Author Topic: Fuel Tap To Fit Bartels CR Tank  (Read 2085 times)
Offline spiritof67
« on: June 05, 2012, 08:30:56 AM »
What fuel tap(s) is commonly used with the Bartels aluminum CR tank? I know there were recommendations to use a Honda CRF tap (anyone got the Honda part#?) but are there any others that can easily replace it or are better? And in street use has anyone done a comparison to see which inline fuel filters flow the best with gravity feed?
Is there a Pingel bolt-on that works?
Spirit
Offline martin426
Re: Fuel Tap To Fit Bartels CR Tank
« Reply #1 on: June 05, 2012, 09:59:53 AM »
 I use a Pingle Dual-Race 3/8 npt fuel valve ( with adaptor plate (#A1602C) on my Bartel CR tank.
1978 CB550
1970 CR750 replica
1979 RCB1000 replica
1988 RC31
Offline Jim F
  • go baby go
« Reply #2 on: June 05, 2012, 10:16:59 AM »
On my Cr tank I had the male adapter already there
but the valve it self if the same duel set up as what martin uses
on the post above this one
its a good flowing valve
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline spiritof67
« Reply #3 on: June 06, 2012, 05:02:22 PM »
Thanks Martin and Jim. Do either of you use any kind of O ring between the tank, the adapter and the tap?
Spirit
Offline martin426
« Reply #4 on: June 08, 2012, 05:38:20 AM »
The pingle adaptor came with a little tube of goo and a gasket.  I did use a little teflon tape on the tap thread.
1978 CB550
1970 CR750 replica
1988 RC31
Offline lordmoonpie
    • Moonpie
« Reply #5 on: June 08, 2012, 03:11:34 PM »
Apparently it needs a Honda CR500 fuel tap that slots staright on but they differ over the years so it's possible to get the worng CR500 tap. Not sure which year is the right one I'm sorry - I ended up getting mine custom made...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #6 on: June 08, 2012, 05:08:46 PM »
Does Pingle have adapters so we can use their fuel taps on stock tanks.?
« Reply #7 on: June 09, 2012, 07:33:49 PM »
 Yeah it looks like the piece on the right hand side.. it may have an O-ring oval in it..
 easy piece to make without the groove..
