Author Topic: Do you count while shifting?  (Read 4389 times)
« on: June 13, 2012, 06:05:24 AM »
Of course I can tell what gear I am in, but I still count when going up or down.
Am I the only one?
Offline LesterPiglet
  • 1977 CB550F2
Re: Do you count while shifting?
« Reply #1 on: June 13, 2012, 06:07:33 AM »
I usually get to 25 or so then something else distracts me. :)
« Reply #2 on: June 13, 2012, 06:13:41 AM »
 ;D well I only know numbers 1 through 7 and than have to switch to Czech language.
Offline jamesb
« Reply #3 on: June 13, 2012, 07:53:09 AM »
your not the only one i thought i was the only one who did that so i guess there is two of us so far. i've always counted when i change gears even in my cars
Offline Motoguy23
« Reply #4 on: June 13, 2012, 09:12:27 AM »
You're not alone.  The  bad thing is that I'm cruising in fifth and always thing I have a 6th gear. (m dirt bike has six)  so I pull the clutch and try to shift but have to settle for fifth.
All glory to the hypno-toad.
Offline azuredesign
  • Knupping pin
« Reply #5 on: June 13, 2012, 09:51:35 AM »
I don't count in that way, but I try to figure what my rev count is in my highest gear at 60 mph. Then I subtract 500 to 1000 rpm to know what gear I'm in. I ride a few different bikes and this helps me especially when on the highway.
Offline kirkn
« Reply #6 on: June 13, 2012, 09:56:36 AM »
LOL!  Good question.  I never thought about it until just now!  :)
I usually count 1st, 2nd and 3rd up, then quit.  And, I've had so many different bikes over the years, I'm ALWAYS reaching for another higher gear.  :)
And, I count along with motor revs, raising the voice in my head to match the revs...  firrrrrrst, seccccoonnnnnnnd, thirrrrrrrrrrrd...  :D
I also count down from the top, too, but invariable start as if I were driving a 6-speed bike - the first click down, I'll think "5th", then "4th", then "no, wait, dammit, this is only a five-speed, so, where was I.....  Oh, look, there's the neutral light."
:D
Kirk
« Reply #7 on: June 13, 2012, 10:18:13 AM »
Long ago, yes.  But, I haven't for a while now.  It's just not important anymore.
The gear is selected for the tach reading.  Tach needle low, downshift, tach needle high, upshift.
A nice quiet pipe allows for that without enraging the residents or constabulary.
I still sometimes try to up shift when in 5th gear, and I want the tach reading to be lower.  But, if it won't shift, I know I'm in top gear.
Sidenote:
I now have a Cb700SC that has the gear indicator on the dash.  I still use the tach for gear shifting.  About the only time I notice it is on the freeway, while bored, when it says "OD".  On that bike, the lever doesn't move up anymore when in OD.  I notice that before looking at the indicator.  ;D
  • 1977 CB550F2
« Reply #8 on: June 13, 2012, 10:22:07 AM »
When it says OD does that mean only downshift?  :P
BrockSamson
« Reply #9 on: June 13, 2012, 10:28:32 AM »
I am still getting used to the high cruising RPM (compare to my car) and I constantly try to shift into a gear I do not have.
I do not count at all on the bike.  My mind is constantly checking mirrors, scanning traffic, etc.  I just feel the bike and react.  I am a novice though and my brain doesn't operate on that level yet, I am still ultra defensive.
« Reply #10 on: June 13, 2012, 12:08:36 PM »
Um, well, yeah.  There IS only one Over Drive gear selection.   :-\
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #11 on: June 13, 2012, 12:33:07 PM »
I always think about counting, but always get distracted for whatever reason.  The only reason I want to count is because it bugs me to try to shift up when I'm already in top gear.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline fmctm1sw
« Reply #12 on: June 13, 2012, 01:00:24 PM »
Am I the only one?
Other than that guy that was looking for 6th gear on his 350F a while back, yes...   :D
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
bollingball
« Reply #13 on: June 13, 2012, 06:08:11 PM »
I get to ten and remember i have my shoes on. I don't count at all in the winter ;D
bollingball
« Reply #14 on: June 13, 2012, 06:14:45 PM »
I don't count I just listen to the motor and look at the tach if I'm on the big highway. I like to stay above 3k cruise at 4.5k-6k
Ken
« Reply #15 on: June 13, 2012, 06:24:28 PM »
Do i count when shifting, No, do i make my shifting count, Yes...{i hate false neutrals}.. 8)
« Reply #16 on: June 13, 2012, 06:59:59 PM »
I am bit surprised nobody came up with the obvious joke substituing t for f :)
« Reply #17 on: June 13, 2012, 07:19:13 PM »
It takes some getting used to since we have grown accustomed to our cars with their six speeds and overdrives.
Stay ultra defensive also, you will ride a lot longer and healthier that way.
Offline Roach Carver
« Reply #18 on: June 13, 2012, 08:12:43 PM »
I hum.
Offline Old School Honda
« Reply #19 on: June 13, 2012, 09:12:10 PM »
I try to count, but usually forget cause I'm concentrating on everything else.
Offline trueblue
« Reply #20 on: June 14, 2012, 03:48:56 AM »
I usually only count the downshifts when approaching a corner at speed when riding hard, otherwise I have time to look at the tacho and speedo to figure out what gear I'm in, but I am guilty of regularly looking for 6th.
1979 CB650Z
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #21 on: June 14, 2012, 06:17:38 AM »
I just listen to my engine.  However, I often want a 6th gear.  I have developed the habit of lifting my toe against the shifter every once in a while while I'm cruising.  If it won't move it means I have another gear, if it moves then I know I'm in 5th.  Works for my Honda and my Harley.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline Johnie
« Reply #22 on: June 14, 2012, 09:47:33 AM »
Never did count the gears. I just go by the engine rev sound and then shifit.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline K5 Keith
« Reply #23 on: June 14, 2012, 10:11:00 AM »
...I have developed the habit of lifting my toe against the shifter every once in a while while I'm cruising.  If it won't move it means I have another gear, if it moves then I know I'm in 5th. ...
+1
Only in the last couple weeks have I figured this out! Before I would automatically pull the clutch expecting another gear that insn't there.
Offline krusty
« Reply #24 on: June 14, 2012, 04:16:15 PM »
I count only when riding my 60 Suzuki Colleda with a 4 speed rotary gearbox. Ever experienced going from top into neutral then thinking its a false, shift again straight into first , at 50mph?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
