Author Topic: CB750 carb bushings  (Read 6560 times)
Offline lucky
CB750 carb bushings
« on: June 05, 2012, 08:17:27 PM »
Replacing throttle shaft bushings in CB750 carbs.
I was rebuilding some CB750 carbs and i need to replace the throttle shaft bushings.
The originals were some kind of sintered bronze and had deteriorated.
Lots of corrosion potential A steel shaft in a bronze bushing inside of an aluminum casting.
So I replaced them with PTFE sleeve bushings,.
They can with withstand 547º and need no lubrication and will not corrode.
I bought them in New York from Quality Bearings& Components
2101 Jerico Turnpike,New Hyde Park.
Sales 516-616-0043
They are PTFE Sleeve Bushings 10mm x13mm x 10mm wide.
It take s 2 for each side of the casting so you need 4 bushings.
There is a minimum order so it is best to order 8 and then you have enough for two sets of carbs.
They are about $5 something each.
P/N is BSPPLNM101310T
Just clean and sand the casting hole and tap them into place.
Support the casting on the edge of a table so you do not break the casting.
« Last Edit: June 05, 2012, 08:19:14 PM by lucky »
Re: CB750 carb bushings
« Reply #1 on: June 06, 2012, 03:15:52 AM »
Hey Bob, seeings though these are non stock bushings and a home made fix, shouldn't it stay in tricks and tips..?
Offline lucky
« Reply #2 on: June 06, 2012, 10:08:58 AM »
Homade fiX?   Can't you think of something more derogatory?
« Last Edit: June 06, 2012, 10:36:48 AM by lucky »
« Reply #3 on: June 06, 2012, 10:11:14 AM »
 If they were sintered they may have been OILITE..in which case, a drop of oil every 3 years should keep them going for like.. hmm the ones on the bike outside are 38 years old. Benn riding it 2.5 years plus.. time to oil them..
Offline lucky
« Reply #4 on: June 06, 2012, 10:23:07 AM »
I have encountered a set that were coming apart.
Another person rebuilding a set of cabs discovered the same problem and I was able to help that person too.
Since you doubt me I will now post a photo of what that bushing looked like upon tear down.
Here is a bushing that has come apart from corrosion.
The problem is caused by a bronze bushing inside of an aluminum casting. There is also a pin inserted into the bushing and that is a steel pin. Fortunately the steel pin usually gets completely corroded and it makes it easier to get apart.
Also the steel throttle shaft gets a lot of pitting corrosion in the area between the sets of bushings. Otherwise between lifter arm A and lifter arm B.
« Last Edit: June 07, 2012, 02:30:30 PM by lucky »
« Reply #5 on: June 06, 2012, 11:59:55 PM »
Only you could find something derogatory out of something positive........... ::)
« Last Edit: June 08, 2012, 04:22:10 PM by Retro Rocket »
Offline lucky
« Reply #6 on: June 07, 2012, 02:32:03 PM »
Only you could find something derogatory out of something positive.......Fool.... ::)
Sorry RETRO....I thought you were knocking down my repair solution.
My apology.
« Reply #7 on: June 07, 2012, 10:38:35 PM »
My apology.
Thats ok, i was saying that i thought it should stay in the tricks and tips section because it is a great fix , its things like this that make this forum a great place.
Offline lucky
« Reply #8 on: June 08, 2012, 11:47:07 AM »
Thanks Retro Rocket.
You are a good guy.
When I posted my repair solution I really try to be accurate and make sure it is a safe and secure solution. I would not want anyone to get hurt.
I checked all of the material parameters for heat etc.,.
TEFLON® PTFE fluoropolymer fiber is stable over a wide range of temperatures. The fiber becomes less ductile at extremely low temperatures and softens at extremely high temperatures. Experi­ence shows that adequate toughness and strength are available for selected uses at temperatures as low as -450°F (-268°C) and as high as 550°F (288°C).
 PTFE can withstand 550ºF for 1 hour.
« Last Edit: June 08, 2012, 11:58:15 AM by lucky »
Offline brandEn
« Reply #9 on: March 16, 2013, 08:05:35 PM »
Bumping this thread, I need the part number. Thanks Lucky!
Offline lucky
« Reply #10 on: June 13, 2014, 11:11:21 AM »
I believe it is already in the tips section.
Offline lucky
« Reply #11 on: June 13, 2014, 11:15:36 AM »
The problem is that on some bikes (different geographic locations) there is a great potential for corrosion to take place.  It is a bronze bushing inside of a aluminum casting with a steel roll pin holding it from spinning. Lots of corrosion potential under certain conditions.
With a plastic PTFE bushing all of that corrosion potential is eliminated.
