Author Topic: RC distributor bevel drive/ Can anybody make One?  (Read 33205 times)
Offline cavebear
« on: June 03, 2012, 12:30:57 pm »
There seems to be a need  for the CB750 crankshaft  bevel drive gear. Can anybody fabricate one or more replacements or know who could?
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Offline BLUE71TURBO
Re: RC distributor bevel drive/ Can anybody make One?
« Reply #1 on: June 03, 2012, 01:44:36 pm »
 Is the gear for the cb750 the same as the one for the KZ1000 ?   I know the timing marks will be different but is it overall the same ?
                 Here is a picture of one i have that came out of a R.C. angle drive for a KZ1000.......
« Reply #2 on: June 03, 2012, 02:02:04 pm »
Maybe you can use a standard gear and adapt it to the end of the crank?
http://www.mcmaster.com/#standard-gears/=htk2de
« Reply #3 on: June 03, 2012, 02:12:28 pm »
 I think the timing marks are on the flate attached to it. I agree with Scottly that buying a stock (off the shelf gear) if one can be found can then be attached to the rest that you would have to make up..
 Setting up to cut a gear, is pricey, so is low volume production..
Offline cavebear
« Reply #4 on: June 03, 2012, 02:17:51 pm »
There's the problem. The gear for the 2 distributors would have to be compared side by side
« Reply #5 on: June 03, 2012, 02:37:28 pm »
 DP can probably be determined with a pitch guage,   count the number of starts, dia , etc...
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: June 03, 2012, 08:37:51 pm »
I got one for a 750.Bill
BentON Racing Website
BentON Racing Facebook
Offline racerx95
« Reply #7 on: June 04, 2012, 08:37:07 am »
i really need one of those. thats the only part missing for my rc mag setup.
Offline BLUE71TURBO
« Reply #8 on: June 04, 2012, 02:48:13 pm »
 I know for a fact that there's quite a few units out there that need this gear part... Honda and Kawi alike.  I've seen alot of the angle drives sold on ebay without this special gear. I know of a shop that has a very special CNC with two very knowledgable guys.  One of them made his own special 5 speed manual transmission !   Gears and cases !   :o 8)    The only problem's are what will the startup cost be and will there be enough demand and what is someone willing to pay for it ?    ???
Offline BLUE71TURBO
« Reply #9 on: June 04, 2012, 05:29:30 pm »
                     The picture of the gear.  The other gear inside of the housing is made with a shaft with an offset slot on the top to drive the distributor/ magneto. Here is a picture of the backside of a cb750 R.C. angle drive unit with the crank drive gear .
    As you can see the timing mark disc is spot welded on the shaft. Look below the top finger.  Maybe that means the main shaft gear is universal and different timing disc's are attached as per application.  Maybe ???
« Last Edit: September 07, 2014, 01:09:12 am by BLUE71TURBO »
Offline BLUE71TURBO
« Reply #10 on: June 04, 2012, 05:37:25 pm »
                  Bottom line, what would ya be willing to pay for that piece. ???
Offline BLUE71TURBO
« Reply #11 on: June 04, 2012, 05:40:51 pm »
  I guess i'm gonna have to dig my setup out of the mine and dust it off and perform surgery.   ;)
Offline racerx95
« Reply #12 on: June 04, 2012, 05:46:26 pm »
I would pay 100 bucks. Maybe rc jr could shed some light on this subject.
Offline jaguar
« Reply #13 on: June 08, 2012, 08:15:38 am »
Blue the unit that you have that attaches to the crank is all one piece?
The drive gear that I have can be removed from the mount.  This might make things easier as the mount could be made on a lathe with out much effort.  It really is the heli gear that is the pain.  I dont really know how to measure the gear to cross it agains others.  Im more then willing to help make a pattern
« Reply #14 on: June 08, 2012, 09:04:23 am »
 Use a pitch guage  and count the number of starts...places that sell stock gears have that stuff.. power transmission places that carry chain, bearings, etc...
 They are made by vendors like BOSTON GEAR, maybe BROWNING.. and others..
 If you want them made short run, & I am not talking 2 pcs, bring Hundreds per unit.. Like I said it can probably be fastened to the other part..
 Meanwhile anyone want to sell a unit missing that gear ?...let me know..
Offline BLUE71TURBO
« Reply #15 on: June 08, 2012, 05:00:16 pm »
               Jag,  I probably miss quoted as it's been a long time since i have had that piece in my hand.  Like i said earlier i need to dig mine out and take it all apart.  It would be nice to be able to compare the Honda pieces to the Kawi pieces.   ;)
Offline BLUE71TURBO
« Reply #16 on: June 08, 2012, 06:45:22 pm »
Yep, yer right.   ;)   I just found my Kawi setup and the gear is pressed on with a keyway.  Damn that little piece is heavy.   :o
           Here are some measurements i took of my piece :
             Over all height..... 2.394 inches
             Width of shaft " Before taper " ..... 1.189 inches
             Height of gear.....  .651  inches
             Width of gear......  1.132 inches
             Width of timing mark disc....  2.997 inches ( 3 inches  ::)  )
             Width of hole on backside ( fits onto crankshaft end ) .....   .971 inches
             Depth of hole on backside......  .424 inches
  If anyone can,  measure your Honda piece to see if they are close.  I doubt the end of the CB crank is the same as a KZ .    ???
    • BentON Racing
« Reply #17 on: June 08, 2012, 07:14:16 pm »
 ;D Cavebear,heres your pics! ;)Came off my brother's RC836 Arlen Ness frame CB750! ;D 8)
3 pcs + key.
Somebody can/will do it....I know$$$$$$
It's just a little pc.! ::)
Goes with this.
Another shot.
It goes in there!
Mallory Pt # was a 640A,Volks or Volvo,they spun opposite,but thats where dist came from.
The setup! 8)
Well,if I can muster the energy I'll measure it.Tonight or tomorrow. ::) Cavebear,PM me.Bill
« Last Edit: June 08, 2012, 07:20:36 pm by Bill/BentON Racing »
« Reply #18 on: June 08, 2012, 09:01:41 pm »
I'd bet a cyber-beer that the drive gear that mounts to the crank is exactly the same for both the Kawi and the Honda. ;D I bet another cyber-beer that the gear is from some common distributor, and modified. How many teeth on a Chevy gear? Ford? Bill's has 11 teeth...
    • BentON Racing
« Reply #19 on: June 08, 2012, 09:05:22 pm »
How many on a Volvo/Volks? The plot thickens! ;D Bill
« Reply #20 on: June 08, 2012, 09:16:16 pm »
Volks doesn't have a gear on the dist., neither does Chrysler...
Offline BLUE71TURBO
« Reply #21 on: June 09, 2012, 12:17:33 am »
 Damn !  After seeing Bill's pictures, the honda piece is way different than the Kawi one that i have.  Although the gear looks to be the same.   ;)  The kawi gear has 11 teeth also.   :)
« Last Edit: June 09, 2012, 12:20:41 am by BLUE71TURBO »
« Reply #22 on: June 09, 2012, 12:55:03 am »
Ooh, I'll have to check out the RC dizzy that Bill (Bellcow) sent me! ;D
Offline johno
« Reply #23 on: June 09, 2012, 01:31:55 am »
Cave Bear,
when you say there is a need for these drive gears does that mean you contacted mallory and they couldnt help you ???
Mallory  have been a long time reliable company ... www.malloryperformance.com  also their web site has a motorcycle section.  they advertise their phone number on their web site.
Cheers Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline cavebear
« Reply #24 on: June 09, 2012, 06:33:43 am »
I'm sure the gear can be sourced. The rest of it has to be made
