedo cable is square (at least the part that connects into the speedo) and my gear inside the speedo has been striped to a circle, I plan to remedy this.
Also in the book I read how to rebuild the starter solenoid, so this will be added on to the list of to do's.
I also ordered some new goodies for the bike, on the small side. A new clutch lever. I had painted mine to see if I wanted to keep them painted or stock silver but when I replaced my MC it can with a new silver lever and figured I'd actually get a matching clutch lever.
I also ordered some handle bar clamps from Carpy (cb750cafe) to replace my old light bar that I don't even have hooked up anymore.
also on the list was a set of Posh Amal Style grips in the gum color. the leather ones I made up are pretty thick and shift around so I decided I was done with them. plus I have a bar end mirror from Dime City Cycles I need to install.
And last but not least some new fork boots. The ones that I bought from Dime City Cycles about a yr and a half ago have already torn  >:( I have no idea how the F*** that happened considering stock boots that are 40+ years old are still good, so I went with tried and true, and bought some OEM boots off ebay in the original package just to be safe.
As far as my brake squeal goes this is what Mr. Paris told me:
"The squeal: it is the EBC pads, period. Every EBC pad I've ever used (or saw after 500 miles) squeals, a LOT. Try to find some other pads, like Fedoro, or old OEM Honda (even used, they last about 40k miles), or some of the racing pads around. I got some genuine sintered pads from M3 Racing last year, my first choice for these discs. They have bits of bronze in them, which prevents squeal and cleans the disc."
Now I've looked on ebay and found some OEM's for $90 but I also haven't contacted M3 yet, their website doesn't have them listed on there at this moment.
Also I get a back fire every so often, I though that it was a jetting issue (I'm Running slow jet #40 and Main jet #110 with Denso X24ES-U spark Plugs gaped at 0.045" with K&N stock air box/filter) How ever I was then told this:
" The occasional backfire can come from a host of things: the short list includes fouled sparkplugs (blackened), high-resistance sparkplug cap(s), or uneven resistance on one coil, a coil that is dying (check the primary resistance, should be 4.4-4.7 ohms), one float bowl too high or too low as compared to the others, a partially clogged emulsifier tube or air screw not set the same as the others, ignition timing not the same on the points (both must be on "F" at idle, and advance the same, and 2-3 side not jittering under a timing light), or a leaking carb hose, usually at the head.
( I could probably list another paragraph, but these are the most common things I see...)"
I'm currently running 5k Ohm NGK (SB05F & XB05F) Plug caps. I know Ngk makes a 10 Ohm Resistance cap and I'm on the hunt for those now too.
"The OEM plug caps from 1968 thru 1974 were 7.5k ohms, and they went up to 10k ohms starting in 1975. This was done for 2 reasons: first, it reduced emissions by stretching out the spark a little more, which lights a wider flamefront in the chamber. These swirl-charge engines have the gases whipping past the sparkplug at nearly the speed of sound by 5000 RPM. The longer the spark, the bigger the burn front, and longer the push on the piston."
I also got hired on at Mossberg as a Manufacturing Engineer Intern recently so I'm hoping that I will be able to finish these pressing issues and move forward with the the rest of the bike asap.
Take care,
Tony
Offline Guns_Up
Re: cb750 1975K5 Cafe Racer UPDATE
« Reply #28 on: March 23, 2014, 06:02:20 PM »
Ok everyone I had a chance to sit down and actually get some of the things done that were on my list of to do's on the bike.
I got everything that I have ordered in, from left to right: NOS Honda fork boots I got from ebay, next are the Posh Amal Style grips in the gum color I ordered from revival cycles, Then HandaMan's Transistorized Ignition for Dual Points, and from carpy a new clutch lever and set of polished handle bar clamps also my old exhaust clamps are pictured.
Putting on the clutch lever and handle bar clamps was a quick change over and I forgot to take a picture of them on, but with the old light bar off it cleaned the look of the bike up a lot.
I then put the grips on. They were shorter than the grips that I had initially made for it, so I had to lengthen the whole that the wires feed through along with cut my throttle tube. I tried to do this quickly and eyeballed the length I needed my throttle tube, it is just a little to long and rubs on the handle bar switches causing it to not have the spring back return that it had prior. this was a MASSIVE pain in my ass trying to fix cause of the tight fit. but the grips are so comfy and well worth it.
next was my fuse holder, around Christmas time I was have trouble with the bikes electrical. After some searching I found that the PO had done some "work" on the fuse hold clip. One of the blades was replaced with a short blade connector causing a bad connection as I said before.
This is HondaMan's replacement,
Install was super easy, just screw it in (I had to get a few washers as spacers for a tight fit) and plug it in:
As you can see it came with a dust cover and replacement fuses, its awesome!
Moving onto the ignition, I was nervous about this because of all the wires it looked a little daunting.
(my dog felt it necessary to see what I was doing with his muddy paws  ::) )
I found out that with my seat configuration that I can mount it on its side in the tool try. I did this with some good ole JB Weld and a socket to keep it tight to one side. you'll also note the Key Switch saver mounted behind it.
The easiest way I found to do this was to un-bolt the oil tank and pull it out of the way to allow me access to the wires I needed to reach:
I wrapped my ground in some heat shrink tubing as a "heat sheild" as it rund along side the wires coming from the point under the engine and into the the points housing:
For the ground you unscrew one of the condensers and screw the ground wire back into it:
The rest of the connections were just following along with the instructions and plugging in the wires. I decided to keep all the extra wire, wrap it in heat shrink tubing to keep them together and tucked it all away:
This is an easy install, and When I was all done I pulled the bike out of the garage and kicked it over. It took a few times then turned over. It was running a little rough so I shut her off to inspect the problem. I had unplugged a spark plug cap to measure the resistance and didn't plug it back in. with that being said this system is so strong that it turned the bike over with a few kicks on only three cylinders! Once I plugged in the plug cap she kicked over the first time and ran like a dream.
next on the list was finding out what was up with my key switch saver, I would have to unplug the ground wire every time I shut off the bike to save the bike from draining its battery. After looking into the problem I had the system wired wrong and had to cut the wire where the green arrow indicates and this fixed my problem.
I had intended to fix my start button and install HondaMan's start button saver kit. Well after inspection, the PO had "fixed" the start button with a half ass soldering job, and I didn't have time to actually fix the problem and install the kit.
(I know there is a spelling error there, I'm better with math than with spelling and grammar)
My yr old fork boots from Dime City Cycles  >:( cheap quality, I DO NOT recommend these!
Also I never put this up when I got them in but my tank, seat and headlight decals for when I paint it. I plan on a cream base color, with a bold gloss black stripe down the center, bordered by the maroon pin strips. The Honda-Norton is going on the tank, the 750's on the side covers and the exiled 8/Afghanistan on either side of the seat cowl. This was all done by myhondas
Also got my new custom plate in  ;D
It hasn't been registered since 98' or something like that, so a cop had to come check out the bike/vin # turns out I did my basic riders course with the cop, we spent about an hr just talking about what all has been done to the bike. The joys of living in a small town!
I also took a trip to the Barber museum and found my dream bike in person.... now I have to figure out how to get it out of there!
OH as for the speedo after I reset it and let it sit for awhile it crept up to 40 MPH, so that thing is dead. I still haven't contacted Carpy about it but its still there. and I didn't get the chance to change out the fork boots. when I get the new OEM brake pads I'll do all that.
Tony
« Last Edit: March 23, 2014, 07:12:06 PM by Guns_Up »
Offline greenjeans
  • 1972 CB750K2
« Reply #29 on: March 24, 2014, 01:22:29 PM »
Lookin good.   Don't know how you were able to pick only one dream bike out of the Barber collection  ;)
Offline Guns_Up
« Reply #30 on: March 25, 2014, 07:42:34 PM »
Thank greenjeans! I don't think I've ever been as a happy as the day I spent at barber. that place is UNREAL, I would give up a lot just to be a security guard inside the museum! and for some reason I have a soft spot for the Indians, abut the 29' scout is my all time favorite. One day when I hit the lottery I'm going to buy one and restore it, and buy a 35' kiwi Indian chieftain !
Offline Roach Carver
« Reply #31 on: March 26, 2014, 02:32:35 PM »
Not to derail the thread but I want to Barber in 2012 and last year as well. The first year was incredible, the second year was just kind of so so. It is getting so crowded and less diverse (sea of Harleys)  that I think I will pass this year.
Offline grcamna2
« Reply #32 on: April 05, 2014, 04:51:47 PM »
Hi Tony  :),
I came across your Cafe project build today and enjoyed looking at the progress you're making on it;isn't electrical a real pain / especially 35+ year old corroded and abused wires and connections. I Love that HondaMan transistorized ignition box,how about you? it makes the bike run great. I like your CL350 too  8)
        Please say Hello to your Mom & Dad & younger brother OK ?!,  ;)
        Bill H.
Offline Guns_Up
« Reply #33 on: April 10, 2014, 05:06:57 PM »
Bill,
I love all the hondaman products they are the best parts I've purchased yet. The family says hey and we all hope that you are doing well.
as for an update on whats going on I bought some new brake pads, I broke down and shelled out the money for OEM Honda brake pads off of ebay. I also picked up a drilled rotor from shinyribs on the parts for sale forum on here and it looks great.
Just from the appearance the OEM brake pads look far superior than the sh!tty EBC ones that I have on there now that squeal pretty good. I also found the resistor type spark plugs from denso: Denso (4101) X24ESR-U. Hopefully this will take care of my slight back fire issue and improve the performance.
and I also booked a box truck from Penske ($350 from GA to CT)) to move the bike, my tools, and all the extra parts up to CT.
Hope you all are enjoying the weather!
Tony
PS: Roach Carver, I have a feeling that the see of Harley's will never cease. There was to big of a gap where they had little to no substantial competition from other American motorcycle manufacturers. And ultimately I also believe that this caused their engineers to get lazy... it happens. But when I get the money I plan on buying myself an Indian or a Kiwi Indian 1939 Chieftain!
Offline grcamna2
« Reply #34 on: April 10, 2014, 06:52:03 PM »
Tony,
Where do you source ND Hot U plugs ? I've been looking for a pair of resistor type W24ES-U's (w/ the 'R') from a local Auto supply house and no one will sell me any.I found one pair on Ebay but I'd like to get a few more locally if possible.
PS. Please thank your Mom and Dad for me for traveling up to Toccoa 2 years ago and dropping off that Volvo transmission,I was on a phone call when they showed up trying to get a part from a 'motor mouth' guy who eventually couldn't help me but I didn't know it at the time...  That was nice of them to do that and I WANTED to speak w/ them and thank them.  :(
I sold the transmission to a man in Athens 5 months later for $500.  :)
Offline grcamna2
« Reply #35 on: April 10, 2014, 06:56:12 PM »
You sure are doing a NICE restoration job on your CB750  ;)
Offline riverfever
« Reply #36 on: April 10, 2014, 07:21:55 PM »
Bike looks amazing.
Offline MikeKato
  • Milwaukee WI
« Reply #37 on: April 13, 2014, 06:00:42 PM »
Hi Tony  :),
grcamna2 : you can look far and wide and you'll be hardpressed to find another that can document a build as Mr. Tony.  That bike will be one that he and his father will remembers as a turning point in his wonderful,eventful, life.
        Bill H.
Offline grcamna2
« Reply #38 on: April 13, 2014, 06:31:04 PM »
Hi Tony  :),
        Bill H.
I seriously respect what Tony and his Dad are doing as a Team to make that 750 just what he wants.
Tony, I understood that's what your family wanted to do as far as healing up after coming home from the war back when I came to visit you in GA. in May 2012.
You and your Dad have a special chemistry for that bike and it shows in your attention to detail in all the work you've both done on this project thread.  ;)
Offline Guns_Up
« Reply #39 on: April 27, 2014, 07:46:34 AM »
Bill, I couldn't find the resistor plugs anywhere local either, after a few days of searching I found 1) I realized that the designation Handaman gave to me had the R in the wrong place (actually  Denso (4101) X24ESR-U for the 750's) 2) That Amazon had some but were on back order 3) I picked them up from a place called rockauto.com Now with all that being said, I was a little skeptical because of the designation (I can only think that they changes it and Hondaman still uses the old designation) and also I had never heard of rockauto.com before, So I only bought 4 and it turns out that they were the proper size for the 750 and they shipped incredibly fast.
Thanks for the kind words guys, my dad is a great guy and always seems to know what to do in any sort of situation.
Hope ya'll are enjoying the nice riding weather
Tony
Offline grcamna2
« Reply #40 on: April 27, 2014, 08:51:53 AM »
Hey Tony,
I got it, rockauto.com,alright  Hey I'm still waiting for some WARM riding weather like YOU have down there,what's it like in the 70's ?  8)
Offline Pinkley
« Reply #41 on: April 27, 2014, 09:13:39 PM »
The bike looks and sounds great! Reading and looking over your thread gives me the motivation to get mine done. Ive been working on it since I picked it up in December of 2012. It has been a headache and a joy building it thus far. It was a nightmare redoing all the electrical. When I got it all the original wires had been hacked and jerry rigged throughout the entire bike. It was a lot of weight off of my shoulders when I finally got it all redone. Im down to a bunch of little things to make it road ready.
Keep on doing your thing buddy!  ;D
Offline Guns_Up
« Reply #42 on: June 10, 2014, 07:19:03 PM »
Hey everybody, figured I put up a quick update while I had the time. About a month ago I took a road trip with my buddy to bring the bike up to CT from GA. I rented a (way to big) penske truck, how ever it was the cheapest that I found.
we started off slow by hitting some traffic in Atlanta, so we did the only natural thing some one could do in when they hit traffic... pulled off the highway and stopped at the Bass Pro Shop. Then got back on the road and drove all the way up to North Carolina until we stopped at a new Cabella's, grabbed a bite to eat and hit the road again until we hit Righmond around 4 am, stopped a very "run down," to put it nicely, hotel. met up with a buddy of mine who recently got stationed at MCB Quantico. Went to the Marine Corps Museum, which was amazing to see being a Marine.
This was the flag flown on Iwo Jima that everyone sees in Joe Rosenthals picture
1st Sgt Dan Daly's 2 medals of honor that he received Daly is said to have yelled, "Come on, you sons of #$%*es, do you want to live forever?" to the men in his company prior to charging the Germans during the Battle of Belleau Wood in World War I.
once we left the Stafford, VA area we sat in DC traffic for a few hrs, and we decided to stop in DC at Arlington to see a buddy, the Smithsonian and just walk around the city.
This is where one of my Marines brother stays, he died in Ramad, Iraq in 2005, I could not leave with out stopping by.
We ended up getting locked into Arlington National Cemetery, fortunately for us there was a Navy Sr. Chief who was locked out with his car inside. We were able to get a hold of the MP on duty. Because of the size of the truck we had to drive through the cemetery following the MP and the Sr. Chief. It was pretty amazing to be able to do that and not get in any sort of trouble.
the next day we walked and the capitol, went to the museums and saw some of the buildings and went oooowww and aaaahhhh. We then hit the road and decided to stop in Philly to get a real cheese steak. We decided to stop at Pat's King of Steaks, and before i could hand over the money the sandwich was in front of me, and man was it GOOD!
and then finally we made it to CT at 4 am again, I had to be at work at 7 so I just stayed up through it, luckily that day was easy and consisted of shooting shotguns all day.
I did some work on the bike this past weekend, changed out the front disc with the one the I purchased from forum member shineyribs, Eric did a great job with it.
I changed out the EBC brake pads that I had on there and with the OEM's that I had picked up. It took me a bit to bleed the brakes but once I got it to a point where there were no bubbles in the line, I took a rubber band and secured the brake lever in the engaged position and about 2 hrs later it was all done with out my help. This did take away the squeal from just rolling the bike but I still have a squeal when I apply the brake... I'm going to take any glaze off this weekend and that should stop the problem.
also I replaced the fork gaitors with OEM ones... Man the quality is unmatched compared to what I had on there from DCC. Unfortunately the top was designed to be used with the head light ears... so its to the drawing board with that fix. In the mean time I summoned my inner redneck and pulled the gaitors over the bolts so that they wont sag until i figure something out with the ears.
My throttle cables are super dry! I took it out for a 3 hr ride on Sunday. For the highway it was great, but in town it was brutal on the wrist, made it look like I was completely new at riding. I picked up some AGS kable-ease to see how it works on the cables.
other than that, I'm thinking about putting on either a shorty muffler or some baffles on, living in a neighborhood with little kids, its not cool to wake everybody up at 6am when I go to work.
hopefully now that the bike is up here I'll be working on it and posting more up.
have a good one guys.
Tony
Offline grcamna2
« Reply #43 on: June 10, 2014, 09:06:19 PM »
Thanks for posting all of that Tony
Offline MikeKato
  • Milwaukee WI
« Reply #44 on: June 11, 2014, 06:22:47 PM »
always fun reading this thread.
Offline Ford40
« Reply #45 on: June 13, 2014, 04:39:23 PM »
Offline calj737
  • I refuse...
« Reply #46 on: June 13, 2014, 05:39:29 PM »
I run them on my 550-
Offline Guns_Up
« Reply #47 on: June 14, 2014, 06:02:15 PM »
You could try using these on your build http://jokermachine.com/products/cafe-racer/honda-cb750-parts/cb750-fork-boot-collars.html
I really like those, they look pretty slick, I think that is what I will be going with. After all the self convincing I didn't want to put on the stock ears again that is for sure
Cal that 550 looks great man, I really like what you did with the electrical. I'm kicking around how I want to redo mine for a "hidden" look.
I'm also working on drawing up some solid models to work off of for a flat oil tank to open up the triangle under the seat, as well as a new seat that can utilize the existing hinges, when I have something closer to being set in stone I'll post up some pics of them.
Tony
Offline brandEn
« Reply #48 on: June 14, 2014, 06:11:38 PM »
Welcome back brother, I am still following along looking forward to some updates.
Offline Guns_Up
« Reply #49 on: June 14, 2014, 09:11:09 PM »
Thanks Branden, hopefully I can get a lot done in the following months.
for the time being I just drew up a very quick sketch of what I had in mind for the oil tank.... and I'm just now noticing that my tabs are off center  >:(
per this drawing it is 2in. wide, made of 12 ga sheet metal and fuzzy math tells me that it will be roughly 3.3 quarts. I plan to use the stock cap as well as the throat. But better decisions will be made with sleep and when I'm not just trying to get ideas on paper
Tony
« Last Edit: June 14, 2014, 09:15:13 PM by Guns_Up »
