Author Topic: Kickstarter conern after rebuild - cb750k1  (Read 951 times)
Offline Prospect
« on: June 11, 2012, 05:26:22 PM »
I'm about 95% done my k1.  I'm at the final stages of putting everything together.  Full bottom and rebuild as well as everything else.
First concern..
I put on the kickstarter today and tried to just kick it over at it was extremely hard.  I have to put almost all my strength to kick it over.  When I turn over the engine using the large nut on the stator it turns over nicely.  I'm not sure what it could be.
Second concern..
The clutch plates are not installed at the moment as I'm having trouble putting on the clutch nut.  I'm able to turn the sprocket freely by hand when in gear which concerns me because there should be considerable resistance at the sprocket.   :'(  I'm thinking the clutch is disengaged when plates are out so that's why this is happening but I thought I'd ask.
« Last Edit: June 11, 2012, 05:34:22 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Kickstarter conern after rebuild - cb750k1
« Reply #1 on: June 11, 2012, 07:09:34 PM »
First concern..
Was this first item with or without the clutch plates installed? If they were installed, did you opt for a later model (i.e. "thicker" clutch pack)?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Prospect
« Reply #2 on: June 12, 2012, 05:13:10 AM »
The clutch plates were not installed in both cases.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
