I got my wheels back from the $75 mounting/balancing.
They said "no weights were needed"
Front wheel always stops at the valve stem down. It will even roll up and then come back the other way back down and land with the valve stem down. It seems slight like it is really close but just not quite. I can't test out my back wheel because the bearing isn't that smooth but they put the yellow marker right on the valve stem on that one?
Not too satisfied with that. So they didn't do #$%* in terms of balancing. I should have just put the #$%*ing tires on myself if that's the case
