Author Topic: Conti Road Attack Classic race tyres  (Read 20356 times)
Offline johno
Re: Conti Road Attack Classic race tyres
« Reply #25 on: July 22, 2012, 03:36:28 PM »
 :) Thanks Turbo,     ............. On your avatar thing do da it says Milan !  I usually go there for a couple of weeks  on business  around late Nov early Dec   When it gets closer I,ll let you know just in case.
ciao Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline turboguzzi
« Reply #26 on: July 23, 2012, 04:28:57 AM »
you're welcome!
Offline freedomgli
« Reply #27 on: January 29, 2013, 08:36:42 AM »
http://www.conti-online.com/generator/www/de/en/continental/motorcycle/themes/motorcycletires/race/contiroadattack_2_cr/contiroadattack_2_cr_de.html
Buff Harsh @ Todd Henning Racing is now offering these race tires at special pricing now until the start of the race season.  I'm thinking about giving them a go.
Offline turboguzzi
« Reply #28 on: January 29, 2013, 10:23:40 AM »
word of warning here after seeing some guys running them in italy last year
these conti radials like wider rims than the similar sized bias dunlop/avon. The 3" recommendation for the 130 rear is a very tight fit.
Offline freedomgli
« Reply #29 on: February 19, 2013, 12:22:32 PM »
I've decided to run Continental's new ContiRoadAttack 2 CR radial race tire for classic bikes.  I'm fitting the 100/90-18 to WM3 rims front and rear.  My supplier recommended using Michelin inner tubes but a quick Google search indicated inner tubes may be a safety issue with some radial tires.  I see Bridgestone offers an inner tube marketed for use with radial tires but not in the size I need.  A press release from Continental on the new ContiRoadAttack 2 CR tire says, "All are tubeless but can be fitted with an inner tube when used on tube type wheel rims."  Therefore I must assume it's OK to use a regular inner tube such as Continental E18 or Michelin 18 MF TR4?
« Reply #30 on: February 19, 2013, 12:45:01 PM »
If ever i am unsure i send the company in question an email and get it from the horses mouth. Lots of guys racing with these tires with spoked wheels so i assume that tubes work with these tires, i am going to use them as well... ;)
Offline freedomgli
« Reply #31 on: February 19, 2013, 01:18:43 PM »
Yeah, I sent an e-mail to Continental Tire and instead of answering my question they simply replied with a telephone number to call.  It just rings and rings.  No one answers.  I suppose their lawyers don't want them to put anything in writing!
Offline freedomgli
« Reply #32 on: February 22, 2013, 07:28:28 AM »
I got in touch with someone from Continental Tire and they said it's fine to run a regular inner tube of the appropriate size inside the ContiRoadAttack 2 CR radial race tire for classic bikes.  They also said that there is no such thing as a radial tire inner tube and if another tire manufacturer sells a radial inner tube it's just marketing hype.  Go figure.
I know it's hotly debated on the various forums (BMW motorcycle, classic British car, hot rod, etc.) but I suspect tire makers advising against inner tubes for radial tires are being cautious due to product liability.  I think the actual usage factors and corresponding dynamic mechanics related to a radial motorcycle tire are different than an automotive radial tire.  I also think that if you run a good tube, change it every time you change the tire, install the tire properly, use a good rim strip and run proper inflation pressures you should be fine.
See also
http://www.vtxoa.com/forums/showthread.php?118871-Radial-tire-and-Tube-discussion
Offline freedomgli
« Reply #33 on: February 22, 2013, 07:43:53 AM »
I also wanted to note that when I called Continental Tire they confirmed what THR had previously reported to me which is that if you live in the USA and have recently purchased ContiRoadAttack2 tires in a classic racing size through authorized distribution channels then the tires are true race tires with the CR racing compound regardless of the labeling or the presence of a DOT code on the sidewall.
Apparently, Conti used existing ContiRoadAttack2 molds to make their first batches of race CR compound tires and they are in the process of updating their molds and labeling so that in the future all CR compound tires will be explicitly labeled as such to avoid confusion.  The ContiRoadAttack2 sport touring tire is available in Europe in some classic bike sizes but it was never available in the USA in classic bike sizes.
« Reply #34 on: February 26, 2013, 10:59:52 PM »
Just to clear up something  here, the conti road attack CR {classic racing} are road legal tires also, its now up on continentals UK site....
Radial High Performance Classic Racing Tyres:
Race Performance for the Road and Track
http://www.conti-bike.co.uk/default.asp?spid=57
Offline SoyBoySigh
« Reply #35 on: March 25, 2016, 02:42:17 AM »
Dholda Honda CB1100R with Conti Road Attack 2 CR , winner of the 4 hours of Spa endurance classics.
http://www.dholda-classics.be/bikes.php
I find some VERY VERY interesting innovations within this thread. For one thing, I've GOTTA check out "HOWELL"'s build thread, more than anything 'cause of that light-weight compact REAR drum hub, as per the Fontana 250mm 4LS up front. I've always been curious about this type of thing - "how low can you go", in terms of swapping out the OEM drum hub for something lighter but set up with good shoes, maybe some 2LS actuation, etc.
But more on track with what I'm doing right NOW, as relates to my "CB900K0 Bol Bomber" project, I find it very interesting to see what team DHOLDA are running for rotors up front.
One of their yellow bikes is on Wikipedia IIRC, using the 296mm dished CB1100RB-only (now in re-production form via Metalgear in Australia, and cheaper than their regular SOHC rotors at that!) on what could only be (to MY mind anyhow) the one-year-only, one-model-only, Canadian-only, POLICE-only, dual-disc wire-spoke FIVE-bolt front hub - from the CB750P7 or thereabouts. FULL-ON 24-carat Unobtainium right there.
However, what we see HERE are some RCB's -
(((Honda gave 'em full bikes from what I gather, but DHOLDA did their own tuning & set up their own suspension etc? Interesting that the WORKS bikes still beat 'em anyhow, ennit? I suppose the DHOLDA & JAPAUTO & "Honda Britain" teams also did well in their own right - Far more fascinating that in this era there were still a few SOHC 999cc engines running against the new DOHC engines, and both of 'em in alternative chassis. This is what I love about Endurance racing, is the whole mix-&-match approach not to mention the independent teams etc.)))
But yeah - THESE bikes might be running light-weight PVM Magnesium rims & all of this other fancy chassis tech & running gear. But look at what they're running for ROTORS - up front at least - the vented 296mm GOLDWING rotors, not just CB1100R versions but those are distinctly GL1200 center carriers in some of 'em.
Here I had been humming and ha-ing over whether to KEEP mine, from the Comstar rims over to the new wire-spoke conversion. Gonna be a pain in the ass, and the Metalgear-AU catalogue specs would indicate that it's impossible - and yet I've SEEN pics, GOT pics, of the vented outer rotors stuck onto the six-bolt SOHC era GL1000 etc center carriers. If these babies won't work, perhaps it's the somewhat more rare REAR vented rotors from certain GL1100 models, which should swap over to the six-bolt carriers. Which is to say it'd be even MORE of a pain in the butt trying to dig up a good pair of those guys -
But apparently it's worth it? I mean, these DHOLDA racers would've been a lot easier to set up with the six-bolt rotors given those SOHC-era skinny version PVM rims - So you'd think some cross-drilled early SOHC CB750K rotors, themselves also 296mm, would be the go-to set-up. Even if they're using later era five-bolt PVM rims or had converted the earlier version as such, there's a five-bolt CB750A Hondamatic 276mm rotor, just like all of the other SOHC-era 296mm discs, for the CR750 dual-disc look. And these thick vented things are definitely heavier than the earlier SOHC 296mm rotors, and no doubt more of that mass is outboard where it counts even worse. And you can't SKIM any of that weight off, 'cause the two outer sandwich layers are already pretty darn thin, and I've even found a worn-out rotor which seemed to get a regular WARP" where the thinner wearing surfaces had seemed to bend in between the gaps - just that wee lil' bit, there was simply a "washboard" characteristic to the worn down outer faces. If you were to cross-drill 'em it's either gonna have to go through the inner section which keeps the outer halves together, or avoiding that & hitting just the "skins" it's not only gonna have limited effect (holes of a diameter approximately that of the materials thickness are only going to keep surface area more or less the same, so you'd be talking about a whole buncha holes less than 3mm diameter) and you'd probably negate the whole air-vane effect by shortening those inner channels - Seems redundant to cross-drill the things. If anything, search for the lightest version of center carriers and I'm guessing that's just what DHOLDA did in choosing the '84+ vintage discs.
Now, the dished CB1100RB-ONLY discs are the lightest of all period-correct 296mm types, so you'd think they'd use 'em but then again they're very rare & ergo $$$ parts after all - Still, they've gotta still be available enough to use 'em for annual competition only? Maybe they would if they could. And on that note now that they ARE available again, it'll be curious to see whether DHOLDA makes the switch in 2016 ... or in any subsequent pics, as these ones are dated back to 2012 - Gotta dig around for newer pics....
Somebody should ask Metalgear just WHEN they introduced their reproductions - I knew of their 276mm dished rotors for several years now, in fact I was ignorant of the full 296mm spec of those '81 homologated racers until a few months ago - I had assumed they were simply 276mm discs like all of the CB750F/CB900F CB750F2-SOHC etc. But you've gotta wonder - did they bring out reproduction rotors for a series of 1050 bikes? Or were more DOHC-4 enthusiasts & Goldwing nuts etc, requesting their 276mm versions be up-sized? Either way, it's simply awesome that they're offering the things! As for the 11mm thick VENTED discs though, nobody's making a replacement for THAT version, and it's complicated enough I wonder whether they ever will....
One would think, I mean - If I had MY druthers, which is undoubtedly feasible for a big well known well connected team like DHOLDA, it would be feasible to replace the outer rotors with some cross-drilled Cast Iron, or any other improved materials. Is it "ISR" that offers the superior stainless rotors with the better coefficient of friction?
So what's the deal here? Are they doing this for some DOHC-era authenticity? They're from 1981 model Goldwing & CB1100R, more to the point those solid center carriers are GL1200 ergo 1984-1987 period-correct. So if that's why they're doing it, they're a tad bit off the mark. I could see how some GL1200 carriers & solid outer discs from SOHC etc could make for some decent replicas of '76+ RCB rotors. Once I realized I was gonna have to mix-&-match the carriers, this was an idea which occurred to me, for some replica '76 RCB COMSTAR rims, with Akront "NERVI" rims on 18"/18" spokes, & CB900F front hub with possibly a disc-converted CB250N/CB400T rear drum or a lump of billet etc etc. Much as I love the fat alloy wire-spoke rims I'm building now I'm just as interested in a "re-invent the wheel" COMSTAR project. Even if it's Boomerang rims using that rear drum out of an XBR500 for the disc conversion etc - or two front rims what-have-you. So too, I've been obsessed with finding that CB750P7 Canadian-spec POLICE hub, and whip up a whole SCHWACK of different 5-bolt rotors for 'em, to be able to use the same rotors on either wire-spoke OR Comstar wheels.... Sure would simplify things that way, if one were to run say, a set of dry-track tires on the wire wheels and wet rubber on the Comstars. To hell with all of the aftermarket stuff, I'm talking about using Akront "NERVI" rims, where my wire-spoke 4.25x18" Akront weighs the same as the 2.50x18" hollow-shouldered version D.I.D. rim from a disassembled CB900F rear wheel - This would make a HUGE difference over the OEM version, and then figure out a way to either replace a smaller hub or use a bolt-up cush-drive on a front hub, etc etc. I'm hopeful that a pair of Comstar rims build this way would blow away all of these PVM Magnesium wheels. Diggin' the idea of the "TECHNOMAGNESIO" rims, where the Akront "NERVI" rim is bolted/riveted to a five-spoke core of cast/forged Magnesium. MARVIC did the same thing, albeit with three fat spokes inboard of both "Nervi" and regular old flat-deck Akront rims. But there's nothing more COOL on a Honda than an actual pair of Comstar rims. All the more cool if they can be rendered a little more "performance-oriented"....
WHATEVER. The point being, this seems to be a "GREEN LIGHT" on using them CBX pro-link / GL1100A Aspencade / GL1200 / CB1100R '82-'83 composite vented heavy-assed thick rotors.
On the one hand, it seems like early SOHC 296mm rotors in good useful condition are in scant supply, but then again if you SKIM the things, you restore the surfaces AND shed excess weight. I would think the economics of good SOHC rotors for a serious race team would be less about availability & more about the labour & tooling in setting 'em up right.
Whereas, THESE guys are still relatively cheap. Despite the prices of identical parts taken off '82-'83 CB1100R versus those from '81+ GOLDWING, & even CBX pro-link - where CBX may be "enjoying" increased values these days I'm under the impression that the early twin-shock models far outshine the later pro-link versions. But yeah, Goldwings are still the cheapest source of these rotors.
I dunno - I can see the better value for MY bike, as opposed to skimmed & cross-drilled rotors which probably STILL can't attain the level of surface area which the vented discs have. But for a top shelf team?
There's gotta be something to it! My GUESS would be that the added mass is actually of value here, for it's HEAT SINK properties. Which when paired to the massive surface area of this design, has got to allow for some very heavy brake usage, without penalty of fading at any point. The mass being enough to keep it cool during the slower corners - then once you hit the straights and gain some speed you're gonna dissipate that built-up heat and hopefully get 'em down to ambient temp or closer to it.
Would be nice if one could somehow dress these things up to look correct for a SOHC-4, maybe just a thin skin over the vanes in the "midriff" area? Possibly even just some silver paint on 'em, with blacked-out center carriers or swap 'em onto SOHC-era 6-bolt carriers of course, they might just stand in for bone stock CB750K/CR750 rotors.
Though I'm sure they'd be superfluous in all but the most demanding applications, hey? Maybe, 100HP+ big-bore monsters, for heavy track use? I'm sure a dual-disc set-up with the regular early 296mm or possibly even 276mm rotors would likely be more than enough for bone-stock motors and street-bikes. But say, upwards of 900cc's and ridden as a get-away for bank robberies or some such - for THIS I'd suggest trying it on a SOHC-4.
For myself, well. For the time being I'm gonna try & satisfy myself with something like a CR750 look-alike front end on my "CB900K0 Bol Bomber" - however, recent images of the '67 MV Agusta 4C6 have me worried just how close to the CB450K0 Black Bomber a DOHC-4 even COULD look, so I'm all the more hard-pressed to come up with a DRUM front end for the bike, being the "Faux-Leading-Shoe" GL1500 thing, ideally with 310mm rear discs from GL1500SE but 296mm OEM rotors from GL1500 front end will have to do. With that, MAYBE just MAYBE this bike will look somehow "correct".
And with that big fake front drum, one might THINK I'd consider an internal disc wire-spoke converted CBX550F fake drum. But I'm thinking instead, I'd like to run an actual DRUM rear hub. And for the 985cc DOHC-4 I'm thinking this for once would be a good application for the OEM 750 drum. I'm whipping up a light-weight DOHC 750 for my kid to ride, when she outgrows the "KZ440LOL" with it's little Suzuki 4LS etc. And I'd really like to run a bigger 4LS on it, with the 4LS-only converted 39mm CB900F fork from the KZ - but will very likely stick with the dual-disc 39mm fork on it, with the 296mm rotors etc. However for IT'S rear drum, I've been thinking for some time now just which of the smaller drums would be appropriate.
(This is why I'm so fascinated with HOWELL's pics!)
So I've got a 3.50x18" "Super-Akront" super light-weight RIM for the thing, which sadly can't be set up tubeless 'cause these older rims don't have the bead retention ridges. Ah but they're GORGEOUS though. But yeah, it's a pre-drilled rim, set up for a KZ rear drum. I've always figured I'd just swap a Honda drum straight across. but NOW I'm giving serious thought to whether it'll fit the early KZ400 40-spoke rear drum. It's a massive weight savings, yet it's a full 180mm drum.
(I'd somehow gotten it into my head that the SOHC & DOHC rear drums were 190mm???)
I had a KZ650CSR drum and an early KZ400 drum side-by-side, and it's a HUGE weight savings. Narrower for sure. The main difference between the drum linings themselves would seem to be the thickness of the lining, and a little bit of width as well. So yeah, this is a drum which you could over-whelm with HEAT FADE a lot quicker than a CB750K or other KZ drums for that matter. But I'm hopeful that I can whip up some good air vents for it. Maybe even find a sprocket type replacement for the belt-drive outer pulley on the light-weight rear sprocket carrier slash pulley center carrier - from the KZ454LTD liquid-cooled model. Some custom stuff that. Truth be told, I've also got some NOS belt-drive bits for KZ400 and I'd really like to see whether this could be converted over to work on the DOHC Honda. Would be nice either way. But the main point of wanting to use that KZ454LTD rear carrier is to get more air blowing through the drum - I wanna set it up as a "FAN" of some sort, to suck air in vents & scoops on the right side and out the left side via the center of the sprocket/pulley. Well, I'm thinking of setting up an alternative rear wheel and/or pulley for the KZ440LOL, the key factor being that the KZ454LTD carrier should fit the smaller 36-spoke drum, and doesn't have the outer diameter suitable for the 40-spoke hub. But it would be a nice test case to be able to run the same drum brake on both bikes and to play around with the ventilation thereof. There's an earlier version of this drum, from the Kawasaki S1 or S2, too-smoke triples & I believe it was even used on the H1 500cc too-smoke triple - anyway it looks just like the KZ400 drum but it's got four huge triangular holes in the central wall, where the later KZ version has a casting in much the same shape, as though the holes were simply not milled out. But yeah, this should indicate the possibility of cutting some holes to vent the drum from right-to-left.
Of course, if and when I ever get around to sticking a FULL-sized drum on the back end of my 900, I'm keen to try some new mods with that one as well. Being that it's so much heavier built, it should be able to take some lightening holes. And I realize this is probably the most "death defying" modification I want to try out, but I want to CROSS-DRILL - the friggin' DRUM lining itself. An old trick of automotive hot-rodders, it's surely far more suitable for say, a Harley "Juice-Drum" or Norton Commando etc - 'cause they're one-piece solid cast "BELLS" of Iron, whereas all of these Japanese hubs are what are called "AL-FIN" which is to say a machined ring heated & inserted to the mould where the Aluminum is cast all 'round it. Very different effects were you to drill the one vs the other. But yeah, I wanna try it, just a little bit at least. Maybe only a half-dozen holes or less, and small ones at that. The REST of the hub however, the Aluminum portion, I'm gonna ventilate the living heck out of that thing. I only wish to heck I could do the same with the '75-'76 CB750F1 rear DISC hub that I've got on hand for the 1st rear wheel I'm building for this bike. Got an identical 4.25x18" Akront rim to lace to a FRONT hub, with bolt-up cush etc. But somehow I don't think that's gonna LOOK right with the big front hub I'm eventually sticking onto this bike. Besides I expect the best weight savings I'll be able to achieve with this alternative rear disc hub, it's only gonna be on par with the drum anyhow. And I'd bet that on a dollars-to-donuts comparison between OEM drum & OEM disc rear brakes, the drum's probably got the better one-shot PANIC stop force. Sure it might fade with heavy repeated use, but truth be told with MY riding style at least, the rear brake doesn't even get used that much.
You've gotta wonder about the possibilities though. Of a really well set up rear drum hub, one that's either too small to lock up the rear wheel entirely, or set up in a dual TRAILING shoe linkage so as to obviate any self-energizing effects of the leading shoe - To use the rear wheel for controlled rear-wheel SLIDES, the way several famous former dirt-track riders brought to road racing. I dunno if I'd wanna ride like that on the street ALL of the time, but it sounds pretty exciting all the same. Pretty safe bet you'd wipe out in these parts. What with all of the sand & gravel spread on the roads during winter. (It sucks, but I wouldn't trade our endless stretches of remote unsupervised back-roads for anything!) Yeah I guess when it boils down to it, I'd want a certain brake set-up for street and a certain brake set-up for the track.
Doesn't only go for the rear brakes either. Here I've been looking at these FRONT rotors, these big thick vented 296mm discs sitting on my CB900F - one of the first upgrades I did upon purchasing this already tricked-out bike, and I've been trying to figure out how to KEEP 'em with the wire spokes, rather than just pop in the usual SOHC discs, I've been hunting for a five-bolt hub to utilize what I've got AND the SOHC discs in five-bolt form from CB750A Hondamatic (on Comstar-equipped versions only) plus the new production CB1100RB dished rotors - the best of ALL worlds, if one could pull it off. Might just be worth welding & re-drilling the Metalgear CB1100RB dished-discs (or ordering custom drilling if possible) plus swapped carriers in these babies, and some ordinary SOHC rotors - might just be less trouble & expense than the Canadian Police front hub anyhow. Certainly less trouble & expense & EMBARRASSMENT of running a Hardlyableson hub up there. Sure, they're five-bolt. But all of the other dimensions needing modded, adds up to a considerable expense as well. A pity, 'cause any problems with the rotors and they'll need to be done over again. But yeah - gonna swap the center carriers, & can't yet afford the Metalgear rotors anyhow.
But yeah - my POINT being, I was thinking of keeping the vented rotors on hand, being that my main purpose in upgrading & detailing the paltry 39mm front end anyhow, was for this planned DOHC 750 light-weight single-seater for Her Nibs to ride, and the whole point of the thing being that it be a light-weight bike of course the CB1100RB discs make the most sense, that or some heavily drilled SOHC rotors.
And then I got to thinking about taking these bikes across the Rockies to Vancouver Island, and how much as I'D love to whip through the Crowsnest Pass with all of it's twists & turns. However, the KID well she's a great rider but probably ... BAH - what am I saying? SHE'D be in great form to thread that needle. It's ME who's gonna have to do a re-think & cross the Great Divide via the Coquihalla highway straight up & straight back down again. Which is to say - coasting on those brakes the entire way down to sea level. Might as well turn the damn engine off, if it weren't for the fact of engine braking. Sure would be nice if you could engine-brake with the engine turned off somehow, but it's the fuel which keeps the damn thing cool, and a carbureted bike would suck fuel anyhow. So yeah - you're left with just the brakes the whole way down.
So for THAT purpose, I can see really heavy-duty rotors such as these having a purpose on the street.
Honestly though, I try & wrap my head around folks using 'em for a REAR brake now THAT one's hard to understand. I mean, unless you're constantly dragging the brake to fight the torque of the GL1100 shaft-drive? It's bewildering. Even on the biggest most powerful 1123cc CB1100F's & CB1100R's, or GL1100's & GL1200's - VF1000's & VF1100's for that matter, the OEM 296mm rear brake was already massive over-kill. So I toy with the idea of sticking one on the bike just for the triple-disc MOTIF if you wanna call it that, but it makes no sense at all.  So I try & wrap my head around a 210mm version from VF1000R instead, but it doesn't seem like it'll fit this '75-'76 CB750F1 rear disc hub. Would be awesome with a disc carrier, even better on that FRONT hub wheel.....
Well, whatever - I just wanted to say, some VERY interesting pics in this thread. Completely different approaches for stopping a track-bike. But each of 'em helpful for my current projects plus the next ones over horizon.
Hella cool.
-Sigh.
Offline SoyBoySigh
« Reply #36 on: March 25, 2016, 08:40:49 AM »
But more on topic, I just wanna add that I find it most discouraging, that here they went to considerable trouble creating a highly competitive tire for vintage machines, and yet they gave it a pattern of sipes so damn FUGLY that you might as well go whole hog & do the Oreo Cookie bike thing, (with all of the cream in the middle) swap out to a fugly-assed USD fork & hideous 17" three-spoke cast-mag wheels, in hopes of finding a modern crotch-rocket tire less hideous than these things. It's like ... like finding a beautiful old racing boot with all of the leather buckles & armoured toe-tips etc - then stepping through a puddle in the things and leaving little prints of Michael Jordan dunking a basketball with every step. Which wouldn't be so bad, 'cause you could stand there and not have to look at the soles, right? Whereas a tire's gonna show from all of 360-degrees!
HIDEOUS friggin' tires on such beautiful classic machinery these days. Downloaded some pics a while back of a nut-&-bolt replica of an RC-181, 500cc DOHC-4 Honda racer from what ... '66-'67? Yeah - but as perfect as this bike was, the best most retro-fried TIRES they could get for it were the same stupid looking Bridgestone Battlax type of rubber that I've had on three '82 DOHC-4's now.
Would if it were the other way 'round, hey? If I could find some '60s style rubber to stick on the '82 bikes?
Just think though, if it chaps MY ass - maybe it chaps yours too - What about these guys whipping up the perfect nut-&-bolt replicas? Do you think they get to the point where the bike's 99% done before they realize they can't FINISH the thing? With the bike up on blocks, beautiful alloy rims gleaming, perfect replica 4LS drums all polished up, put the seat-cover on and the paint & decals etc. Then they get the grips & toe pads etc - and then they sit down to relax & stare at the bike, maybe read a TIRE CATALOGUE over a beer.....
Here I was worried it had happened again. Like - when it became trendy all of a sudden to whip up a wire-spoked DOHC-4 café right after mine was lost in a house-fire, or I'd started my 985cc version of which and then Café Racer magazine announced that wire-spoke CB1100F - good thing it turned out looking like such #$%* ha-ha. Or there were the DIY solder-brazed clip-on bars I'd made from an old top yoke, only to find that the CHINESE of all people were knocking out clip-on bars for $40-$50 a pair.
I was thinking that just around the time I'd put together some nice fat vintage alloy rims in a size appropriate for some sport-touring radials of a 1990's style & specification, that they'd managed to put out decent wide radial tires that somehow squeezed onto skinny old's-cool rims. Kinda like the cheater race tires they made to put WM4 spec rubber on the WM3 rims which were capped out in the vintage AHRMA classes - only FATTER, just somehow squeezed onto them same WM3/WM4 rims.
But I guess the real trick here, had nothing at ALL to do with the stupid looking diagonal zig-zag sipes on all of these tires. THAT stuff is simply a styling exercise meant to evoke the hideous crotch-rocket jiggery-pokery with the computer designed slipstream bodywork carved via laser from an enormous block of cheese - then the little triangular scraps are picked up off the cutting-room floor, slicked up with contact cement on one side and flung at the bikes willy-nilly - the gold & purple anodized billet (KILL IT) Aluminum, #$%* like that.
What proof? Well just look at the actual race-spec rubber, how they've got slicks - and then the RAIN tires - with old's-cool looking sipes strung longitudinally, then transverse to the direction of travel. I mean, if this is considered to be cutting edge appropriate to a modern bike, why can't they do this on a STREET bike tire?
I mean, yeah - I realize there are surely a few disadvantages to classic diamond/rectangular grid style tires, that made themselves apparent over the years. Tracking in the rain grooves of freeway over-passes. Perhaps some type of cupping or other such wear problems. So it's to be expected that the majority of classic bike owners are gonna look at tires strictly by "form follows function" logic. Except it DOESN'T, it's just another type of styling exercise. But let's say that it IS a bad idea over the long haul, that they won't last as long or won't corner quite as well.
Even SO - shouldn't there be a tire you'd buy just the one set of, for taking pictures of your bike the day you've finished the restoration? A period-correct looking tire, just so you could pull out the vintage clothes the roll-film cameras, some bad HAIR let's just say (Hey some of ya'll are sporting your '70s-'80s hair ALL THE TIME, just ready for those vintage re-enactment moments, am I wrong?) and not #$%* up the photographs???
Something in BETWEEN the modern crotch-rocket rubber, and the Coker Tire Firestone replica BALLOON tires. Perhaps some reproduction Bridgestones appropriate for that perfect concours restoration '68 CB750K0 pre-production Sand-Cast?
Seriously. Put me down for at least a couple of sets. IMHO it's about time they made 'em in the fat 17" crotch-rocket sizes, too. The Michelin Pilot Classic series was pretty awesome, remember THAT one? Couldn't have launched the Duck Paul Smart Replica without 'em let alone the Sport Classic (gotta wonder, where that name came from) or the GT1000 twin-shock once they'd figured out how screwy the other bikes looked. Seriously, without those tires, them wire-spoked rims would've looked like #$%*. Kinda still DID come to think of it, though mostly after the Michelins had been discontinued. Ah, but I guess they had a few small recalls & other problems. Probably scared the rest of the tire companies from doing anything similar or even better....
What cheeses me off more than anything, was them tires actually CAME in 18" Sport Touring sizes for a while back there. 110/80ZR18 & 160/60ZR18 just like I'm whippin' up NOW. And here I was, waffling over the purchase of this truly odd-ball STAINLESS STEEL 4.50x18" rim, 'cause it had a Harley-hub drilling pattern to it. Haven't seen 'em since, either. Kinda wonder whether they were actually made for the "Big Wheel Craze" that was just catching steam at that time, with the VTX1800 etc, itself using a 150/70-18 or 160/60-18 up front! But yeah, would've made some AWESOME wheels with that, but the "Front Hub Trick" made me uncomfortable. Here I am NOW, waffling over the weight of the BIG hub and having bought two rims the same size to make up my mind over which hub to stick with. Oh, but alloy rims don't COME in 4.50" - which is incidentally the recommended rim size for all of these tires - just 4.25" or 5.00" when neither is ideal. Sheesh. Probably should've gone with the 5.00" anyway, but was already concerned with weight. What would be interesting though, is to compare the stainless rims vs Aluminum/Alloy/Aluminium. Probably a big enough deal that I shouldn't concern myself. But it's more of a "bird in the hand" type of thing, 'cause that would've been several years ago by now. More to the point, all of the NOS alloy rims I lost in that house-fire wouldn't have melted into shiny lil' dog turds if they were made from Stainless Steel! It was cheap, too - $99ea on clearance. And of course the Michelin tire would be all worn out by now, or at the very least rock hard dry. Even so, just putting 'em both on my DOHC-4 would've given one a lifetime's master-batory subject matter, perhaps even sharing some Bike-Porn with the rest of humanity....
Tell you what though, I'd be happiest of all if I could find a TRUE "vintage tread" tire in 140/80-18 for the 3.50x18" Super-Akront rim. That would give the most "period-correct" total package at least for my "Retro-Fried" project theme. Proper mid-'70s specs, whereas the wider stuff seems to fit more of a mid-'80s period just from old pics of racers etc.
Damn though, probably gonna have no choice but a fugly '90s style tire tread on THAT wheel too. Argh.
-S.
« Reply #37 on: March 25, 2016, 08:57:27 AM »
Holy #$%* man, you want us to read all that?
Offline gschuld
« Reply #38 on: March 25, 2016, 10:04:36 AM »
I got a 3rd of the way through, and I got winded ...felt dizzy :o.  And I know all about wordiness...
I'll try again this afteenoon :)
George
Offline simon#42
  • liverpool
« Reply #39 on: March 25, 2016, 11:27:02 AM »
a 3rd of the way through George , you did a lot better than me
Offline calj737
  • I refuse...
« Reply #40 on: March 25, 2016, 11:28:50 AM »
In a single post, he eclipses all the words in all the posts on this thread over 3 years. Then posts again! Ramble much?  ::)
Offline gschuld
« Reply #41 on: March 25, 2016, 11:33:12 AM »
He's got a lot on his mind....and I'm gonna read it all, when I'm nice and comfortable.
George
Offline calj737
  • I refuse...
« Reply #42 on: March 25, 2016, 11:34:12 AM »
Hope you start early so you don't run out of daylight. It would cost a bloody fortune to read that by lamp light.
Offline simon#42
  • liverpool
« Reply #43 on: March 25, 2016, 11:37:30 AM »
hang on in there , the bit about ugly tyres is classic !
Offline gschuld
« Reply #44 on: March 25, 2016, 02:34:00 PM »
Ok, I did it.  I'm exhausted..... :-\
George
