Author Topic: Not sure of which forks I have/how much fork oil to use  (Read 8463 times)
Offline tmac
« on: June 08, 2012, 09:47:20 pm »
OK So I find out the P.O. installed an 81 air assisted front end on the 78 750K that I own. I am currently rebuilding the forks and just measured the upper tube. It measured 23 5/8. My question is I guess : Which front end do I have & how much oil goes in each tube? I put 6 oz. atf in each leg.I think they need some more fluid but I dont wanna make the new seals leak by over filling!! Also gonna hafta return the new springs I got because they are only around 19 inches long, wish I measured em before ordering. Dohhhh  >:(
Re: Not sure of which forks I have/how much fork oil to use
« Reply #1 on: June 08, 2012, 10:50:22 pm »
Maybe a picture of the forks would help? There's many that will fit these bikes.
Offline tmac
« Reply #2 on: June 09, 2012, 02:38:05 am »
I cant get any pics to post. it keeps reading " request entity too large"? Hondaman sir, Thank you for the reply. I was told that the bike had a frozen front caliper when it was nearly new & the PO threw the whole front end away(yes sir, I said threw away, as in tossed in dumpster someplace. What a maroon !) and swapped an air assisted front end from a 1981 CB750K. Gonna keep trying to post pics.
Offline Xnavylfr
« Reply #3 on: June 09, 2012, 05:04:52 am »
I know that some Magnas, Sabers ,CB900c (37mm), 75-77 wings (37mm)used airassist forks.
Xnavylfr(CHUCK)
Offline onepieceatatime
« Reply #4 on: June 09, 2012, 05:49:41 am »
The 1981 CB650 has air assist forks. They are 35mm. I have a set in need of seals that I will be taking apart (probably tomorrow) that I can measure the tube length for you. If they are for the '81 650, here is the oil capacity chart from my clymer manual.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #5 on: June 09, 2012, 08:29:48 am »
Lower the pixel setting on your camera to make a 'smaller' picture or use a free online photo service to reduce the size and then you can post up some pics  ;)
« Reply #6 on: June 09, 2012, 09:15:05 am »
I missed this part and was going off the title on my previous post. The service manual for 79-83 CB750K says drain and refill capacity is 155cc (5.2oz) and rebuild capacity is 172.5-177.5cc (5.8 to 6.0oz)
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline lucky
« Reply #7 on: June 09, 2012, 10:04:25 am »
Why don't you buy a workshop manual for your motorcycle?
Offline tmac
« Reply #8 on: June 09, 2012, 02:18:50 pm »
I have 2 workshop manuals thank u sir. They are for a 1978 CB750K. The front end is an 81. Should I buy a manual to see how much oil they take or just ask u friendly helpful chaps on here? Thanks so much and have a great day.
Offline tmac
« Reply #9 on: June 09, 2012, 02:19:37 pm »
The tubes are 35mm sorry,
Offline Roach Carver
« Reply #10 on: June 09, 2012, 02:24:11 pm »
I cant help you but if you get a pic up or set up a free photobucket account and post that way you will have your answer shortly I imagine.
Offline tmac
« Reply #11 on: June 09, 2012, 06:22:07 pm »
Thanks Bro !
Offline tmac
« Reply #12 on: June 09, 2012, 11:14:56 pm »
lowered pixels hope this works
« Reply #13 on: June 10, 2012, 05:41:53 am »
Those look a lot like my 77 cb750f forks.
Offline tmac
« Reply #14 on: June 10, 2012, 08:19:55 am »
it only has 1 caliper mount on the left side. didnt Fs have dual fronts?
« Reply #15 on: June 10, 2012, 09:03:14 am »
Yes. Fork volume would likely be the same. Not sure if thats the same fork though.
« Reply #16 on: June 10, 2012, 09:37:47 am »
 Try 5 -6 oz should be fine...
Offline tmac
« Reply #17 on: June 10, 2012, 11:16:05 am »
Thanks 754 !
