Author Topic: '71 CB500 won't go into 2nd  (Read 3483 times)
Offline LesterPiglet
  • 1977 CB550F2
Re: '71 CB500 won't go into 2nd
« Reply #25 on: June 12, 2012, 06:19:04 AM »
I had that same problem and it turned out to be the spring in the centre bottom of this picture had broken.
If you try and shift into second then slightly tap the gear lever down then try shifting into second again does it make a difference?
