Author Topic: Have I got the original spare parts  (Read 1097 times)
Offline caller
« on: June 11, 2012, 02:55:09 am »
I have a Honda CB 750 -k4. It was a basket case when I bought it but becomes more and more complete.
I wonder if I have bought the right parts for a -k4.
The rear winkers got two separate strength of lights, like a rear bulb with rear light and brake light. The winker got a diameter of 90 mm and the hole to fit the stay is 20 mm.
« Last Edit: June 11, 2012, 03:05:29 am by caller »
Re: Have I got the original spare parts
« Reply #1 on: June 11, 2012, 04:43:21 am »
Looks like that turn signal has the big round back,not the smaller dimple back. The one in the picture is for a 75 or later. 74 is different and uses a smaller stem also. Also if you need a grab bar for the rear 7274 and 75-76 or model specific to each other as there are different size stem mounts. My info only applies though to USA models,may be different over there. This is proper for a K4 over here.
« Last Edit: June 11, 2012, 04:49:41 am by ekpent »
