Author Topic: '81 650-- What carbs should I be looking for?  (Read 858 times)
Offline cgswss
« on: June 02, 2012, 06:10:08 PM »
OK- I did the whole overhaul the carbs deal.  pain in the A.  I have started looking for '82 carbs to get the screw in low speed jets.  I figure these would be a easy bolt on.  However, from time to time I see posts saying well you should get a set of such in such carbs,  Normal they are an id number- nothing to say what yrs/bike they would be off.  When I shop on e-bay the carbs are normally refuted to by a model and year.
SO...  as long as I'm looking to upgrade my carbs what would you recommend what year/model would they come from, and if you know, what would be required to mount them on my 81 650 custom?
Thanks!
Offline fmctm1sw
Re: '81 650-- What carbs should I be looking for?
« Reply #1 on: June 02, 2012, 06:53:08 PM »
If you're going to upgrade, I'd be interested in the '81 CV carbs...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline cgswss
« Reply #2 on: June 02, 2012, 07:21:46 PM »
I pm someone that has a set of '82 bodies but no insides.  I thinking that I could use my insides in those bodies and just buy the extra jet, but I don't know that will work.  but if I get a complete set of '82s I'll get back to you
Offline fmctm1sw
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline trueblue
« Reply #4 on: June 08, 2012, 06:03:33 AM »
http://forums.sohc4.net/index.php?topic=40287.0
Check these out, gives you some more, easier to get options.
1979 CB650Z
Offline tomkimberly
« Reply #5 on: June 08, 2012, 03:51:04 PM »
You want the VB44 B or VB44 C carbs if you want the screw in slow jets. Look on the boss at the top right front (as facing the front of the bike) for the ID stamp.
Tom
