Author Topic: TORO TORO TORO Sprinklers, inground ?  (Read 538 times)
« on: June 03, 2012, 05:20:22 PM »
 Got a question;
 Got a STUCK zone..turning solenoid top does not help.. just stays on. Anyway to disable without cutting wires? Have not tried opening valve up, but if it has debris, I would think flow would be reduced.
Any ideas?
Re: TORO TORO TORO Sprinklers, inground ?
« Reply #1 on: June 05, 2012, 08:22:25 AM »
I'm not a toro guy but I'm thinking nelson and rainbird have a diaphram type solenoid, there is a little bleed hole under the plunger that allows pressure to bleed into the back side of the diaphram and push it closed. the orifice can get a piece of rust or some other form of grit in it.
