Author Topic: Headlight drains battery  (Read 9622 times)
Offline saxamaphone
Re: Headlight drains battery
« Reply #25 on: September 21, 2012, 09:49:37 AM »
I found a cool charging mod for my CB450K6 here http://www.hondatwins.net/forum/viewtopic.php?f=53&t=6185.
Not sure if anything like that exists for the fours.
1975 CB550K1, 1973 CB450K6
« Reply #26 on: September 21, 2012, 10:06:24 AM »
It doesn't.
Offline saxamaphone
« Reply #27 on: September 21, 2012, 10:16:43 AM »
That's good to know.  Even more impetus to make sure you have your charging system working as good as possible.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=c7r923jjadc2gfd3dtgivuqng5&/topic,60973.0.html
« Reply #28 on: September 21, 2012, 12:31:06 PM »
only work on simpel 1/2/3 fase generator...can be done on yamaha fs1 and honda cd 50. and other moped liked small mc.if they are used in city traffic..but the battery have to be kontroled often..you boil the battery vhen driving NO. light on
« Last Edit: September 21, 2012, 12:33:34 PM by strynboen »
i hate all this v-w.... vords
Offline stockscreamer
  • 8 valves + 4 pistons + 2 wheels = 1 happy guy.
« Reply #29 on: September 21, 2012, 01:06:34 PM »
I know your problems already been solved but i had issues with charging due to a dented dynamo cover which in turn had the field coil tweaked inside causing contact to the rotor. did every single electrical test known to man for these bikes and came up with a defective field coil a couple times and a couple other times it tested good.. measured the difference in depths with a straight edge across the gasket surface and shimmed it straight, adjusted the regulator gap and taa-daa good as new-ish ; )
Long story short if your dynamos scratched/dented check the gizzards.
Josh
There are no absolute truths. The truth of a theory is merely its power to produce predictions that are confirmed by observations.
