Author Topic: Race Tach  (Read 5369 times)
Race Tach
« on: June 10, 2012, 01:55:37 PM »
I'm in need of a decent electronic tach. I've tried two different GSXR tachs and they just wave at me at high rpm. Scitsu is on the list though some aren't sold on them. Any good options? I just want to cover my tracks before I pull the trigger.
Offline simon#42
  • liverpool
Re: Race Tach
« Reply #1 on: June 10, 2012, 04:23:24 PM »
i would take the scitsu off that list brent , ok they are cheap but they are not very accurate and seem to die at the drop of a hat . if you must have one the ones with the external battery seem to last better .
Re: Race Tach
« Reply #2 on: June 10, 2012, 04:45:35 PM »
Thanks Simon. That's the feedback I'm hearing about Scitsu too. Got a brand name?
Offline Tintop
Re: Race Tach
« Reply #3 on: June 10, 2012, 07:14:37 PM »
I haven't installed the tach you send me bw, do you want it back?  I'll probably stay with a mechanical for now because of battery life issues.  That said a self powered tach sounds interesting.   Wonder how long it would take for the sidecar's vibration to kill it.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline lordmoonpie
    • Moonpie
Re: Race Tach
« Reply #4 on: June 11, 2012, 10:45:55 AM »
I'm surprised at that Simon I've used Scitsu for years and never had any issues providing you follow the battery instructions to the letter and the trigger wire is attached to the HT leads properly. Dawson Harmsworth who make them have even taken old tachos for me and changed the internals to go from a single to an inline four with different wasted spark etc. If you're not using mechanical tachos, I'd have no problems with Scitsu...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline simon#42
  • liverpool
Re: Race Tach
« Reply #5 on: June 11, 2012, 11:20:48 AM »
i use krober rev counters on the tz's and rotax 's , a bit more expensive but on the dyno they seem to be dead accurate .
http://www.motocicliveloci.it/inglese/catalogue/strumenti_uk.htm
simon ive bought loads of scitsu's off tony over the years.  ive got a couple from the 80's that still work ok ive also got a big box of broken ones that where only a year or so old . ive got none that are very accurate
  • Moderator
Re: Race Tach
« Reply #6 on: June 11, 2012, 11:52:09 AM »
I guess some people are just unlucky 42. I ran them on the CR and Benly for years with the built in battery and on the RS off the battery that was fitted for the aftermarket ignition, air shift and nitrous systems.
Like his lordship says, the after sales service is first class from Scitsu.
Sam. ;)
Offline H2Eric
Re: Race Tach
« Reply #7 on: June 11, 2012, 02:50:32 PM »
How about a Krober tachometer? I used them on both my Triumph and Honda drag bikes. They do several different models depending on the number of sparks generated per crankshaft revolution. I haven't got a link but if you try a Google search it should come up.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline turboguzzi
Re: Race Tach
« Reply #8 on: June 11, 2012, 09:48:30 PM »
Brent
massimo, owner of motocicliveloci is a friend, just in case....
never knew he dealt with krober...
Re: Race Tach
« Reply #9 on: June 12, 2012, 03:34:31 AM »
I think Howell uses a Kroeber too. I'll let you know TG.
Offline iomtt9
Re: Race Tach
« Reply #10 on: June 12, 2012, 01:21:59 PM »
Brent , i'm with Lord Moonpie, never had a problem with the 500/4 using the scitsu.
Col
Offline turboguzzi
Re: Race Tach
« Reply #11 on: June 12, 2012, 02:53:33 PM »
if money is short you could try these...
http://www.stackltd.com/st200.html
Offline scondon
  • Mmmm......tasty bugs
Re: Race Tach
« Reply #12 on: June 15, 2012, 01:39:25 PM »
I've had this mini wired through my Dyna 2000. Running for years now with zero issues. It's small, but the lit red needle is easy to read, and it's very steady. Made in Canada, Brent ;)
http://www.kosonorthamerica.com/new/shop/motorcycle_gauges/gp-style-universal-tachometer-4/
Re: Race Tach
« Reply #13 on: June 15, 2012, 02:44:54 PM »
Hey stranger good to see you Sean-man. I looked at those tachs and a mess of others. I've got feelers out there on some options. Thanks everyone for the experiences & info.
Offline turboguzzi
Re: Race Tach
« Reply #14 on: June 18, 2012, 10:21:42 AM »
did you ever check out those new smiths motorpsorts ones?
Re: Race Tach
« Reply #15 on: June 18, 2012, 12:46:03 PM »
Re the Smiths.... I have asked two different UK suppliers for a recommendation on either Smiths, Stack, etc. and neither would answer with more than two words, but that's cool. TTR400 likes the Elliot but they've unfortunately gone out of business.
I'm leaning to the Kroeber/Pitsch unit as several guys have highly recommended them. I like the look of the Scitsu but there are just too many that have had negative issues.
« Last Edit: June 18, 2012, 03:54:50 PM by bwaller »
