I started putting my 1971 sl175 back together after the cam chain broke now im having a rough time getting the cam timing set up right
on the camshaft i see a circle stamped on the gear and a white paint mark on the shaft that lines up with the mark on the gears the problem is i cant find what these marks line up with also im lining up the pointer on the crank whith the "T" mark on the flywheel is this correct
