Author Topic: Engine leaking oil..  (Read 3915 times)
Offline chickenman_26
    • Motorcycle Consumer News
Re: Engine leaking oil..
« Reply #25 on: June 09, 2012, 07:40:48 AM »
Thanks.  Do I need to yank the whole engine out? And how do these go bad? I bought it and it didn't do this ...now its doing this leaking.
Sent from my MB855 using Tapatalk 2
You don't need to pull the engine. Just remove the valve cover. Age and lack of use contribute to these things leaking. It's common. Old rubber parts harden and shrink.
Stu
MCN DTF
« Reply #26 on: June 09, 2012, 08:18:03 AM »
Stu
+1  25 years ago we could care about things like low mileage, how it was used or abused. Now those don't matter (as much) as the sheer age factor overwhelms everything. At 40 years+, all the rubber parts, inside and out, are likely shot, cables and chains that look great are corroded internally past redemption, electrical coonnections the same robbing power, etc.
Offline DJ_AX
« Reply #27 on: June 09, 2012, 09:26:53 AM »
... and sometimes a fresh oil change or two in combination with usage will reveal leaks formerly blocked by gunk.
Offline Gorwoc
« Reply #28 on: June 09, 2012, 10:39:00 AM »
Maybe sit back and have another beer, go outside and catch a smoke. Just don't get frustrated yet. The wind blows that oil everywhere so look for the simplest explanation first.  I've tried the foot power spray and it worked but the engine has to be really really clean of oil before you put it on.  I'm not sure if you really need to ride it to show up though.  The wind will blow it around but it's oil pressure that puts it out there.  I think that just the running and revving that you'll do while trying to work through the other problems will pump some oil out for you to see.  I don't know about the "pucks" on the 550 but the 400f's leak spot is the rubber "doughnuts" that seal the oil passage around the head stud.  There you need to pull the head so it may not be such a big problem for you with these pucks. I agree with you in wondering why it's started up now.  I would expect that you would have seen a slight seepage first, not enough to drip yet.  Might want to spray up the tach drive seal to just to be sure you didn't miss something there.  Hey, at least it's not pouring out of the bottom of the engine... constantly... like something British.
Gorwoc
the man with no signature
Offline messeduptriple
« Reply #29 on: June 10, 2012, 01:47:41 PM »
Seems like its coming from the left side of the engine in the fins. Any thought on what next?
